Question about Samsung SF-340 Plain Paper Inkjet Fax
Toner ink-m40 with pb3 work ok, but with pb4 they dont work
Is hp 901 ink cartridge ok to use with dell printer
No, Dell printers are only designed to use their own ink. But I have attached a website to where you can purchase dell ink. Also I'm going to attach a way to receive discounts on ink purchases! Printer Ink Toner Printer Supplies Staples Rewards members earn 2 back in rewards for each ink or toner...
Oct 02, 2014 | Dell Office Equipment & Supplies
Eht price samsung FOV17L002
I have had a play with one of these....
I Used 2G mem card, formatted to FAT32
Video format 470 x 270 (16:9)
Frame Rate 25 Fps
Compression = XVID
Audio MP3 22Khz (128kbps)
Name file VideoA.avi for trigger by PB1 connector
Name file VideoB.avi for trigger by PB2 connector
Name file VideoC.avi for trigger by PB3 connector
Name file VideoD.avi for trigger by PB4 connector
Name file VideoE.avi for trigger by PB5 connector
Not sure how to copy the video into the screen, but mem cards are so cheap, it's not really a problem ;)
Have Fun :)
Nov 28, 2013 | Computers & Internet
Need information on a dt070-bt-p lcd
Frame Rate 25 Fps
Compression = XVID
Have Fun :)
Mar 21, 2013 | Computers & Internet
Toner empty
try to shake the toner after removing it if there is still remaining ink left. If non, replace the toner to its nearest Printer provider outlet
May 11, 2011 | Office Equipment & Supplies
Refill ink.
First understand, that your Laserjet uses toner, not ink. Usually, the best answer is to purchase a replacement toner cartridge. I buy from the aftermarket, as the HP brand can be expensive. I think this is your best solution.
Jun 03, 2009 | HP LaserJet 4L Printer
HAVE PUT TWO KNEW HP INK CARTRIDGES IN (MAGENTA)AND PRINTER SAYS (MISSING OR DAMAGED BUT THEY ARE NEW ONES. IT ALSO SAYS REFER TO PRINTER DOCUMENTATION ..I DONT KNOW HOW TO
1) NEED TO KNOW WHAT MAKE AND (MODEL) OG LASER JET THIS IS BUT MOSTLY THIS KIND OF TROUBLE IS CAUSED BY A BAD CHIP ON THE TONER CARTRIDGE OR THE SENSOR IN THE BACK OF THE PRINTER IS BAD OR BROKEN.
THE MAGENTA AND THE YELLOW ARE THE MOST COMMON
Nov 04, 2008 | HP Office Equipment & Supplies
Refill Toner Cartridge for Laser Printer
Nobody has a clue how to refill a laser cartridge with ink. :)))
OK< just kidding, here it is:
First of all, laser-cartridges have toner (a fine black powder) and not ink.
Second: There are 2 methods to refill a laser cartridge: dismounting it to get to the toner chamber (involves a lot of tehnical skill) or the melt-and-pour method (see here http://www.urefilltoner.co.uk/), but you need the melting device.
But because from your question i see you dont know a thing about refilling, better go to a refill center.
Feb 14, 2008 | HP LaserJet 1012 Printer
Samsung SF-340 Plain Paper Inkjet Fax Logo
16 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
