Question about ACCO Brands Rexel 3150 Shredder
No instruction manual - orange light on which shows "door open/paper full - done!" Still no go. What do I do now?
  • 1,294 Answers
Clean the exit paper sensor and restart the shredder.
Posted on Nov 14, 2009
My hp laserjet 1300 printer shows blinking the orange light instead of the green one and I couldn't find out what is the reason
1. Go light/button blinks twice with solid green and orange lights
2. Green light starts blinking with go light twice and then both go off
3. orange light goes off.
4. green light followed by orange light followed by go light cycle twice and a third time by the green light
5.followed by the orange light continuously blinking.
I have already tried the following trouble-shooting:
1. Put in a new cartridge
2. Made sure there is paper properly seated in the tray
3. Made sure all doors closed (I even took off left side to verify no memory cards
4. Verified all doors closed
5. Done a cold reboot by holding the Go button while turning the unit on.
6. Repeated steps 1-5 multiple times.Hope It's resolve all Your Printer Problem,
Or
Still having Problem Then follow Us For HP Support
Mar 06, 2014 | HP LaserJet 1300 Printer
Paper jam showing red light
did you get a full sheet of paper back out when you removed the jam? If not there is still a small piece of paper in the machine. You will need to get a flashlight and look carefully in the center of the path from where the paper starts (the paper tray) to where it comes out when it is done. if you cannot find any do this: best if you open and close all doors and lids. even the doors behind the printer if there is one. If that does not help try this: Turn off the printer, unplug, count to 10 then plug back in and restart. If the light is still on then light is saying a sensor is seeing a piece of paper or thinks it does. It is possible while you pulled the paper out you pulled a sensor flag out of its holder. By pulling the paper out opposite the paper moves through the machine can cause this. always try and remove a jam with the flow of paper, in other words the same direction the paper travels not backwards. Once fixed can prevent this failure in the future.
Jul 10, 2012 | Xerox Phaser 3117
Orange light blinking, cleared paper jam, changed printer cartridge, won't print subsequent documents.
Double check all doors/ rollers for small pieces of paper stuck in the rollers. Sometimes just opening the door in question and closing will reset the paper jam sensors. Paper jams can be smaller than your pinky finger nail. So double check,
Comment if it still isn't working.
Oct 21, 2011 | HP Deskjet F335 All-In-One InkJet Printer
My HP LaserJet 1320 is showing an Orange Light ( Exclamation mark inside the Triangle) and i could not make any printing... It's keep showing that problem after restart the Printer. Can anyone give me some...
if the light is blinking it means
1. either the cartridge door is open
2. or paper tray is empty
3 or paper is misfeed
4. or paper jam
Verify that the print
cartridge is present and
that the print-cartridge
door is closed correctly.
2. Verify that media is
present in the input tray.
3. Clear any jams and
perform paper-path
functional checks.
4. Make sure that the
interlocks are operating
correctly.
Jan 12, 2011 | HP LaserJet 1320 Printer
Light kee flashing orange/green and says computer is busy when there is nothing in print queue
FLASHING ORANGE LIGHT ERROR MESSAGES
Try counting the number of orange flashes.
* two flashes means you’re out of paper or the paper is not feeding correctly.
* three flashes means there is a paper Jam or the output tray is closed.
* four flashes means the ink tank is empty
* five flashes means the print head is not installed correctly or not installed or is defective (before buying a new print head always try the cleaning instructions at the end of this post first.)
* six flashes means the inner cover is open or not closed properly.
* seven flashes means you counted wrong.....
* eight flashes means the waste ink absorber is almost full or full.
* nine flashes mean that a digital camera or video that is connected is not compatible with the printer. If a specific amount of time lapses without getting a response from the digital camera or video camcorder this will happen.
* ten flashes means it can not print to both sides of the page
* eleven flashes means the automatic print head alignment failed. (this can be caused by low ink levels, ink tanks not being installed correctly, the print heads being clogged. It can also be caused by the paper output slot being exposed to a strong light source (Press the resume /cancel button and move the printer to a darker location and try to align the print head again.
* check to make sure the lock lever is correctly positioned (down)
If the above does not work, align the print head manually by opening the printer properties dialog box and clicking the maintenance tab and then select the print heal alignment button on the left side, second row down.
Mar 29, 2010 | Canon BubbleJet i320 Printer
My is not working & shows an error code B200.
Mar 25, 2010 | Canon Office Equipment & Supplies
The orange light keeps flashing
Mar 22, 2010 | Canon I990 InkJet Photo Printer
HP LaserJet 1200 series
Hi vgde2004: Here are some things to check.
1. The printer is in manual feed mode.
Possible solution: Change the manual feed setting in "printer properties"
2. The door is open,the media is out,the toner cartridge is installed incorrectly,or the paper is jammed. Check paper path.
3.Fan error
Solution:
1. Check fan cables for looseness.
2. Replace fan assembly
Dec 15, 2008 | HP Color LaserJet 3500 Printer
All the light are red
1)either the toner is empty or not fitted properly. 2)either there is a minor paper jam or any small piece of paper is blocking the gears to move. 3)or the printer door is slightly opened or not fitted properly.
Aug 13, 2008 | Brother HL 5150D Laser Printer
ACCO Brands Rexel 3150 Shredder Logo
299 people viewed this question
Top ACCO Brands Office Equipment & Supplies Experts
jasbo
jasbo
Are you an ACCO Brands Office Equipment and Supply Expert? Answer questions, earn points and help others
