Question about Video Game Consoles & Games
The F1 and F2 on the nintendo ds lite work but the unit does not power on.The L2 also is fine and what other things do you recommend checking to see if it will power on.It is O.K. until the R9,from there on there is no voltage.thanks
  • 3,741 Answers
The ribbon cable connecting to the main board of the unit to the display board needs to be checked.it has been seen that many times F1--- F2--- AND L2 works properly but the ribbon cable gets short and due to that unit stops getting started. -------- also it can be battery problem.if the battery gets drained it will not support.the battery needs replacement in such cases. ----- also click this link directly to get more help http://www.dcemu.co.uk/vbulletin/archive/index.php/t-94191.html -------- This will help. Thanks please keepupdated.please do rate the solution positively .thank you for using fixya.
Posted on Nov 13, 2009
Nintendo wont charge or turns on. F1 & F2 fuses are good.
Check the L2 as well (under the power switch). Replace if necessary.
May 09, 2010 | Nintendo DS Lite Console
Unit won't turn on !
This could be due to several things, the main ones being:
1) One of the screens is either not correctly connected or has devlouped a fault... If one of the screens flickers after you switch it on and just before the green light goes out then the screen that doesn't flicker is causing the problem, firstly try reconnecting it and if that doesn't work you will have to replace it, both screens are avaliable for a reasonable fee on ebay, search for either "DS lite top screen" or DS lite bottom screen".
2) Locate the inductor labled "L2" if this is missing then you will need to either solder it back on if you can find it or else you can buy another one again on ebay for a reasonable fee, search for "DS lite L2".
3) If both the above fail then chances are you have blown a fuse, if you can charge the DS then it is not your "F1" fuse in which case you will only need to replace the "F2" fuse, firstly desolder the old fuse and then solder on the replacement fuse, this should solve the issue. If however the charging light stays on for a very brief time (i.e 1-2secs) then you will have to replace the "F1" fuse, locate the "F1" fuse and follow the sames steps stated for the "F2" fuse. These fuses are also found on ebay, search for "ds lite fuse" and buy the quantity you require.
If you don't have access to soldering equipment or are unable to solder these very small parts (i.e fuse dimensions - 1.5 mm x 0.8 mm and the "L2" inductor dimensions - 2.5mm x 1.8mm x 1.8mm) The is a product called wire glue which is avaliable from ebay (located in the USA) which is fantastic as it is a glue with conductive properties.
You may find guides that tell you to "bridge" the fuses and "L2" inductor but I would strongly advise against this, afterall they are there for a reason and just think what damage would have happend if that fuse hadn't have blown.
Here is an image for the location of the fuses, also if you look just under the power switch you will see the "L2" inductor:
http://www.xdupe.com/assets/images/nintendo_ds/tutorials/ds_lite_fuse/usg-cpu-x3_fuses.jpg
I hope this helps and have to say that I accept no responsability for any damage that may occur to your DS lite when following these tips.
Regards,
SOD69
Feb 07, 2010 | Nintendo DS Lite Console
My Nintendo DS LIte wont turn on!!
Are there NO LIGHTS at all ? Check continuity of F1 and F2 and make sure that L2 (by the ON/OFF switch) hasn't been dislodged. At the very worst you can buy a new motherboard for about £38.00 (~$60 UK).
Sep 19, 2009 | Nintendo DS Lite Console
BLANK SCREEN (BOTH)
You must take your DS to a repair technician to fix it as it would be many things causing the flash on/off cycle.
If you know how to repair electronic devices then check damaged top screen, loosen L2, or blown F1 and/or F2. Or maybe water damage is your problem.
Jun 20, 2009 | Nintendo DS Lite Console
Nds lite wont turn on
There maybe something wrong with the jack inside your Nintendo DS, you can easily get them repaired at a few shops, just tell them that the On/Off switch doesn't turn the DS on and they'll fix it for you, shouldn't cost an awful lot as they're just replacing something inside.
Oct 10, 2008 | Nintendo DS Lite Console
Nintendo DS lite
Baakie,
You turn de DS Lite on, the green light flashes and the unit turned of. Is that correct?
The DS Lite checks some things before he starts-up. One of these things are the screens. the DS sends a signal to it and expect an answer back. When this answer is not received, it shuts down.
The most common problem in these cases is the flatcable of the upper screen.
Question is, did you replaced the housing? If so, you might dammaged the flatcable of the upper screen. If not, the flatcable might be defective because of using the DS Lite a lot (open /close the unit).
So first check the flatcable of the upper screen (google and you will find manuals how to open the DS Lite but be carefull!!!!)
Second, on the mainboard are two fuses (F1 and F2) . Check these! One of them might be defective
Success
Jul 19, 2008 | Nintendo DS Lite Console
Ds Lite not power up L2 Inductor is not good not work.
For the L2 L4 inductor specification, I check the following website, on there have original L2,l4 inductor power and specification
http://www.logictoyz.com/nintendo-ds/nintendo-ds-lite-spare-parts/ds-lite-l2-inductor-power-replacement-.html
By the way,L2,L4 is not fuse,
It is Inductor power
May 30, 2008 | Nintendo DS Lite Console
Video Game Consoles & Games Logo
22 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
