Question about HP Officejet 6500 Wireless All-in-One InkJet Printer
HP Officejet 6500 the printer goes into a sleep mode and the wifi will turn off. If you are wired the printer will be reachable 24x7. How to get the wifi to be available 24x7. P.S. Kodak ESP 7 does not have this problem; but other HP printers do have this problem.
  • 295 Answers
SOURCE: esp 7 cartridge resetter and color refill .
no,ink cartridges cannot be refilled .kodak printers dont recognize refilled cartridges and as such,ink price is very reasonable,clear liquid is white coloured ink. no cartridge resetter is available,cartridges are seated in the printhead of the printer
Posted on Jul 27, 2009
  • 295 Answers
SOURCE: reset chip kodak esp 7 ink cartridge
Kodak printer works with genuine Kodak cartridges and that too brand new not refilled cartridges. The brand new cartridges have a certain code that is recognised by the Printer.Kindly buy genuine cartridges as the printer may be damaged by Non comaptible cartridges.
Posted on Sep 21, 2009
nalin_elliot
  • 224 Answers
SOURCE: hP officejet wireless 6500 printer won't print
Yes I will tell you why Kodak photo paper is a little thicker in size and you should not get this same error message if you use hp photo paper or regular photo paper.See of this helps.....
Issue The Out of Paper message appears on the computer and the product stops picking up or feeding paper. Solution Step one: Reset the product
  1. Without turning the product off, remove the power cord from the back of the product.
  2. Wait 30 seconds and then plug the power cord into the back of the product.
  3. If the product is not already on, use the On button to turn it on.
Step two: Check the condition of the paper and reload it
  1. Replace any paper that is ripped, dusty, curled, wrinkled, or bent.
  2. Make sure that all the paper is the same size and type. Because only one type of paper can be used in the product at a time, paper types should never be mixed.
  3. Tap the stack of paper on a flat surface to align the edges.
  4. Make sure that the stack of paper to be loaded in the product contains no fewer than 10 and no more than 25 sheets of paper.
    NOTE: Do not load too much paper in the product.
  5. Insert the stack of paper into the product and gently push the paper guides snugly against the paper. Make sure that the paper is completely inserted into the product and can be picked up by the paper rollers.
  6. Try printing again. If the issue is not resolved, try loading different brands of paper and different types of paper, one type at a time, into the product and then try printing again.If the issue persists, continue with the next step.
Step three: Adjust the paper settings in the print driver The paper settings in the print driver must match the paper settings for at least one of the installed paper trays.
  1. Open a document in the program being used to print.
  2. Click File , click Print , and then click Properties . The product Properties dialog box appears.
  3. Click the Paper/Quality tab.
  4. Choose the appropriate paper size from the Size is drop-down menu.
  5. Choose the appropriate paper type from the Type is drop-down menu.
  6. Click OK and then click OK again to print the document..
  7. If the issue is not resolved, continue with the next step.
Step four: Clean the rollers
  1. Turn off the product and unplug the power cord.
  2. Open the access door to gain access to the rollers. Depending on the model, this is usually the rear access door. See the product user guide for information about locating the rollers.
  3. Clean the rubber rollers with a lint-free cloth, lightly moistened with water.
  4. Make sure that any paper rollers that rest on the input tray, which are located behind the back rollers, are cleaned. A clean cotton swab, lightly moistened with water, might be necessary to reach these rollers.
  5. Close the access door and plug in the power cord.
  6. Try printing again. If the issue is not resolved, continue to the next step.
Step five: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product. CauseAny of the following issues can cause the error message to appear:
  • The paper trays are empty or overloaded.
  • The paper is curled.
  • The print side, or shiny side, of the paper is not loaded in the input tray face down.
  • The paper might not be engaged with the feed rollers.
  • The paper-width guide is pressed against the paper stack too tightly.
  • The paper tray is not completely inserted into the product.
  • The paper settings in the print driver do not match the paper loaded in the paper tray.
  • The rubber paper-feed rollers are coated with dust.
Posted on Oct 03, 2009
Mhinhi
  • 10 Answers
SOURCE: HP Officejet 6500 will not print after sleep mode
Move the printer to a different location and keep it closer to the connected device (e.g. router) and away from large metal objects / other electromagnetic devices for stronger signal strength.
Posted on Mar 01, 2010
SOURCE: Kodak ESP 7 WIFI problems
Today I contacted Kodak about my ESP5250 wireless printer and they said it won't work with the Actiontec PK-5000 because it does not multicast. My old Actiontec wt-701-wg worked fine, but qwest couldn't find any other answer for me for my problems with intermittent stalling of my browser, so they told me my 5 year old modem was too old and to buy a new pk-5000. Same problems. Tonight I contacted qwest to tell them about this problem and they said it is now a known problem, and recommended an actiontec Q1000. Hope they tell the girls in the Phillipines this. Hope this helps.
Jerry
Posted on Mar 26, 2010
I have an HP office jet 4500. How do I turn off the sleep mode? I am having to unplug it everytime now to get it to turn back on.
Sleep mode option for avoid consumption of power which was widely used in high end laser technology to save power. This option is not avail in inkjet technology where that much power not required..Even power saving mode not switch off entire internal functions except fusers/heaters.
Sep 24, 2011 | HP Officejet 6500 Wireless All-in-One...
Tip
Power saving mode officejet 6500 series
did you know that officejet 6500 series doesnt have any configuration about power saving mode (sleep mode).
it will turn to sleep mode after 1 hour.
if it is wireless, you need to turn off/on the product for you to use it again
on Mar 21, 2010 | Office Equipment & Supplies
Can't get the Power Save Mode to turn off
Try looking on the front panel of the printer
press set up button look for Tools or Preferrences then look for power saving mode then turn it off
If the front panel cant have it,connect it directly on a wall outlet not power strip
or more advance
press * and # at the same time then press 1234 consecutively then underware menu should appear on screen
if it does not show you that just keep on doing it until it appears
then use arrow keys and look for sleep mode/power saving mode then set it to 0 or off
Hope I help you a bit.
Your's Truly,
Christian from HP
Mar 23, 2011 | HP Officejet 6500 Wireless All-in-One...
Have an officejet 6500 wireless printer and the printer goes to sleep and wont wake up without unplugging it
Power Save Mode.Just press the on/off button or wait for the printer to wake up when you start a print job.
Nov 07, 2010 | HP Officejet 6500 Wireless All-in-One...
I have an officejet 6500 wireless printer and the printer goes to sleep and wont wake up without unplugging it.
Nov 01, 2010 | HP Officejet 6500 Wireless All-in-One...
How do you turn off sleep mode on the hp officejet 4500?
This no doubt violated the warantee, but I got tired of turning the printer around and unplugging the power cord etc.
So I got a cord switch I had (Ace hardware 31089, others will not doubt work) and installed it in the power cord per directions.
Now it is easy to reach behind printer and cycle the power with the power cord switch and thus wake up the printer.
May 20, 2010 | HP Officejet 6500 Wireless All-in-One...
Why does my new HP Officejet 6500 power light keep flashing about every 5 seconds ????
I thought I had a problem, but it is not a problem. The machine power light flashes when it has not been used in a while and kinda goes to sleep until you start to use it. That way it saves on power. Thanks any way. But before I would pay for help, I would throw the machine away. !!!
Mar 25, 2010 | HP Officejet 6500 Wireless All-in-One...
Jan 17, 2010 | HP Office Equipment & Supplies
The fax auto answer goes off when the 65oo is in
You could try these two suggestions from HP support. The semi-full reset will affect quite a few settings. Perhaps you should copy down these settings for reference later.
HP OfficeJet 6500 Auto Answer
Jan 08, 2010 | HP Officejet 6500 Wireless All-in-One...
HP Officejet 6500 Wireless All-in-One InkJet Printer Logo
278 people viewed this question
Seeker5211
Seeker5211
