Question about Tascam DR-1 MP3 Player
Navigation ring came off
The ring you use to scroll through the menu items came loose and stopped working. If I hold it down, it works. It seems like there should be some kind of clip or screw from the back side that holds it in, but nothing is apparent. When I turn the unit over, the ring falls out in my hand. How can I reattach it?
The scroll wheel should click into place if you push on it. There are small plastic ridges around the inner hole of the scroll ring that act as clips. If these ridges are worn down, it will no longer click in. The DR-1 is a good recorder, but cheaply constructed.
Posted on Jan 17, 2010
How to reset blackberry 9320 to factory settings
1. Find "Security Wipe"
  • Press the Menu key twice.
  • Scroll to Options and press the Navigation key.
  • Scroll to Security and press the Navigation key.
  • Scroll to Security Wipe and press the Navigation key.
2. Restore factory default settings
  • Highlight Emails, Contacts, etc., User Installed Applications or Media Card and press the Navigation key.
  • When the box next to the menu item is ticked (V), the selected data will be deleted.
  • Highlight the field at the bottom of the display and key in blackberry
  • Scroll to Wipe and press the Navigation key to restore the factory default settings.
  • Follow the instructions on the display to set up your phone and prepare it for use.
Jul 25, 2014 | Cell Phones
Why won't the number 1,0 and space bar button work?
Have you tried a battery pull...... restart by removing the battery while your device is Powered On , try it and see if you're able to access your keyboard . you can try factory default to reset phone ...When you restore the factory default settings, all personal settings are reset. Follow these instructions to restore the factory default settings.
All phone data will be deleted. Data on your SIM isn't deleted.
  • Highlight Emails, Contacts, etc., User Installed Applications or Media Cardand press the Navigation key.
May 13, 2014 | RIM Blackberry Curve 9320 Smartphone -...
Can i stop the alcatel one touch 665 from playing a tone when i open and close the clamshell
Goto Menu then Profiles you see a red dot on General. Press options on lower left of screen and Edit. scroll down to Flip Beep and click it then scroll to Silence and press Select on lower left of screen. It worked for me.
Nov 20, 2011 | Cell Phones
Cannot change the language to english it is currently japanise
looks like you have to reset it
to do that slide the hold button to hold and then back
then press and hold the menu and the center buttons at the same time for about 7-8 seconds until the apple logo shows on screen
if after resetting, the language is still Japaneses, then do this
Scroll down to the last menu option but don't select it.
Scroll up one menu item. This should be Settings.
Press the Center (Select) button. This takes you to the Settings menu.
Scroll down to the last menu option but don't select it; in English, this is the "Reset All Settings" option.
Scroll up to the third menu item from the bottom one. This should be Language.
Press the Center button to select Language.
Select your preferred language from the list.
Jul 18, 2011 | Audio Players & Recorders
I have a apple ipod A1199 my little brother got a hold of it now its in some forien language that i cant read how do i get the menue to read american again?
No problem, you'll just need to do a full reset to restore the language to English.
1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. Try resetting the iPod while it is connected to power.
Feb 28, 2011 | Apple iPod Photo MP3 Player
Screen displays empty data base and cannot be re tuned
This sounds like a software glitch, you could try a factory reset, but you do so at your own risk. Here's how:
On top of your tv there is four buttons...
1...Turn your tv off
2...Hold down TO THE LEFT the volume button and the CHANGE CHANNEL button.
At the same time hold down the AV select button (round button)
3... Now press the tv ON button KEEP ALL THE BUTTONS DEPPRESSED untill the TV turns on...
4... By now the screen should have come on with a engineers menu on.
5... Using your remote scroll up and down the menu using the ""P"" button...on the menu you will notice items saying RESET..click either ""OK"" OR using the navigation buttons on your remote (thats the 4 surrounding the ok button"" press the right arrow then press ok.
6... Scroll through all of the pages ALL 11 of them and reset them all.
At this point your tv on/off button may not work..simple turn off at the socket and everthing should have been reset.
Now turn your TV off then back on again.
Hope this helps
TV_Doctor
Jan 05, 2011 | Sharp AQUOS LC-32D44U 32 in. LCD TV
I need to change the lanuage from japanese to engish on a ipod and I know absolutely 0 japanese
If you have an iPod nano or Fifth Generation iPod (iPod with video):
  1. Scroll down to the last menu option but don't select it.
  2. Scroll up one menu item. This should be Settings.
  3. Press the Center (Select) button. This takes you to the Settings menu.
  4. Scroll down to the last menu option but don't select it; in English, this is the "Reset All Settings" option.
  5. Scroll up to the third menu item from the bottom one. This should be Language.
  6. Press the Center button to select Language.
If you have an older iPod with color display (including iPod photo)
  1. Scroll to the fourth menu item in the screen and press the Center (Select) button. This takes you to the Settings menu.
  2. Scroll down to the last menu option but don't select it; in English, this is the "Reset All Settings" option.
  3. Scroll up to the third menu item from the bottom one. This should be Language.
  4. Press the Center button to select Language.
  5. Select your preferred language from the list.
If your iPod has a monochrome display (black and white):
  1. Scroll to the third menu item in the screen and press the Center (Select) button. This takes you to the Settings menu.
If the instructions above don't enable you to change the language on your iPod, try using the "Reset All Settings" option at the bottom of the Settings menu. If the Reset All Settings option does not work, you can restore your iPod back to factory condition and reselect the display language.
Apr 29, 2010 | Audio Players & Recorders
Toll saver does not work. Ring count set to 4 rings
"2 rings" or "4 rings" (the default) are not "toll saver". You need to set the ring count to “toll saver”.
On the handset
1) Press Menu
2) Scroll down to Answering Device then press menu
3) Scroll down to Settings press menu
4) Scroll down to Ring Count press menu
5) Scroll up to “toll saver” and then press menu
Feb 05, 2009 | Panasonic (KX-TG1032S) Phone
Wickedwahine
This may be an intermittant on the circuit board or the switch assembly inside of the camera. Was the camera dropped?
I would not suggest trying to fix this yourself unless you have experience in this type of service and have spare parts.
Jerry G.
Jan 02, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Wrong language on ipod
This is simple but good to know.
Select your language.
  7. Select your preferred language from the list.
-----John
If that doesn't work go to: http://support.apple.com/kb/HT1824
Nov 24, 2008 | Apple iPod nano
Tascam DR-1 MP3 Player Logo
96 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
John
John
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
