Question about Frigidaire Electric Dryer
My creda t622cw dryer had no heat so I have replaced the thermostats, but when I tried it there is heat but the heating element gets very hot and turns red, is this normal or do I need to replace this as well?
  • Frigidaire Master
  • 3,463 Answers
The fact that the element gets red hot, shows that there is nothing wrong with the element, it will get red, more so if you tried it without a cover or panel over it, as normally the fan blows the air over the element, make sure the drive belt is o/k, and the drum is turning.
Please rate my solution.
Thanks.
Posted on Nov 13, 2009
Testimonial: "thankyou i did try it with the panel off, there are four metal strips should they all get red?"
  • Barry Coates
    Barry Coates Nov 13, 2009
    They will not all neccesserily get red, but as long as they are getting hot, then it is o/k.
I have samsung dv220aew/xaa dryer, that gets too hot and kicks code HE. New element, thermistor and cleaned thoroughly. Gets hot, codes on all heat settings. Any ideas?
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
Apr 21, 2015 | Samsung Dryers
What could be causing inside of the drum of my AD55 F&P dryer to very hot?
see this causes and fix it. God bless you
Blower Wheel A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
Felt Seal Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Cycling Thermostat Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Air Flow Problem Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Heating Element Assembly A defective heating element assembly can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element assembly to inspect it. The coils should not be touching each other or anything else.
Heating Element A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Sep 28, 2012 | Fisher and Paykel Dryers
My creda simplicity t622cw condenser dryer wont turn
Broken or belt has come off. If can open back and fix or replace. You may need to remove the top. Careful of the heat element, lift out drum and place new belt on motor holding it while you put the drum back keep hold of belt and place around drum replace top and should be ok. Hope this Helps
May 25, 2010 | Dryers
How to fit creda thermostats
It depends on which make and model of tumble dryer you have as to how easy it is to replace the relevant parts. Some tumble dryers have heating elements that are easily accessible by removing the back panel, and can be tested for continuity or checked for obvious burning out or open circuit. Others though have their heating elements inside, which aren't accessible without stripping the dryer down we will try and cover as many as possible in or video tutorials section. Tumble dryer heating elements are always protected by thermal fuses and thermostats which are usually simple devices with 2 wires connected and have a bimetal strip inside them. They can be tested for continuity with a test meter.
The problem is that if a stat (thermostat) or t.o.c. (thermal overload cut-out) has gone open circuit, it may be for a reason. Overheating could have caused it by not being able to vent the air due to a blockage some ware. Blocked filters or even the machine not being allowed its ten minute cooling down period, Overloading can cause it as well. Sometimes they can go for no apparent reason. A blocked or severely kinked vent hosecan also cause overheating.
You-Tube video "ymXmpyVkxIE" placeholder (do not delete)
Jan 02, 2010 | Dryers
Creda dryer not heating fitted new element but still no heat
If you have not replaced the thermostats, then I would suggest that you do so, as .it is usually the stats that cause the prob.
Thanks.
Aug 14, 2009 | Dryers
Creda Reversair Sensa Dry Tumble Dryer produces no heat.
There is only 1 heater element, and normally one thermostat.
they are located at the rear of the m/c, behind a removable panel.
If you are not sure whether it is the element or stat, join the two
wires togeher that go to the stat, if the heater then works, replace stat. if no heat, replace heater.
plz leave feed back for this solution.
Thanks.
Dec 17, 2008 | Dryers
No heat in tumble dryer
Is this a gas dryer, if so check the thermal fuse, should be white plastic with 2 wire ports. These tend to bad first. Thanks Dave www.washermd.com
Dec 16, 2008 | Whirlpool GEW9250 Electric Dryer
Tumble dryer wont dry
hi do you have any blockages in the vent system (lint) can you hear the fan running and are the filters clean.did you put it back together correctly.hope this helps.
Mar 05, 2008 | Dryers
Thermostat wiring diagram for creda t622cw
I assum there are four wires, you really cant get them wrong as they are all Neutral wires so it won't go of bang, it just may not heat as it should, I would connect them as you think it should and try them.
Dec 02, 2007 | Dryers
Frigidaire  Electric Dryer Logo
452 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
