Question about Xerox DocuColor 12 Printer
THE MAGENTA COLOR PRINT CLOUDY
HI, MY DC12 PRINT BAD WHEN I PRINT RED OR MAGENTA, ONE SIDE IS GOOD, BUT IN THE OTHER SIDE IT LOOKS CLOUDY AND RED COLOR LOOKS LIKR ORANGE. ANYBODY KNOW WHY? THANKS.
  • Bill kennedy Feb 15, 2008
    I'm having the exact same problem on my machine. The first side of my card stock is fine. When I flip it to run the second side, the colours are all light and "washed out" looking. All of my colos appear this way on side 2 however, not just the majenta based colors. Although those are the worst. I had a tech come in and rebuild the fuser unit and just about everything else. He can't figure it out either. This problem is killing me.
    Problem Solver:
  • 4 Answers
Well I notice on the copier itself there is a heavyweight side 2 and extraheavyweight side 2 option. I ran some card manually from the glass, and it was fine on the second side using those options. The problem is this option doesn't exist when you run from the server. A huge oversight on xerox's part I guess.
The quality is much better when you run an original from the computer. Kind of upsetting.......
Posted on Feb 27, 2008
How do you access developer housing?
best regards,
Rui
Posted on Feb 07, 2008
    Problem Solver:
  • 8 Answers
I one side is good and the other is not ok, the problem maybe in the fuser unit
you must chose heavy eight, not proper pressure on the heat rolls will cause this colour errors that you are descriving.
another solutiuon is to increase the pressure on the fuser rolls, one turn one each side of the screws clock wise.
Good luck
Posted on Jan 10, 2008
    President:
  • 2,072 Answers
My first suggestion would be to change the copy/[rint cartridge.
After that, I would suspect the magenta developer housing is a problem.
That would require a service call to resolve.
Posted on Jan 08, 2008
6ya staff
SOURCE:
I have a Konica C250 machine which cannot print red color at all. I had changed the toner and image unit but still cannot print red color. How can I solve this problem?
Recommended that you have a tech come out and look at it might have a bad LED assy. for the Magenta Image unit. All other color print OK? Can you print gradation test pattern for each color in service mode? Meter count, details, stop 00 stop 01 Test Output Gradation pattern select magenta. If you open the side cover after printing a document with the color magenta try to catch a print of paper do you see the color magenta on the transfer belt if yes the drum is ok could be the transfer belt magenta 1st transfer roller on the belt replace the belt assy.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Oct 28, 2015 | Konica Minolta BizHub C252
Red does not print on one side of the page
I have bad news :( when that happen on this model its because one of the lasers its contaminaded. Dust or toner get inside the unit and block the light of the laser for the magenta causing issues with color that uses red. If you print a configuration report the red look faded in the sides. Changing the cartridge wont fix it. it can be repaired but its expensive. I suggest to get a new model. or if you call HP they can exange it for about $200
Sep 06, 2010 | HP Color LaserJet 2600n Printer
Dc12
Drum Sensore is dirty
Solution
put out first drum & see up side in near ibt belt one sensore (Small Steel Body ) Clear with Alcahol.
Jul 11, 2010 | Xerox DocuColor 12 Color Copier
Xerox dc12, it looks like there is less and less mangenta
Several things can cause that.
A dirty laser window on the Magenta. The Charge may be dirty, the drum is the most likely cause, it would be bad. Or your developer may need replaced.
In order , 1 Laser window, 2 Drum. 3 Charge wire or roller, 4 Developer.
Feb 20, 2010 | Xerox DocuColor 12 Printer
Colour problem
If the printer gives magenta instead of red you have a problem with one of the other colors. Magenta needs other colors to print red. Print a cofiguration print and check witch color is bad or missing. Replace the cartrridge of the missing/bad color
Dec 24, 2009 | HP LaserJet 3000n Printer
I have a used C60. I have replaced both ink cartridges with Epson cartridges. When printing in color, the colors are not accurate. For example, red comes out yellow. Also, there are lines running through...
Hi there. The reason for your problem is that the colour cartridge contains cyan, magenta and yellow ink, plus a black cartridge of course. All the other myriad colours are produced by mixing these four basic colours. So, if you print red, it requires ink from both the magenta and yellow cartridges. Thus if your red produces a yellow print, it means your magenta is not printing. This can be due to a number of reasons, mainly an empty or faulty magenta cartridge or blocked magenta print nozzles.
If you wish me to help you with sorting out the lack of magenta, please post a new comment to this effect.
Mar 04, 2009 | Epson Stylus C60 InkJet Printer
Epson c88 how print in magenta
Do you mean "how do I print text in Magenta instead of black". Well, you change the colour of the text from black to magenta. For example in Word, you would select (highlight) all the text, click on Format, then Font. Then click on the down arrow at the side of the Font Color box, then click on Magenta. To check you have the right colour, click again on the down arrow at the side of the Font Color box, and select More Colors. Then click on Custom. Magenta has a Red-Green-Blue value of 255-0-255. Now print the document and it will come out with magenta text.
If this is not what you want, please come back with a new comment explaining further.
If this advice has been helpful, please rate it.
Jan 30, 2009 | Epson Stylus C88 InkJet Photo Printer
Graininess on xerox dc12 print s
hi i think u took print in low resulution photo. pls check ur phot resulution.
Nov 21, 2008 | Xerox DocuColor 12 Printer
Xerox DocuColor 12 Printer Logo
277 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Clive
Clive
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
