Question about Dell Sound Blaster Card
I have re installed windows to a critical error,
I have re installed windows due to a critical error, my sound card is not working. I have checked the devices on the HD and all working correctly.
    President:
  • 1,653 Answers
You will need to reinstall the Crative Soundblaster driver which you can obtain from thje following Creative Link
http://support.creative.com/Products/Products.aspx?catid=1
Posted on Nov 13, 2009
Just bought new speakers i know they work. but the sound through my computer does not work even through head phones. how do i fix this?
Check your computer if the driver of your sound card is installed by play a music/mp3 in your windows media player if no error your sound driver is installed already...if there is a error installed first your sound driver...you can check also your speaker to another computer with installed sound driver, if this working...your computer have a problem with your sound driver..
Mar 05, 2011 | Acer AX1200B1781A / AX1200-B1781A /...
Installed hallmark card studio 2011 upon launch keep recieving send error message to microsoft.
The installation must have gone wrong somewhere, Uninstall and install again.
If the program works anyway. Just disable the "Send Error Report" message:
To access the settings for the reporting feature:
  • Click Start.
  • Right-click My Computer, then click Properties.
  • Click the Advanced tab.
  • Click Error Reporting.
To configure the error reporting feature:
  • By default, error reporting is enabled. To disable it, click Disable error reporting. To continue to be notified when errors occur without being prompted to report the errors, click to select the But notify me when critical errors occur check box.
  • Specify whether you want to use error reporting for the Windows operating system, for programs, or for both Windows and programs.
  • To report errors only for selected programs, click Choose Programs, click All programs in this list, and then click the programs that you do not want to include.
  • To add a program that is not listed, click Add, type the name of the program, or click Browse to find the program on your computer.
Mar 01, 2011 | Computers & Internet
Creative sound card! no sound!
Check whether you plugged in the speaker wire into the correct jack at the back of the computer (it should go into the green colored jack on the sound card).
Did you try playing a sound file? Does media player show the file as playing, but you can't hear anything? Or do you get any error? if there's any error, please mention the error.
If the sound plays but you can't hear anything, again, check the speakers are connected to the correct sound jack. Next, try connecting a pair of headphones or earphones (lower the volume before playing any sound  or music file).
If you still can't hear anything, click Start and type the command "dxdiag" in the Run box and then press the Enter key. In the dxdiag window, click the Sound tab. Check the Notes box, if it gives any error info. If your card is working, it should say 'No problems found." You can also test the sound using the "Test Directsound" button.
If you still can't hear any sound, you should check and reinstall your sound card driver manually after removing it first.
There may be other problems. For more information, check this nice blog post about sound problems.
Hope that helps.
Regards,
Raspal
Jun 14, 2010 | Creative Labs SB0400 Audigy 2 Value Var...
Dear Sir or Madam When I want to play a music on my computer , I get this error: "Windows Media Player cannot play the file because there is a problem with your sound device. There might not be a sound...
Yes there is something wrong! The sound card driver is corrupted!
YOu need to check on device manager again. Look for your drivers there.
If you do not see the EXACT NAME of your sound card, then the driver that is installed is a DEFAULT driver made by the os.
Ex: This is a sound card driver name listed in Device manager:
IDT HIGH DEFINISION AUDIO
This is an example of a default sound card driver that will not work well on certain sounds or will not work at all:
LEGACY SOUND DEVICE
Even thought you many not see a yellow question mark (which you should be checking for too just in case)on any of the listings for your hardware, chances are you are still using a default sound card driver due to a corruption to its original sound card driver.
So recheck your device manager and find out the exact name of your original sound card. If there is no match to your exact name of your sound card, then you need to REINSTALL your sound card driver again and you will immediatly see your sound card working again :)
If this does not work, you may have to change your sound card.
Hope this helps :)
Mar 16, 2010 | Intel Motherboard
Music wont play through media player due to installing web cam
Hello my friend, i had encounter same problem as you have when i on one of my client's computer. You can reinstall the driver of your sound card. When you installed the program driver of your cam the sound card is affected due to some factor either the sound card is currupted. So my solution are the following: 1. Go to my computer icon then right click it the click properties. Then go to Tab name Hardware then click device manger then check if the sound driver is not installed or it is being corrupt. Then proceed to the reinstallation of your sound card driver. But if the sound card driver is installed then reinstall you windows media player. If you don't have installer then try this link: http://www.microsoft.com/windows/windowsmedia/player/10/default.aspx 2. Donwload Windows media player codec and update the codec of your Windows Media Player. try this link: http://www.microsoft.com/downloads/details.aspx?familyid=06fcaab7-dcc9-466b-b0c4-04db144bb601&displaylang=en
Hope this help fix your problem. If you need more help just contact me or reply to this post. Thanks
Jun 25, 2009 | Logitech QuickCam Pro 5000 Webcam
My Dell Inspiron 1521 laptop recently shutdown and would not reboot due to a Windows Vista error. After recovering my files, I decided to install Windows XP. Obvisouly, the product code is not compatabile...
You might find it difficult to get hold of windows XP keys since Microsoft stopped selling it.
If you get on google and search for something called TinyXP (rev09). I think that this willl solve your problem.
May 18, 2009 | Dell Creative AWE64 Value Sound Card
After re-installing windows XP Professional, every thing is OK but no sound. I went to sound from control pannel but I found the sentence: no audio device
Open the Device Manager and look for any Yellow Exclamation points indicating a device hasn't installed properly. If your sound card shows up as an Unknown device, run Windows Update to allow it to find the proper driver. Sometimes on re-install, Windows needs to update several times, installing Critical updates before looking for drivers. If this doesn't work, click on the link below and install the program. It will identify all of your devices. When you find the soundcard, go to the manufacturers website to locate and install the driver. I hope this helps with your problem and Good Luck!
http://www.zhangduo.com/udi.html
May 11, 2009 | Computers & Internet
No Sound is there while using SAA7130 TV Card
I am using p4 dual core intel processor 3.06 Ghz. Recently i installed tv tuner card on my suystem with cabil connected to this card. but due to unknown reasons sound stopped coming. though the picture is still there i am using Windows vista . My system config is 2 GB DDR2 ram and tv tuner card with 80 gb HDD + FDD
Due to this problem I formatted my hard disk and re-installed everything but the problem remained i re-checked everything with no results.
can you help me to sort out this.
thanks
Dec 29, 2008 | Philips SAA7130 TV Tuner/FM Radio/Video...
RealTek HD Problem win2K3 SP1
This might be error due to the DirectX  problem some sound card drivers works with addon softwares by installing DirectX 9.C will solves ur problem. After installing DirectX install sound drivers.
hope this will be helpfull
Bye...
Jun 04, 2008 | Microsoft Windows XP Professional With...
Error code: 88780078
Error code 88780078 Means bad sound card driver or bad direct sound driver.
You need to re-install your sound card drivers. If this does not work you will need to download and install directx from www.microsoft.com.
Also check this thread
http://www.opentechsupport.net/forums/archive/topic/24955-1.html
Regards
Feb 21, 2008 | Computers & Internet
Computers & Internet Logo
71 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
