Question about AT&T 922 Corded Phone
Screen will not stop flashing ( power failure) after the power surged a few days ago
  • 135 Answers
Plz change ur battery
Posted on Nov 13, 2009
  • jranieri77 Aug 31, 2011
    change the time and date, or if you have caller ID it will update automatically and should clear the message.
42 inch flat screen sanyo wont power on wont do nothing bought 2 years ago
Power surges, such as those caused during lightning storms, can often cause power supplies in electronics to fail. Sometimes, if you're lucky, the manufacturer will have placed a protection fuse in the power supply which can be replaced after a surge. If there is no such fuse, the power supply typically will need to be replaced for the equipment to regain function.
It is VERY IMPORTANT to use SURGE PROTECTORS on all electronics, especially if you live in an area where thunderstorms are commonplace. This will protect your electronics from most (not all) surges that would otherwise zap them into failure.
May 24, 2014 | Televison & Video
The screen of Nuheat Solo keeps flashing, the floor is cold. It seems like that the whole system stop operating. Yesterday, it was fine.
I had the same problem. It is caused by a failure in the thermostat, usually brought on by a power surge. Unfortunately, this product is poorly designed, and cannot handle common power surges in homes. The only solution is to replace the thermostat unit. Nuheat has a decent warranty (3 years) so you may qualify for a free replacement.
Dec 22, 2013 | Nuheat SOLO Thermostat
How do I reset Electrolux E48DF76EPS?
Only way to truly shut it down and bring it back up is a power reset from the household circuit breaker for about 10 minutes. Then retry.
Aug 05, 2012 | Electrolux E48DF76EPS Dual Fuel Range
MY SONY K800i IS DEAD ! TRY TO FLASH IT, BUT NEED TO KNOW WHERE TO DOWNLOADFLASH MAIN FIRMWARE AND FLASH FILE SYSTEM
hello brother i have sony k800 i flash it it work properly but few days ago it goes white screen after few seconds when phone power on i again flash it now it is dead plz help
Dec 15, 2010 | Sony Ericsson K800i Cellular Phone
When I restarted the computer, the monitor would not come back on. The green power light on the monitor was not lit. A few days of letting it sit there and the monitor suddenly came on again. Then, we...
Such is life when you leave both monitor and pc on all the time and have them unprotected by a surge protector and have it subjected to repeated power failures and power surges. Either the hardware fails or the system software becomes corrupted. When there is a power failure, unplug your monitor and pc, wait for power to be restored and only then plug them back in. That may not stop errors from the power failure but it will stop hardware from being fried by a power surge.
I think your best bet is to take it to a shop and have them boot the computer from a Windows 7 disk (if that is your operating system). If you video card has not been fried, that should load your drivers and operate your monitor (which you will take along also.) If it can be booted, then software corruptions introduced may be fixed and disk errors fixed. If you had an autobooting repair flash drive, it alone might fix the problem. But you would have to have a rather geeky pal around to have that. One might be made using resources at Majorgeeks.
There is a wee possibility that you could try another monitor with the system and that monitor might work and you could try entering safe mode with networking via F8 at boot. Then you might try using the sfc command or error correcting programs such as Tweaking.com's windows repair and or Glary Utilities. Sorry but the repair possibilities rather shoot off in a variety of directions. Windows 7 has a number of repair options built if you can get the system to boot.
Oct 09, 2017 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Blinking red power light
HI. this is an unfortunate power board failure. The board is unable to distribute the proper current at this time. you must replace this failed board asap. this will fix this issue.
Aug 08, 2009 | Panasonic TH-42PZ77U TV
Frigidaire side-by-side stopped working
I would chech the components on the compressor. Take the cover off the compressor power terminals and inspect the relay for damage.The power outage is not a concern but the power surge could definately be the cause. hope this helps.
Jul 28, 2009 | Samsung RS2578BB Side by Side Refrigerator
All TV's in house failing, a few at a time
Hey PNorris,
If multiple electronic devices are failing in your home all at once, I would probably first have to ask if your home recently experienced an electrical storm or major power surge of any kind.
Normally the effects of such large-scale surges are immediately noticeable - TV's and other major electronic devices may fail to turn on, fuses may be blown or circuit breakers tripped, and in some cases electrical wiring may be melted.
If nothing like this has happened recently, low-level power surges may still be a potential cause of this problem. When the motor from any large appliance (such as an air conditioner or refrigerator) turns on or off, it often diverts power to and from other electronic devices using the same circuits. This fluctuation in electrical current may result in low-level power surges to every connected device. While not immediately noticeable, these low-level surges can often cause the eventual failure of (and gradually degrading quality in) many audio/video components.
Typically, the easiest way to avoid situations like this is to make sure that outlets are not overloaded and surge protectors are used with every major electrical device in your home. For older homes however, replacing the house's wiring may be necessary. Homes that were originally built at the turn of the 20th century may not always have wiring capable of supporting the electrical needs of many modern appliances.
Ultimately, this means that in addition to contacting your local TV repair facility, you may want to also speak with an electrician. This is probably the best way to determine whether or not power surges have caused these failures, and may give you a better idea how to proceed.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jun 12, 2008 | Televison & Video
HP Media center 1170m
did you checked the ram just clean and fix it again. bye
Oct 01, 2007 | HP Media Center m1170n Photosmart PC...
AT&T 922 Corded Phone Logo
142 people viewed this question
Top AT&T Lands Phones Experts
george  peters
george peters
Paul C.
Level 1 Expert
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
