Question about Bosch Axxis WFL 2060 Front Load Washer
Sirs: The Softener Dispenser on my Bosch Axxis washing machine is filled up with water. What to do? It won't dispense softener.
    President:
  • 1,653 Answers
Take out the drawer and clean the compartment and pipe at the end of the drawer with hot soapy water - washing up liquid works well. Clean all around it. Use a pipe cleaner, cotton buds or piece of coiled curtain wire to ensure that the U shaped pipe is clear of obstruction. Pull it back and forward to dislodge any accumulated fabric conditioner. To show this is working OK, put it in the sink and fill up the compartment with water until it is overflowing then stop. The water should drain out of the compartment on its own.
Next, where the drawer fits in the machine clean the water exit above the drawer with a washing up brush. This can appear brown or white depending on your water type. If this is OK then try running the machine. If there is still a problem, remove the drawer again and turn off the power at the mains. Use something like a paper clip to poke all the holes in the water dispenser area above the drawer. There are lots of them so some patience might be required. If you live in a hard water area it could be blocked with limescale in which case an application of a descaling mousse or spray will assist. Once complete, make sure you rinse the drawer area, drawer and put the drawer back in and run the machine on a short cold fill wash cycle. Put some fab con in the drawer to test that the machine drains it correctly. A good idea is to slightly water down fab con concentrate as it will eventually clog up the dispenser. If all is well then there will be no fab con left. If it is still there then you will need to get into the water dispensing area to see what is wrong. Occasionally the mechanism can get jammed, lose a spring or just get broken, in which case it will need replacing.
Posted on Nov 13, 2009
Bosch classixx 1200 fabric softener dispencer doesn't empty into machine just fills with water
Pull out dispenser drawer in the middle section for fabric softener lift up top plastic cover and flush out hole with water and this should solve the problem
Jun 08, 2017 | Bosch Washing Machines
Front load washer dispenses fabric softener drawer fills water
either the auto dispenser is sticking , take out and clean with hot water. Or flow control valve needs replacing.
Feb 24, 2014 | Bosch Washing Machines
Frigidaire washing machine fabric softner will not dispense out
Hello - There are several things that could cause the fabric softener to not dispense into the washer. Are you sure the liquid in the dispenser after the wash is fabric softener? If it is fabric softener, the solenoid that lets the water into the dispenser is not working. This solenoid is located on the back of the dispenser. It only gets voltage during the dispense time and fills the fabric softener dispenser with water. The fabric softener dispenser fills while the washer is filling for the rinse cycle.
When the washer begins to fill for the rinse cycle, the fabric softener solenoid is energized and water flows into the fabric softener dispenser cup. When the cup is full the water siphons out and softener and water flow into the tub.
If the liquid in the fabric softener dispenser is pure softener you may need a technician to diagnose and repair the problem. The voltage will have to be tested to the softener solenoid and a volt meter is required.
If the liquid in the fabric softener dispenser is water you probably need to clean the dispenser cup. **** will build up in the siphon tube and stop the liquid from going into the washer tub. The incoming water will dilute the softener and overflow the dispenser cup and run into the tub. The instructions for cleaning the dispenser should be located on page 43 of the use and care guide that came with the washer.
If you don't have the use and care guide these instructions will help. Open the dispenser until it stops. In the left rear corner of the dispenser, there is a release that is labeled push. Press down on the push area and you can slide the dispenser drawer out.
Remove the insert from the bleach and fabric softener compartments. Clean the bottom of the insert and the bleach and fabric softener compartments. Reinstall the insert and put the drawer back inside the washer.
To test the siphon action slowly pour water into the fabric softener compartment. When the water level goes above the maximum line stop pouring. The water should all drain out.
Hope this information proves to be helpful however if it is ineffective please contact a professional to move forward accurately.
Oct 26, 2012 | Frigidaire Affinity ATF7000E Front Load...
Water left in fabric dispenser after load
The dispensers work by the siphon principle. You load the softener and at the proper time, the machine diverts water to the softener cup raising the level. In the softener cup, there is a tube loosely covered with a cap. When the level in the softener cup is raised high enough, a siphon effect is started and the softener is pulled from the cup into the washer. This will continue until the water quits flowing and air gets under tha cap, breaking the siphon. The amount of water remaining in the cup is dependent on the level of the cap, and the amount of residual water remaining in the dispenser fill tube once the siphon effect is broken. You can see this effect for yourself: take a measuring cup and slowly pour water into the softener cup, raising the level above the max line. When the level gets high enough, the contents of the cup will dispense. You can remove the cover cap that is a part of the dispenser and clean it; it will help. Removing the entire tray and cleaning all of the tubes and the cap assembly will also help. The only other thing that can be done is to change the dispensing supply valve, as it sounds like there may be some leak by after the fabric softener is dispensed. Having residual water isn't really hurting anything. It's only water, and the machine has dispensed the softener! Try the cleaning part first as this usually corrects the issue, and then the repair technician if it still bothers you. For as much as the extnded warranty costs, you should be completely satisfied with your machine.
Best regards, --W/D--
Sep 13, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Water left in fabrish softener dispenser after wash cycle
My Frigidaire front loader was doing the same thing and also not taking the bleach. I could hear that the water pressure was not real strong when I turned the machine on. I removed the two small screens on the back of the machine where the water supply hoses attached, found they were partially clogged and cleaned them well. The bleach and softener dispensers are now working like new.
Aug 03, 2009 | Bosch Washing Machines
Fabric Softener Dispenser wont drain
Try using a long handled babies bottle brush to clean out the rear of the dispenser and the tube leading down into the drum
Jun 18, 2009 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Bosch Washing Machine Softener Tray not emptying
You need to replace the cold water inlet valve. If the machine is older than one year it may be clogged on the side that moderates the cold water to the bleach and softener compartment. Replacing the valve fixed the problem. During the cycle when the softener dispenser fills it should fill quickly and no or little water should be seen in the soap dispenser area. If a lot of water goes into the soap dispense and little into the softener area the valve is clogged.
Feb 15, 2009 | Bosch Logixx WFT 2806 Front Load...
Washing m/c does not take softener during washing cycle.
Hi. Assuming the washer has completed the rinse sequence, there is a possibility the dispenser part of the valve could be faulty. I assume that you have put the conditioner in the right compartment of the dispenser.. If all else seems to be o/k, I recmmomend thay you once again thouroughly strip and clean the dispenser..
The other possibility is that the hole where the water comes in at the top of the dispenser is blocked.
You need a stiff piece of wire with a hook on the end and poke each hole that you can see in the top of the dispenser compartment
This should solve the problem
Please leave feeed back.
Thanks
Dec 03, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Bosh washer won't dispense softener. cleaned the tray and tested it by filling with water and it drained completly out, so i know its not clogged. washed another load and softener still there at end of...
I had the same problem. the only thing that works for me is fulling the fabric softener compartment all the way to the top with water then it will syphon down! it adds it to the load at the start instead on the rinse cycle but its better then nothing!
Jul 28, 2008 | Bosch Washing Machines
Dispenser
add water to them and then it will work
Feb 20, 2008 | Bosch WFMC 3200 Front Load Washer
Bosch Axxis WFL 2060 Front Load Washer Logo
262 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
