Question about ViewSonic N2230w 22 in. LCD TV
I have a ViewSonic N2230w. Recentely the picture motion become very slow. I mean the pictures are blurry, completely unviewable. Sound is ok still. I want to know what is wron and possbile to repair? thank you
SOURCE: ViewSonic TV sound but no picture
I have same problem (power light is on, and I have sound, but no picture ) and found that a small capacitor on back of power supply is blown. Seems to be common problem. But viewsonic doesnt stock. Part number is b-00005352 and im trying to find one too
Posted on Sep 10, 2008
renx
  • 71 Answers
SOURCE: No picture, sound works, but along with high-pitched noise
My guess is that you might have the yellow (video) cable plugged into an audio input on the TV. Make sure that the yellow cable is plugged into both the video out on the DVD player and the video in on the TV. Most of these connections are color coded.
As a diagnosis, try changing the TV input (using the remote) and let me know if you still get the buzzing on the other inputs. If no, then, it's most likely your RCA connections. If yes, it's another problem.
Posted on Apr 21, 2009
ginko
  • 19396 Answers
If an LCD TV has sound but no picture do the following:
Use the source button to ensure that source is not set to the wrong input.
Try unplugging power cord for ten minutes, to ensure it is not a setting problem.
Check all the video cables at the back of TV.
Check Light /Color settings.
If problem persist and does not depend on external receiver or settings, then it is likely an internal fault.
If it has sound but no picture then one of the following parts is faulty, and must be tested and replaced:
Theinverter is the high voltage board that provides variable power to thebacklight lamp. This is the most common. When inverter is faulty youcan get no picture, or a very dim picture that can only be seen bypointing a torch light with a 45 degree angle on the LCD surface fromvery near distance.
The inverter must be tested by reading voltages with a multimeter.
The LCD ribbon cable/LCD display and connectors.
Thisis quite uncommon, but happens. If the TV had been hit or moved the LCDcable may have slipped out, or the LCD connector may be damaged.
The LCD controller board.
Thisis the board that controls the video signal, it is difficult to test,as there is need to read determined values on IC pins. To test thisboard you need to purchase a service manual and follow thetroubleshooting diagrams on service manual.
Input/Output Signal boards.
This are the boards where youconnect the video and audio cables, if a signal board is defective,then you may get no picture on particular inputs located on faultyboard.
If under warranty contact the manufacturer ringing the number on the user manual.
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
Posted on Jul 18, 2009
  • 22 Answers
SOURCE: picture goes away not sound ,hit the back of tv
You need to take the back off the set, with the power off, turn it on, then probe around with a long, wooden chopstick until you find the problem.
Posted on Apr 05, 2010
rulds2008
  • 3866 Answers
SOURCE: Viewsonic N2060w no picture but sound My
LCD backlight has gone out , you can verify this by holding a flash light up to the scene to see image , www.partstore.com or www.shopjimy.com where you can buy the part and put it in yourself would save you money
Posted on Oct 04, 2011
Why is the picture on my Sony KDL-55HX729 blurry? The right side of the screen is light and blurry like its in slow motion and retains the previous screen picture, it fades after a few secondboard may
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Oct 19, 2014 | Televison & Video
I have a Sanyo DP42849 tv and the picture is real blurry almost seems like the picture is in slow motion but the sound is fine. When I shut the tv off it has a good picture for about 30 seconds then it's...
Try resetting, Not sure if this works for your model
Power off the TV, hold down the reset button on the remote and power up the tv with power button on tv while keeping reset depressed.
(Is there a restore factory setting or reset buried in the on screen menu? I couldn't find it in the manual, can you let us know if there is?)
here is the manual in case you don't have it
http://us.sanyo.com/dynamic/product/Downloads/DP42-46849-52449%20(331--)-15947801.pdf
May 15, 2014 | Televison & Video
My tv has a sluggish picture. It almost acts like everything is in slow motion. The picture is very blurry
I already replied, but to add try a reset also make sure any motion settings or noise reduction settings are turned off.
May 15, 2014 | Cameras
My netflix is running slow..the sound and picture don't sync up what causes this?
The problem is that your internet speed is not fast enough from your provider. Call the provider and see if you can move up to faster speed and that will help your problem
Apr 23, 2014 | Netflix
Picture comes out blurry
There are three main reasons for blurry pictures.
Pictures may come out blurry if they're not focused properly. If some objects are sharp and others are not, this may indicate focusing on the wrong subject. This is usually not a major problem with compact point&shoot cameras since they have such a wide field of focus that almost everything will be in focus anyway.
Subject motion. If moving objects blur while stationary objects remain sharp then the shutter speed is too slow to freeze the motion. Try switching to the sports mode, and/or add more light.
Camera motion. This is the most common cause. Set your camera on a table or other stable surface and use the self-timer to take a picture. Take another one while holding the camera. Compare the two on your computer.
Feb 22, 2012 | Canon PowerShot SD870 IS Digital Camera
When i was taking picture the lens of my camera ( sony dsc-w120) become blurd. why'?
The cameras capacity to capture motion pictures is disimpressionful. Usually cameras have feature functionalities either as still picture shoot or motion video recorder devices. Cameras may have any once of the mentioned features or both as complementary for videographic requriements. Inspecte the camera for capacity to capture motion picturee. Usually, the lense capacity with pixel capacities are indication of extensive capabilities. An impressionful camera producign disintergral result requries adjusting the lense or pixles buttons prior to photo shut. Also, cameras that least have the pixel capacity requires photo shoots at still motion or at calm climate least onbracting activities. Capture pictures at areas that least have movement caused by human interfernce or windy or suny blurs. Also, capture pictures maybe retored of blurry filming from computer photo video editor programs. Capture the picture or videos to be loaaded on to a computer that allows editting to achieve desired interfaces.
Feb 07, 2011 | Sony Cyber-shot DSC-W120 Digital Camera
Why are my pictures coming out blurry?
Pictures may come out blurry if they're not focused properly. If some objects are sharp and others are not, this may indicate focusing on the wrong subject. This is usually not a major problem with compact point&shoot cameras since they have such a wide field of focus that almost everything will be in focus anyway. However, make sure the macro/far switch is set to the appropriate position for your picture.
Jun 12, 2010 | Vivitar ViviCam 8025 Digital Camera
Olympus 720 SW blurry
slow the motion of taking the picture...by mashing hard the images in digital camera are always less the desirable
Jun 06, 2008 | Olympus Stylus 720 SW Digital Camera
Screen becomes unviewable
Sounds like a problem with the graphics card or on board video. Please state which one you have and type. The last option is a bad monitor. Try Degaussing it first on the monitors menu selections. If you use a graphics card, you can disable it and try the on board one to see if it helps. If you need further assistance, please ask. I can guide you through all the steps.
Nov 20, 2007 | Computers & Internet
Picture problems
Sounds like a problem in the main power regulator circuit, such as a bad capacitor or regulator IC or transisitor. There are no user serviceable parts inside these sets and every thing is soldered into place. I recomend that you call in a trained service tech to assist you with this repair.
Sep 25, 2006 | Proscan PS50670 50" Rear Projection...
ViewSonic N2230w 22 in. LCD TV Logo
222 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
