Question about Westinghouse LTV-27w7 7 in. LCD HDTV
I have an intermittent problem the set will be working fine when suddenly the screen is full of multicolored moving veritcal lines. This condition may last for just a few seconds or as long as an hour+. When it stops the TV runs normally.
2 Suggested Answers
jerryg50
  • 1689 Answers
SOURCE: screen is black but there is sound
It is possible that the backplane lamps and or the ballast supply is in failure. It is also possible that the main power supply is having a fault condition, or there is some other area that is shorting and causing part of the power supply to go in to protect mode.
The set should be checked out by a service tech who knows the set, and has the necessary resources to service it.
Jerry G.
Posted on May 16, 2008
Vizio TV has a horizontal 2mm black/multicolor line.
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jul 27, 2016 | Vizio Televison & Video
Veritcal lines - different size - distorted
Main digital board has the fault. As set is new one, it must be under warranty period. Get this set repaired by the authorised service center before the warranty period expires. Otherwise you might have ot spend for the cost of the board + service charge. The board can't be repaired. It must be replaced as card basis.
Jul 09, 2012 | RCA 42LA45RQ 42 in. LCD TV
I have a Samsung LNT4066F. Multicolor lines then normal.
Had this problem occcured after opening of the set or by itself. If so please checck on the shielded connections of the power board. Please make sure your power outlet is working fine and there is full voltage on the input to the power board.open the set carefully by unscrewing the rear panels. Look out for any loose/dry solder joints inthe power board.Use a good low wattage soldring iron to solder suspected joints.Keep the power off and be careful to see that you do not attempt to touch the main capacitors which could have high voltage stored. Next you need to check the drive to the panels, check from the transformers for loose / dry connections, if so resolder. once you have finished, close up the panel and test. If htis wont solve, test the voltages in the power and the drives, the fault appears to be some dry points so look carefully with patience. I hope this advice helps you out. Good day
Jul 07, 2010 | Samsung LNT4066F 40 in. LCD Television
Multicolor vertical lines on one third of screen?
Unfortunately TV's aren't built to last anymore...once LED sets came out the life of them dropped in half over what they were 10 yrs ago.. 2.5 yrs isn't that far below average anymore. .There is a good chance you have Tcon board issues, you can try the old trick of cooking it in your oven and see if that helps since it started out as intermittent or would work for awhile and got worse but only about 20% at best of the time that works, you can find instructions on how to do it on youtube if you want to try, it won't hurt anything but chances are it won't fix it...next step is buy a tcon board but there are other things that could cause it , tcon would be where I would start
Dec 10, 2017 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Screen Problems with HP laptop
i think it is under of waranty. it look likes your graphic card or emmeded chip is down. need to get service.
May 27, 2009 | HP Pavilion dv6000z Notebook
Rainbow line will come across screen and then goes blank. This is an intermittent problem. Normally if I turn it off and back on, it works. Now it does not.
try resoldering the vertical output IC, the IC runs at a hot temperature and this can cause the Pins to have cracked solder.
May 23, 2009 | Mitsubishi WT-46807 46" Rear Projection...
Phone screen goes blank to a grey color (externallY) .
same problem, broke my screen, ordered a new screen off ebay and replaced it. now it works fine most of the time but sometimes external display freezes. sometimes goes black, sometimes goes multicolor pixelated (full screen, in blocks, or lines) when this happens sometimes touchpad still works, others not. removing battery usualy temporarily fixes.
Mar 09, 2009 | LG VOYAGER VX10000 Cellular Phone
Hitachi 51GWX Scrambled Picture
STK392-560 STKS convergence CHIPs Replace both of them.
Feb 24, 2008 | Hitachi 51GWX20B 51" Rear Projection...
Westinghouse LTV-27w7 7 in. LCD HDTV Logo
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
