Amstrad Widescreen TV
I'm having a problem getting the av channel on this tv which is about 5 years old and recently purchased. I#ve tried a DVD player and PS2 console, plugged it into the back of the TV via the red,yellow and white sockets, switched it on, but with no response. I checked with the previous owner and they said when they connected their DVD player it would automatically come on the TV when the player was switched on, but this isnt happening for me and I didnt know if it was a problem with the TV or if there could be anything I'm doing wrong. Thank you
  • 2 more comments
  • joylc Jan 08, 2008
    Thanks Chris, Yes I have the remote and I have pressed the AV channel and on screen it comes up with AV1 or if I press it again it says AV2 and then 3 etc, the yellow phono plug is plugged into the yellow socket at the back of the tv. When I switch on the DVD player it isnt making any differrence to any of the AV channels. Thanks
    Hello, The make and model are : Amstrad Widescreen TV 7128 N, from England, Also the DVD player is a Tesco's Own Brand but I should add that although I have used the DVD player as an example of what I'm trying to achieve, my original plan was to run a PS2 console from it and when it didnt work I then tried the DVD player which I have attached to another TV which functions perfectly. I have also tried attaching the PS2 console to another TV through the AV channels and that also works perfectly, so I have tried various tests and therefore appears just to be the Amstrad one I have a problem with. If you need any further information please do not hesitate to ask, thankyou, Joy
    Ok Chris, I have got an adaptor which I tried aswell into the scart without success but I think I need to double check this out again now I've learnt a bit more, and will let you know.
    Regards
    Joy (Sunny Warwickshire)
    Thank you for all your advice and help, the scart has solved the problem and the PS is up and running, like you said it looks like the phono sockets are not working.
    Many thanks
    Joy
  • 372 Answers
Hi.
Have you got the remote control for the tv set ?
You must put tv on AV channel you can only do this using the remote.
Allso double check that the yellow phono plug is in the socket marked video in on tv set.
Let me jnow how you get on.
http://dysonmanuals.llc.nu/
Chris..
Posted on Jan 08, 2008
  • chris pursloe
    chris pursloe Jan 08, 2008
    Ok
    Can you tell me the make & model number of your tv set this will be written on the back of tv set.
    I allso want the make & model number of your dvd player.
    And what country are you in. I know you might think thats strange but different contries use different types of connections & I need to know what you have on the tv & dvd.
    Regards Chris..
  • chris pursloe
    Hi Joy,
    Ok im in the UK to Gloucestershire.
    Why havent you tried connecting the items using A scart lead ?
    Please try using scart lead just in case there is A problem with the phono sockets on the tv set.
    The scart connection is a rectangular socket approx 2 inches ling with A dog leg on one side it has 21 pins.
    Your tv & dvd should have these sockets.
    Let me know how you get on.
    Chris..
My old Toshiba tv is stuck on widescreen, help..
this a problem with microprocessor signal, this will be difficult for to fix it yourself.
Every signal coming from tv goes to the CPU, you must have high skill for to repair and diagram. I can recommend you to get assistance from some repair shop TV for fix it. see the diagram and you will see the problem difficult.
God bless you
Jul 14, 2012 | Toshiba CF32F50 TV
Hi i have an alba tv , im trying to connect a dvd player. I have connected the scart leads etc.I can not get onto the av channel so i can watch a dvd. Please help
Firstly, please make sure you have connected the SCART cable correctly. This should be connected to a SCART OUT socket on the DVD player to one of the SCART IN or EXT sockets on the rear of the TV.
If you have correctly connected the SCART cable the TV should automatically switch to the AV channel when you switch the DVD player power on or insert a disc.
Switch your TV on, then switch the DVD player off and then on again. If the TV does not change to the AV channel you may have the SCART cable connected incorrectly.
Not all TVs automatically switch to the AV channel when the AV device is switched on. On some TVs the AV input is on channel 0 or 99. On other TVs the AV input is not assigned to a specific channel. On these TVs you need to look for a button marked "AV", "INPUT" or "SOURCE" - either on the TV remote or on the buttons on the front of the TV. The easiest way to do this is to insert a disk into the DVD player and start it playing. Then press the "AV" "INPUT" or "SOURCE" button (whichever one you have) repeatedly until you find the signal from the DVD player.
Please check your connections and try using the "AV" "INPUT" or "SOURCE" buttons. If you are still unable to watch your DVD player, please post back with the following information:
1. Model number of the Bush TV
2. Brand and model number of the DVD player
3. If you are using any remote other than the ones supplied with the TV or DVD player, the brand and model number of the remote.
I will then be able to tell you exactly how it should be connected and which buttons (if any) you need to press to access the AV channel.
Hope this helps. Happy New Year!
Regards,
BElectric
Jan 01, 2011 | Televison & Video
No picture on dvd but picture on tv only sound comes out on dvd
Could you try to set your channel to 2,3, or 5 when viewing video from dvd. Or try search which channel will the video and audio will sync in tune. I think this is an old tv.
Hope this one helps.
Apr 07, 2009 | JVC AV-27530 27" TV
DVD with RCAs, TV with Scart. Have an adaptor but no joy. Why?
The dvd has Y= video composite, R= Right channel audio, W= Left channel audio these are the common jacks of electronics, Now the G=Green,R=Red,B=Blue are usual Component VIDEO OUT/IN for higher video resolutions, this could explain no video picture, try the Y=Yellow to Y=Yellow from dvd to TV then set tv to a VIDEO input 1 or 2
Feb 06, 2009 | Panasonic SA-HE100 Receiver
Can't change our Panasonic TV channel to watch DVD input
Buy a 21 way scart.This will have an 'AV' enable connection built in. After fitting, turn on the TV, then turn on the DVD player. It will automatically enable the DVD through the scart socket.
Nov 10, 2008 | Panasonic CT-32SX31 32" TV
Son pressed something and now DVD won't work
well there could be two things going on here that i can think of, one the scart lead between the dvd and the tv is not i properly vica versa for the dvd player, the other thing is the button which changes the av channels could have been pushed so simply push the button while the dvd os on and find the av channel, the button looks like an arrow going right hope it helps.
Jul 04, 2008 | Panasonic Televison & Video
Setting up Wii with TV
I'm 60 plus years old. Do I connect the AV cables to my TV or to my SAT receiver.
Jun 18, 2008 | Nintendo Wii Console
JVC C2628 model TV
It's a C-2628 JVC TV? And still works after 20 years????? Get it to the JVC museum...Maybe they will trade it for a new model!!!!
Nov 10, 2007 | JVC AV-27230 27" TV
Maxim 1160 (Thomson) 32" Widescreen CRT - no signal
Your going to need the original remote first. then go into the menu and do a channel search on it. if it goes through and finds no channels then the tuners bad. You could have that famous RCA on nboard tuner fault where alot of sheild grounds are bad. This is not a job for the layman. if you cannot get channels by doing a channel scan call out an rca or thompson repair person.
Sep 22, 2006 | Thomson 28VK25US TV
TV PROBLEM
No sir its not just an adjust ment or "twiddling" It sounds like its one of the same as your girlfriends set except a differant part such as a capacitor in the vertical curcuit, Output IC or even a defective resistor?? Good Luck
May 18, 2006 | Grundig GF70-600 TV
Televison & Video Logo
115 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
