Question about Maytag Neptune MAH5500B Front Load Washer
Does the door switch control the front load washer and dryer performance
    President:
  • 1,653 Answers
The door switch is a saftey switch that will prevent the machine from operating and the drum from turning if the switch is not 'closed' or 'made', i.e. Door Closed. These can eaasily be replaced and are relatively cheap components.
Posted on Nov 13, 2009
Starts to spin then cuts out
Check the program controller for shutting off, check the motor for tripping off , possible door switch making it cut off - safety switch on the door.
If prograam controller , check for loose connections, if motor check if heating off, check capacitor .
Sep 29, 2010 | Electrolux EW1200i Front Load Washer /...
Can I change the side the door opens?
Unfortunately you cannot reverse the doors on this model. There have only been two front load washers that I know of that had reversible doors, the maytag neptune and amana front loaders. Your matching dryer for this model, I believe has a reversible door, but you'll have to purchase a kit to do it. IF needed maybe you can switch the dryer and washer locations to make them more accessible?
Sorry, and good luck to you!
Jul 03, 2010 | Whirlpool GHW9100L Front Load Washer
The dryer does not cut off when door opens and also will not stop when on off button is pressed. To switch it off you have to turn the timer to off or switch off at mains.
The secondary microswitch controlling the door is shorted. Check the microswitch which is located at the door perimeter and have it replaced.
Nov 08, 2009 | Hotpoint Aquarius WD63 Front Load...
How do I remove and then replace a new door seal on my hotpoint WD420 washer / dryer
First switch off electrics , Remove door interlock , leave wires on .remove soap dispenser,remove front panel with controls 3 screws top of machine 3 screws bottom remove front casing you can now see door boot. remove sring note how boot came off refit is oposit to this noting top / bottom of seal ..Hope this some help-
Oct 03, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
The dryer's control lock light stays on and can't start the dryer
I held the "End of Cycle " button for 3 seconds and the dryer reset itself. Pretty simple.
Jun 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My front-loading automatic washer won't start . mechanic was here and replace the main control computer and nothing.. than he tryed the front control nothing - now their saying is something wrong with the...
it is unfortunate that this has happened.
sorry to here. it is most common for front loading washing machines and dryers to have a faulty door switch, although new machines have become increasingly difficult to diagnose. and parts have become much more expensive. Its possible he may be able to by pass the door switch to test the machine or test the door switch.
Hope this helps
May 07, 2009 | Whirlpool GHW9400 Duet Washer
Whirlpool duet 9400 Washer won't do anything?
Hi.
Please read the Fixya article below explaining how to fix the problems related to control lock on Whirlpool dryers and washers.
The front light lit on my Whirlpool.
Regards.
Dec 27, 2008 | Whirlpool GHW9400 Front Load Washer
Washing machine doors
Electrolux has a reversible door for both front load washer and dryer. Just found that out at HHGregg because we need to put our washer to the right of the dryer, and none of the other makes will allow the washer door swing to be switched.
Apr 11, 2008 | Kenmore Elite 45986 Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
