Question about Acer Aspire One PC Notebook
On button wont turn on , the battery light is green but the on button wont turn on. no light is on
  • 2 more comments
  • debby_59 Nov 13, 2009
    the battery light is on with power cord in and battery in, when i take out battery no lights work, but its the on button that wont light up
    the battery is ok i think, the on button wont turn on
  • debby_59 Nov 14, 2009
    nope till dead
    dont know how
  • Acer Master
  • 11,800 Answers
I suppose it's truly dead, no sound at all is coming from it - it's a hardware problem. To test it you will have to open it and check first the memory.
If you aren't very good with the screwdriver (or even worse with computer parts) you should leave that to some repair guy.
Posted on Nov 14, 2009
  • Acer Master
  • 4,806 Answers
Take out the AC power and the battery and then try booting the machine on AC power only. If the machine boots up then let the operating system load up, the shut it down. Remove the AC jack and put the battery back in again, then power it up.
If it boots all is well if it doesn't then there could be a problem with the battery.
Please let me know how you get on and good luck.
Posted on Nov 13, 2009
  • 2,567 Answers
There could e a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
Please let me know whether this works or not so that I could troubleshoot the problem with you further.
  • Mohamed Omran Nov 14, 2009
    Try to reseat the main components of the notebook: the battery, the AC adapter, the memory modules, & the hard drive.
    After that try switching it on & see if the problem was fixed.
Why green light wont come on when put in netural to start
Hi Howard find thd neutral switch on the left hand side near the sprocket it should be a single wire (light green) earth it to the frame or battery and se if the light comes on. If it dose make sure it's in nethral then try to star it. Regards Jim...
May 05, 2015 | Honda 2008 FourTrax Rancher ES
It wont turn on when charging the red light is on for abut 4hours and then turns green i unplug it and it wont turn on ive holding down the volume + and power button and still nothing
tablets are designed to be throwaway.
you can buy new batteries off ebay but replacing the battery will require cutting and soldering as the batteries in these tablets are soldered directly to the board and are stuck in place with glue and electrical insulating glass tape. Not a big job but fiddly and anyone with a soldering iron skill and basic leccie-tronics can do it.
it may be the battery - when you press the power button does the screen flicker or does the green power light come on.
pressing the power button whilst pressing the up or down volume button should take you into recovery mode - do this whilst the power block is plugged in - if the tablet shows signs of life with the power block plugged in you can be sure its the battery..
when tablets are vroken its usually by being dropped and this can cause the screen connector to come loose so you get no display but power lights will still be on.
Apr 26, 2015 | Nabi 2
MPC wont turn on!
Remove the battery and press down the power button for 10seconds and leave for another 10mins, then install the battery and see.
Jan 29, 2014 | MPC Computers TransPort GX Notebook
Vxl 3s turns on when i plug in battery, green light comes on, than red, than blinks through the racing and training modes, wont respond with button push
It sounds like it might just be a case of the button being stuck. The ESC shouldn't turn on just from you plugging in the battery, you're supposed to have to press the button once the battery's connected to power up the ESC.
Programming Your Traxxas Electronic Speed Control
Oct 17, 2012 | Traxxas Velineon VXL-3m Speed Control
Controller wont hook up with console ?
Is this a new controller?
Are the batteries new/recharged?
This is the sequence summary on where you are going to focus:
Step 1 - Controller
Step 2 - Console
Step 3 - Console
Step 4 - Controller
Step 5 - Both
Assuming your controller is a wireless version, Lets start!
Step 1 | Press and hold the Xbox Guide button until the controller turns on. The Xbox Guide button is the round button with the green "X" near the center of the controller.
Step 2 | Make sure that your Xbox 360 console is turned on. If your Xbox 360 console is not turned on, press the power button. The power button is the large round button on your Xbox 360 console.
Step 3 | On the Xbox 360 console, press and release the Connect button. The Connect button is the small round button on the Xbox 360 console.
Step 4 | On the controller, press and release the Connect button. The Connect button is the small button on the front edge of the controller, between the left bumper button and the charging port.
Step 5 | After the Ring of Light spins and flashes one time on the controller and on the console, the controller is connected. The quadrant on the Ring of Light that remains lit indicates the position in which the controller is connected.
Light indicator on console
Green light in the center- power is on
Green light on one quadrant - controller is connected
Four green lights rotating on four quadrants - ready to connect with controller
Light indicator on wireless controllers
No lights - no batteries
Green steady light on one quadrant - connected
Blinking green lights - its either its ready to connect or the batteries are dying
*Make sure that you have a fully recharged rechargeable batteries
*Make sure that you have a functioning/new non-rechargeable batteries
*If the steps above aren't working use another Xbox360 controller and follow the same steps.
If the new/working controller is connecting with the console this means that the previous controller is faulty - needs replacement.
If the new/working controller is not connecting with the console this may mean that the console is faulty - needs repair.
*NEVER TAMPER WITH ANY OF THE TWO AS TAMPERING WILL VOID EXISTING WARRANTY.
Nov 23, 2009 | Microsoft Xbox 360 Console
Wont turn on, new batteries, green light just blinks.
Make sure you are using the correct batteries, and that they are installed correctly. Some cameras require more powerful kinds of batteries and will not work with the cheaper kinds.
A blinking light can mean something is wrong with the power, not enough or something else.
If you have a power adapter or can get one, you may try that, to see if the camera will work without batteries. If it does, then some problem exists in the battery circuit.
Oct 20, 2009 | Samsung S860 Digital Camera
No power
Unplug All External Devices Unplug the AC Adapter From the Wall Outlet. Disconnect the AC Adapter From the Laptop Reseated the power cable to the adapter.
Remove the Battery Connect the AC Adapter Directly to a Known Good Outlet, But Not to the Computer Verify That the AC Power Adapter Has a Solid Green or Blue Light.
The AC adapter status light is solid green. The AC adapter status light is solid green.Press the Power Button and Check for POST. Post means if you see the dell logo,remove the battery, plug the ac if still it wont turn on or doesnt have any light,Reseat the Memory if after reseatting the memory still the same problem it might be a bad motherboard.
Oct 23, 2008 | Dell Inspiron XPS M140 Notebook
MY ARCHOS PLAYER WONT WORK
Just watching a movie and my archos just froze in mid play , did a switch off to rest it and guess what it wont restart , ses ARCHOS in green at the start but wont reeboot have tried the reset button inside but no joy what so ever , any tips or advice 'or shall i just ship it back to Archos ....
Jan 05, 2008 | Archos 605 WiFi Digital Media Player
Acer Aspire One  PC Notebook Logo
50 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
