Question about ASUS P5N32-SLI Deluxe Motherboard
The motherboard not give any display !
ASUS MOTHERBOARD MODEL : P5N32-SLI DELUXE
The motherboard not give any display ! I was tred everything to solve the problem but i was field :
1- I change the Power Supply .
2- I change th Ram .
3- I chacked the processor on other computer i have its working in good condition .
4- I remove all parts and chacked all they are work perfectly.
5- I remove all Parts and i leave the Power supply and ram and processor and i turn on the motherboard but no display .
6- I bought New Bios chip with motherboard programing but no solve it .
7- The motherboard green light is on and all processor fan and VGA fun working but no display .
7- I change the VGA card and I put it new one but still no display .
Last i tred everything but the problem not solve it . I need your solution before i decided to through the motherboard from my windows .
Best Regards ,
Morshed
  • 1 more comment
  • morshed828 Nov 13, 2009
    Hello Agine ,
    I forget to told you i was do removed the battry and the cmos jumper for 24 hours before not only 3 mins . but no display . You know i have also asus motherboard model P5N32-SLI SE DELUXE and had same problem . I think maybe the problem came from nvidia chipset in motherboard . Need solution as soon as possible .
    Best Reagrds ,
    Morshed .
    Yes I write for you by the same monitor tested . I have new vga card which i bought before its NVIDIA but the old one is ATI , samtime if you change the vga card efen of the old one is work maybe is solve the problem . The hard disk is working , i can hearing the sound but no display . This motherboard it was working before perfectly but after 1 year stop to give any display . This case is more than my experince .
    Best Regards ,
    Morshed .
  • Sam May 11, 2010
    ASUS motherboards are quite reliable. I don't think you should throw it out of the window yet. I am not sure if the motherboard was working before and suddenly you find a problem now. This motherboard is atleast 3 years old so you must have been using it before this problem started. You say that you changed VGA card - this I am not clear. If you tested the VGA card and it was OK then why get new one? When you have hard disk connected and you turn power on then do you hear any disk bootup sound? Have you tested the display monitor separately? If you are hearing hard disk bootup sound then atleast motherboard is active. If you are using this motherboard first time then you have to be sure you are connecting the VGA card in the correct slot. The motherboard uses sophisticated NVIDIA SLI chipset for the PCI connections and you have to use the correct slot and drivers for VGA graphics card. Have you got the user manual. If not download fromhttp://dlsvr.asus.com/pub/ASUS/mb/socket... check page 2-25 and 6-1. Good luck
    Guru:
  • 480 Answers
Last 2 things to do
1.remove the cmos battery
2.remove the cmos jumper.
remove power cable from power supply.
3.wait for 2 to 3 mins
4.put the jumper back to the correct position usually pin one and pin 2
5.try to start the mb if ok
ok
Posted on Nov 13, 2009
P5N32 -SLI Deluxe. I use windows xp on virtualbox and have problem with sounds, I dont have sounds, Have to using chipset Nvidia? If yes which one?
hi
if you want to go for then only you can put any Nvidia Pci card
or
try to run motherboard drivers hope fully sound will come
May 30, 2010 | ASUS P5N32-SLI Deluxe Motherboard
I have a p5n32-sli deluxe motherboard. Do you know if it suports the intel core 2 quad processor Q8300?
The highest you can go is a Pentium Extreme ED-965(3.73GHz, rev C1), it will not support the Core 2 series
Apr 21, 2010 | ASUS P5N32-SLI Deluxe Motherboard
System has been working fine for several years. Now on boot up, shows initial screen with ASUS information (motherboard model P5N32-SLI SE Deluxe, Press DEL to run Setup). No BIOS beeps. Warm reboot,...
Are you able to enter into the BIOS settings by pressing DEL?
If so, load default settings in the BIOS and try booting up again.
Best wishes,
Graemevm
May 05, 2009 | ASUS AI Lifestyle P5N32-E SLI...
I have a ASUS P5N32 SLI Deluxe Motherboard but when i boot up pc i get a black screen
I've had similar problems to this, where the computer would start sometimes, and other times it would start, but not give me any video. I changed my power supply and the problem was solved.
May 04, 2009 | ASUS P5N32-SLI Deluxe Motherboard
Constant restarting with my asus p5n32-sli deluxe motherboard
These boards have reknown faults, usually regarding Bios errors and memory slots on the motherboard. try removing ram, and trying in different slots. Or if your using a matched pair of memory modules. use 1 only in slot A1 or B1. Finally is to check the bios setup, to ensure that all the bios defaults are set.
If this advice resolves your problems, please rate as fixya.
Many thanks mike @ compurepair.
Nov 16, 2008 | ASUS P5N32-SLI Deluxe (890552603794)...
Problem in my asus motherboard
I don't understand the exact problem you are facing but hope that you are getting your problem due to the processor. If possible, try with dual core processor.
Feb 14, 2008 | ASUS AI Lifestyle P5N32-E SLI...
Freezes at random
From Asus website:
System become unstable when I use 4GB memory. How do I solve this problem?
Please upgrade to beta BIOS version 0702 or later to solve it.
http://support.asus.com/download/download.aspx?SLanguage=en-us&model=P5N32-E%20SLI&type=BIOS
Nov 12, 2007 | ASUS P5N32-SLI Deluxe Motherboard
Need wiring harness guide for asus p5n32-sli deluxe motherboard
http://support.asus.com/download/download.aspx?SLanguage=en-us&model=P5N32-SLI%20Deluxe
You can get all the files you need here.
Download and print only the parts of the manual you need or it will be almost a whole stack of paper.
Good luck with this mobo.
I've had nothing but prob;lems with it.
I'm going back to my ecs that I know works.
I suggest you search "problems with p5n32-sli".
Oct 18, 2007 | ASUS P5N32-SLI Deluxe Motherboard
ASUS P5N32-SLI Deluxe Motherboard Logo
341 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
