Question about Apple iPod nano 3rd Generation
I recently returned my Nano. The volume could
I recently returned my Nano. The volume could barely be heard until I brought it up about three quarters of the way from the top level. Nothing could be done to solve the problem. My question is: Is this something that cannot be changed?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Apple Master
  • 1,099 Answers
Have you checked whether there is a volume limit on the nano. Go to settings then playback and then volume limit. From there you can adjust the maximum volume you can have. Hope this helps.
Posted on Nov 13, 2009
Adjust bunn coffee maker water level
To adjust the brew volume/batch size you will need to access the main circuit board behind the front panel. Isolate the machine before removing panels.
NOTE: Check that the brewer is connected to water supply, the tank is properly filled and a funnel and server or decanters are in place prior to setting or modifying batch sizes.
  1. Modifying batch sizes: To modify a batch volume, first check that the SET/LOCK switch is in the "SET" position on the circuit board. If the brewer has a batch selector switch, position it to the size to be changed. To increase a batch size: Press and hold the START or BREW switch until three clicks are heard. Release the switch (Failure to release the switch within 2 secs after the third click causes the volume setting to be aborted and previous volume setting will remain in memory) and press it again one or more times. Each time the switch is pressed, 2 secs are added to the brew time period. Allow the brew cycle to finish in order to verify that the desired volume has been achieved. To decrease a batch size: Press and release the START or BREW switch once for every 2 sec interval to be removed from the total brew time period; then immediately press and hold down the START or BREW switch until three clicks are heard. Release the switch. (Failure to release the switch within 2 secs after the third click causes the volume setting to be aborted and previous volume setting will remain in memory). Allow the brew cycle to finish in order to verify that the desired volume has been achieved.
  2. Setting batch sizes: To set a batch volume, first check that the SET/LOCK switch is in the "SET" position on the circuit board. Press and hold the START or BREW switch until three clicks are heard (this will take approx. 10 secs) and then release the switch. (Failure to release the switch within 2 secs after the third click causes the volume setting to be aborted and previous volume setting will remain in memory). View the level of the liquid being dispensed. When the desired level is reached, turn the ON/OFF switch to "OFF". The brewer remembers this volume and will continue to brew batches of this size until the volume setting procedure is repeated. Empty server(s), turn selector switch to positions that have yet to be set and repeat batch setting procedure until all batch sizes are set.
    NOTE: When brewing coffee, batch volumes will decrease due to absorption by the coffee grounds.
  3. Setting programming disable feature: If it becomes necessary to prevent anyone from changing brew times once
    programmed, you can set the SET/LOCK switch to the "LOCK" position. This will prevent any programming to be done.
    NOTE: If the clicks cannot be heard, lightly grip the incoming water line to feel when the valve cycles on and off.
Jun 22, 2014 | Bunn CWTF15-TC
Volume wont turn up
Resetting the volume limit on your iPod Nano affects everything you listen to, from music to audio books. You can adjust the volume for each individual item on your Nano using the click wheel, but the highs and lows of the sound will depend on the overall volume limit setting. Volume levels will vary with different ear buds and headphones, and using external devices like docking stations to play your iPod Nano will also cause variation in the volume.
Instruction:
1 Press any button on your iPod Nano's click wheel and turn it on. Press the "menu" button at the top of the click wheel until you reach the iPod menu.
2 Select "Settings" from this menu by scrolling down until "Settings" is highlighted, then click the center button.
Select "Playback" from the menu choices that show up.
4 Select "Volume Limits." You will reach a screen with a speaker icon and dots indicating the level of volume your iPod is currently set on.
5
Scroll the wheel up or back to adjust the volume limits. Press the center button and you will have the option to lock in your settings by selecting a four-digit combination lock. This is not a necessary step; you can click on "done" and finish. Setting the combination allows you to have more control over any future changes to your iPod's volume limits. Scroll the click wheel to select your combination. Press the center button and you will revisit the volume limits; adjust it as you like and press the center button.
Goodluck
Dec 10, 2011 | Apple iPod nano
Volume wont turn up on my mp3 - volume too low
How to Reset the Volume Limit on the iPod Nano
Instructions
3 Select "Playback" from the menu choices that show up.
5 Scroll the wheel up or back to adjust the volume limits. Press the center button and you will have the option to lock in your settings by selecting a four-digit combination lock. This is not a necessary step; you can click on "done" and finish. Setting the combination allows you to have more control over any future changes to your iPod's volume limits. Scroll the click wheel to select your combination. Press the center button and you will revisit the volume limits; adjust it as you like and press the center button.
Tips & Warnings
If you set up a combination and forget it, you can reset your iPod Nano and start over again. Resetting will not lose any of your downloads, but you will need to restore or reset many of the settings you initially chose when you first set up your iPod.
Changing the volume limits on your iPod Nano covers everything on your player, but the sound levels for songs, audio books and shows will vary based on how they were recorded.
How do I change the volume on my IPOD Nano. Its too loud and hurts my ears.
  • Press any button on your iPod Nano's click wheel and turn it on. Press the "menu" button at the top of the click wheel until you reach the iPod menu.
  • Select "Settings" from this menu by scrolling down until "Settings" is highlighted, then click the center button.
    hope this help. :)
    Nov 04, 2011 | Audio Players & Recorders
    I have a Lenovo Ideapad. When I try to play audio, nothing can be heard. The mute button is off, the volume level is all the way up. I can hear audio when I put headphones in, but not through the...
    set mouse cursor over speaker icon (bottom-left of your screen), right click and press PLAYBACK DEVICES -- select some options and experiment with the selection you make until you ehar audible sound
    Oct 26, 2010 | Computers & Internet
    The handset lights up and the incoming number is shown but you dont hear it ringing
    Many times there is a volume switch on the actual handset itself. Most commonly on the left side of vtech devices. there are three different volume levels. By pressing up on the button you should be able to turn the volume up until it has an audible tone confirming volume change. Handset should ring with incoming call when audible tone is heard by pressing up on volume button.
    Oct 13, 2010 | Vtech DECT 6.0 Cordless Phone with Digital...
    I have a microsoft VX-6000. until recently it worked fine (video and microphone) on skype & msn, however now the microphone has stopped working. when I go into skype/tools/options/audio settingsand...
    Make sure your webcam mic is set as default
    TEST SPEAKERS
    Right click on speaker icon in System Tray or from Control Panel
    Select "Playback Devices"
    The speaker icon ( checked as working) and volume level graph should be visible
    Right click on the volume graph and click "Test"
    Left hand speakers followed by right hand should be heard
    SET DEFAULT & TEST MIC
    Click "Recording" tab.
    To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
    In lower dropbox display "Use this device enable" click 'OK'
    Click "Levels" tab and ramp up sliders ( adjust to suit later)
    Return to "Recording". Test mic by speaking and make sure volume graph displays
    Restart computer
    Configure to Skype
    Apr 25, 2010 | Microsoft LifeCam VX-1000 WIN-Blk Webcam
    Adio capture is very low
    check your basic audio settings
    Vista
    If you have an earlier OS, you may have to access your hardware from the Control Panel.
    TEST SPEAKERS
    To set required mic as default - click on mic font to highlight and click "Properties"
    In lower dropbox display "Use this device enable" click OK
    Restart computer
    Dec 14, 2009 | Microsoft LifeCam VX-3000 Web Camera
    End of cycle signal is too low
    There should be a switch on the control panel that sets the volume or a 'setup' feature in an electronic control panel. The manual should show how to do this.
    Aug 25, 2009 | Dryers
    Ipod Nano 3rd Generation volume problems
    ITunes contains a volume leveling program that works with every recording in your library or you can select each one individually by going to the library, selecting get info with the right mouse button, select options, and change the volume with the control you see on the screen and press ok.
    Aug 17, 2008 | Apple iPod nano 3rd Generation
    Apple iPod nano 3rd Generation Logo
    66 people viewed this question
    Top Apple Audio Players & Recorders Experts
    Nagendra Baliga
    Computer Repairing
    Computer Repairing
    Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
