This problem should be removed because:
Problem with Sony Flat Panel Televisions
sony lcd kld-52z5500 tv receiving only 1080i
tv receiving only 1080i pictures how do i setup 1080p - is my connections ??
Suggested Solution (2)
Not sure about your exact model, but for most HDTVs, you cannot set the resolution in the TV itself, the TV will automatically adjust to whatever signal is sent to it.
Note that Many HDTVs cannot do 1080p over component video inputs, only HDMI. Also, check for firmware updates for your TV, as manufacturers seem to be are often fixing bugs with things like HDMI input detection and so forth.
A 4 flash shutdown indicates a backlight problem. It can be acused by a bad backlight inverter board (the backlight power supply) or by a defective backlight in the panel. There are fuses on the backlight inverter board called "picofuses" which will need to be checked in order to isolate the problem to the board or the panel. If the fuses are good, you have to replace the panel (very expensive!). If the fuses are opne, most likely the back light inverter board has failed.
Source: I have a Sony KDL-40V2500 LCD 1080P TV there is no picture the
1080i, 720p
I have the Sanyo dp42746 and just wonderinig how can i get my picture up to 1080i or can it be upconverted to a 1080p with an up converter....
Hi, Can you tell me if the panasonic TH37PX600P
Hi, Can you tell me if the panasonic TH37PX600P plasma TV is 1080p HD ready? Also, if I connect a panasonic blu-ray player to this...
my tv only shows 720p and i am not sure how to
my tv only shows 720p and i am not sure how to adjust it to 1080p ={
I just got the Toshib
I just got the Toshib 46rv530u and can't figure out how to get it to change video to 1080p
New TV is hooked up
New TV is hooked up from satelite cable via HDMI wire. We have it plugged in the HDMI port # 1. When we turn on the cable, the little box...
Tips for Helping sjwalley3 With Their Issue
- Give detailed step-by-step instructions
- A picture or video is helpful
- Use plain language not industry jargon
- Check spelling & punctuation
Add Your Solution
tv settings
tv is working but cant get picture or sound
samsung makes buzzing noise, gets louder when...
I move the Samsung to another room and began to make this horrible buzzing noise. I've tried connnecting...
no screen on tv
turn on tv and do not get a screen for days
Fix-O-Meter
39
39 people viewed this problem
- 0 people are following this problem. Be the first!
Top Sony Flat Panel Television Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
