Filter Hi, In my panel the light for filter flash(flicker) and the big filter (I have one in the corridor upstairs) is cleaned and changed. My question is why still flashing ? I have another one somewhere ? My model is : GSC140241A - Goodman 2 Ton 14 SEER R-22 Central Air Conditioner CODE: GSC140241A
  • 89 Answers
Check and see if there is one in the A/H. Look on the right end (return end) There is a panel anout 1" wide going from top to battom. There may be a filter left in there.
Posted on Nov 17, 2009
GREEN LIGHT FLASHING/ FLICKERING BEHIND THE TV SCREEN SONY KDL-40 EX 520. OCCURS AFTER 2-3 HOURS OF TV VIEWING. BUT WHEN CONNECTED TO LAPTOP, THIS NEVER HAPPEN. IS IT A FAULTY T-CON OR MAIN BOARD?
Hi
actually there ia a common mode choke coil problem there are located near LVDS connecter please change these coils & your set become ok there are 6 coils & must change all coils
Oct 09, 2015 | Sony Televison & Video
Flickering lights on 2004 gmc sierra. alternator changed
Hi J, The ground connections are on each of the units. that is to say there is one power feed to the dome and another to the instrument panel. From there each door is separately grounded via each of the door switches. If one is rusted, contaminated or damaged and not operating correctly, it will cause the dome light and the door warning on the instrument panel to flicker. regards John
Aug 13, 2012 | 2004 GMC Sierra
Hi my washing mashine wont spin, and code 0E comes up on sreen and start button starts flashing PLEASE HELP THANKS
That is actually DE. (Drain Error) Open the small access door at the bottom left corner of the front panel. Use the small hose to drain the remaining water out of machine. Unscrew the big knob and pull it out to clean out filter. (If filter was clear, replace pump motor.)
Jan 01, 2011 | LG Washing Machines
Flashing indicator lights
Truthfully it isnt a good sign. Not sure if yours has a reset fascility or not. If it does, reset it....If not, just use it untill it stops working. Make sure when it is running you take note of what is happening like is the water comming in: is the unit washing correctly: does the drain pump operate correctly:does the spin work correctly.(Rectify when problem area is found.)
Jun 15, 2010 | Hotpoint WF430 Front Load Washer
Flickering headlights
Flickering headlights can be caused by a bad alternator, the car might not be charging correctly the battery, check alternator. Good luck
Dec 30, 2009 | 2005 Chevrolet Impala
Amana Touchmatic Heavy Duty Washer Filter Light Flashing
I have the same washer unit and I purchased my washer new in 1989. The flashing filter light is normal. If the light doesn't flash, than the water filter is plugged up. The water filter is self cleaning each time the water empties. You can take off the front panel(two screws at the bottom and the top disengages with metal clips. The water filter in at the bottom on the right, white plastic housing. There is a drive belt from the motor that powers the pump. When the washer goes into the spin cycle, the motor changes rotation direction and the pump works in reverse, thus flushing out the lint that may have been captured during the agitation cycle. I hope this helps.
Mar 14, 2009 | Amana Washing Machines
Filter light keeps flashing
The light flashes after a certain amount of run time. It is a reminder to check the filter to see if it needs cleaning. Once you have checked/cleaned the filter and reinstalled it, press the filter button for 5 seconds and the light should go out.
Jun 18, 2007 | Whirlpool ACQ158XP Wall/Window Air...
Heating & Cooling Logo
37 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
