Question about Ariens 34 In. Zoom Series Riding Mower
I have a 1984 ariens snowblower with a Tecumseh and no spark
I have a 1984 ariens 7hp snowblower and it has no spark i put a new spk plug in it still no spark I am trying to find out if it has points that mabe that is the problem.
Thank's for the help
  • 486 Answers
Electronic Ignition was introduced on many engines about that time frame. I would need to have model and type numbers from the engine to fully determine that question. However, have spark is still the issue. If the unit has a switch installed on the operator's console, it should be disconnected at the engine so that any safety switches are not masking or causing a problem that is not engine related.
Let's investigate a few basics first.
a) How have you determined that there is no spark?
b) Have you used a type of spark tester?
c) What is the condition of the plug. Brown or dark brown is OK. Black or silver is NOT Ok.
*If you do not have a spark tester,
a) remove the plug, and with it connected to the wire,
b) find a portion of metal around the cylinder that you can ground it on, and then pull the rope.
c) If the plug is black, you may see spark, but you should replace the plug.
*** PLEASE NOTE ; if there is excess fuel in the cylinder or on spark plug, it can catch fire, so be carefull to cover the hole with a heavy rag so that any fuel cannot be exposed to spark plug durning test !!!!
Get back with me on how this issue works out.
thanks, rwvanlue
Posted on Nov 13, 2009
On a 1973 Ariens Snowblower with a 7hp Tecumseh motor what is the proper way to check oil level? Do you screw the dip stick all the way in or let it sit on top of the oil fill hole?
To check the oil you screw the dip stick as far as it will go. Before you start take the stick out and wipe it off then insert and screw it in to the bottom then take it out and check it.
Jan 26, 2015 | Garden
Parts not available for Ariens ST724 7hp snow blower?
As far as the bolts you should be able to match them at a small engine and lawnmower repair shop and as well if you take the old recoil they might be able to get you what you need.
Nov 10, 2014 | Garden
Parts not available for Ariens ST724 snowblower?
No you do not..you have the model number and hp should do it ..go in on your computer and just put the name,model number,hp and model in that order .or better yet go in on eBay and put that in and most likely you will find it a a reduced cost..good luck
Nov 10, 2014 | Ariens Snowblower Belt 72098, 8hp 1/2 X 37...
I have an Ariens ST724 7hp snowblower (model:924075 serial 005629) that needs to have the starter cup, recoil, and the 4 bolts that secure the recoil replaced. The problem is all of these parts are NO
In order to order engine you must look-up the engine itself. If this blower still has the original engine then it is a
Tecumseh HSK50-65496
Recoil Part Number TEC590604 Image
t_590604_000.jpg This item has been discontinued by Tecumseh, part number STE150-003 will work but does not have the handle cup.
Original Tecumseh Part
Replaces Tecumseh 590604 and 590605
Fits Models: H, HS, HSK
For use on Snow King Models
RECOIL STARTER ASSEMBLY TECUMSEH 590420A
Craftsman snowblower will not start
Dump out the old gas and put in new.Try a spray of starting fluid into the carb. If it will not fire on the starting fluid there is somthing wrong in the ignition system. Pull out the spark plug and clean it with a wire brush. If it still won't fire the points and condensor need to be replaced.
Dec 21, 2013 | Craftsman Tecumseh Snowblower 7hp...
Ariens snowblower 1979 how to test for spark
The coil needs to be just close enough not to rub. Wrap a piece of hard copper wire on the threads of the plug and ground the other end to the engine. Pull the handle and watch for spark.
Dec 14, 2013 | Tecumseh Snowblower Snow Blower Starter...
Ariens 34 In. Zoom Series Riding Mower Logo
1,141 people viewed this question
Top Ariens Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Paul Sikkema
Paul Sikkema
Are you an Ariens Garden Expert? Answer questions, earn points and help others
