Question about Focal 165 K3P Car Component System
What is the wiring diagram for focal k3p crossovers
Previous owner played with the wiring of the vehicle. I would like to fix it back to original
you will need the factory wiring diagram to be able to do this...
and as long as you take your time and follow the diagram, you too can become an automotive electrical specialist... get good glasses or magnifying glasses or in my case, bi-focals LOL
Dec 29, 2013 | Cars & Trucks
How do I replace a blown fuse on the Solo 6 be?
Unscrew the woofer, gently pull it out, follow the wires to the crossover, replace the fuse, reverse the process.
Jun 18, 2011 | Focal Solo6 Be 2 way Near field Shielded...
Problem with focal k2 power and focal fiberglass speakers in car
It could be the setup of the speakers, but I would install a crossover equalizer for your situations. A crossover equalizer is supposed to automatically filter the necessary frequencies to the correct speakers. I have used no name and brand name XverEQs and they both worked the same for me. Along with this response I am assuming you also have Mids and Highs to go along with the woofers.
Nov 08, 2009 | Focal -America FAA33A Car Speaker
2 channel amp to 6-6x9 wiring diagram
Hello magoocsl,
Yes, with the use of 2 high-pass and 1 low-pass crossovers, that Kicker amp will operate in what they call stereo and mono simultaneously (SAMS). You'd run 4 of the 6X9's in mono. Wire them in series-parallel with a low-pass crossover on the positive leg to the amp. The amp would see a 4ω load. The other two 6X9's would be wired as stereo, one to each channel with a high-pass crossover. Again, the amp sees a 4ω load.
Here's a link to the appropriate wiring diagram. The diagram is on page 5. Just substitute your 4 6X9's wired in series-parallel where they show the "mono" speaker.
http://www.kicker.com/sites/default/files/02KX300_400_500_800_2AmpManual.pdf
Hope this helps.
Apr 01, 2009 | Kicker KX500.2 Car Audio Amplifier
Wiring diagrams for installing tweeters and crossovers in a door
try 12voltresource.com or google "wiring diagrams for car audio"
Feb 17, 2009 | Car Audio & Video
How to wire in a cross over
You didn't say if it was active or passive, but here is both:
Passive crossovers are easy to install. By definition, the only type of connections they require are to your speaker line. They typically get installed between the end of the speaker wire and the speaker. Connection should be fairly simple, just like hooking up the speaker itself.
Now F-Mod crossovers modify the audio signal before it is amplified. They accept the patch cord from your receiver on one end, and then plug directly into the preamp inputs on your amplifier. They are also easy to install, and don't require additional wiring.
 An active crossover requires a little more work. You have to connect 12-volt power, ground, and a turn-on lead. The active crossover gets installed between your receiver and your amplifier. A lot of active crossovers have both speaker-level and preamp inputs, so they can usually work with either type of connection. The outputs will be preamp connections to your amplifier. Hope that helps.
Oct 05, 2007 | CTG 2 ft. Stranded Wire Crossover Cable...
Wiring Diagram
Did you get this figured out?
Apr 28, 2007 | Hitron SEQ-554 7-Band Car Equalizer
Focal 165 K3P Car Component System Logo
106 people viewed this question
Top Focal Car Audio & Video Experts
xxxxxx xxx
Are you a Focal Car Audio and Video Expert? Answer questions, earn points and help others
