Home | Uniden | Cordless Phone | Uniden corless phone say...
Uniden Cordless Phone
Problem for Uniden Cordless Phone
Uniden corless phone says Do not disturb on screen
By hottiejess12 on Jan 08, 2008
On my cordless Uniden phone it says on the screen of the hand set "Do not disturb" and we cant hear it ring. This is due to my todler pushing bottons! Please help!
thanks
Comments:
Jan 08, 2008
- please answer cause i need to know asap
Sponsored Links
Same Problem
Sep 06, 2008
-   I di not know why our handsets both say Do not disaturb but I cannot find any reference to this in the manual at all. The other reply for a similar poroblem was to press the dnd button on the master base unit - mine does not have one. The other solution was to remove the battery. Since one of my units is a submersible I dont want to break the waterproof seals unless necessary.
First: how did this happen
Then: How do we turn this off again. The phones will not ring.
-   pauldnz
Aug 13, 2008
-   I had the same problem also caused by my toddler. The 'dnd' button fixed the problem. Thanks!-   Guest
Best Solution
posted on Apr 08, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
On the base unit (not hand unit) there is a do not disturb button (mine is in the lower left corner for the powermax 5.8 Ghz). If your hand unit or chargers are not near your base unit, it's not obvious why your hand unit suddenly says "Do Not Disturb" on it.
Solution #2
posted on Jan 08, 2008
Helpful)
patel352003
Rank: Guru
Rating: 87%, 423 votes
It seems problem of programming. You have to reset it. I can say that if you are enough knowledge of it's initial setup process you may tri by removing battery and again attach it with your phone. This will reset your phone on factory status. You may be loss your data stored but get working phone. Vote it how this fix your problem.
Was this helpful?
Yes
No
Solution #3
posted on Jul 04, 2009
Very Helpful)
sailakfan
Rank: Apprentice
Rating: 100%, 6 votes
On the base unit there is DND button. Just press it. Goodluck
Was this helpful?
Yes
No
6 people thought this was helpful
Solution #4
posted on Aug 30, 2009
Somewhat Helpful)
true7
Rank: Apprentice
Rating: 75%, 1 votes
one of my headsets go lost and when we found it it was dead, after we put it on the charger and it came back on they all went back to normal.
hope this helps
Was this helpful?
Yes
No
Popular Solutions for Uniden Cordless Phone
Questions and Unsolved Problems for Uniden Cordless Phone
Do you recommend Uniden Cordless Phone?
Answer
Answer
my tel is locked . icannot use it b. how can it be reopened????
Answer
how can be reopened one of thecordlessphone??
Answer
when i pick up the phone I can hear myself like an echo and I cannot phone out
Answer
we have tried re-registering our uniden DECT 1580-2 phones many times following the instructions in... (More)
Answer
after i make a call in the middle of talking about 1 minute the phone cuts me off
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Uniden Cordless Phone:
Top Phone Experts
Rank: Guru Guru
Solutions: 1444
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Phone Experts
Top Telephone Repair
(800) 513-9962
Component level repair and complete refurbishing...
BARCLAYENTERPRISESINC
(316) 262-7171
Cctv,Cable Tv Wiring & Outlets,Computer Wiring...
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
