Door locking dE flashing
The wasing machine door doesent lock and it flashes dE
  • maeria Jan 08, 2008
    thank you for such a quick respnse
    The make and model nos are
    Direct Drive 7.0?3.5kg WD-121126RD
    it sometimes locks though
  • docevil13 Apr 02, 2008
    hi my name is Andrew,
    i have a creda excel 1200 w220vw washing machine,
    this was a second hand machine i acquired and wont start, the run light is light but the door lock light continually flashes,all the other lights work rinse hold and energy save works,i was wondering if i need to replace the door catch sensor or door clip ,also can you tell me where i could find a front bottom plate or what the right name of part is and where i can obtain the parts needed
What a quick response thank you .
The make and model no is
Direct Drive 7.0/3.5kg WD-121126RD
Posted on Jan 08, 2008
    Scholar:
  • 196 Answers
This generally refers to a locking latch not operating. I would need the make and model number to further assist you.
Lg washer wm2455hw door won't lock. DE code flashes.
LG Washer Door or Lid Won't Lock - Model WM2455HW ...
www.repairclinic.com/...Washing-Machine/...-/LG-Washer-door-or-lid-...
LG washer door or lid won't lock? Use our DIY troubleshooting & videos. Then, get the parts you need fast. Return any part for 365 days.
Nov 15, 2015 | LG Washing Machines
Bosch Maxx6 washing machine. Shut door,rinse button flashing but door not lock so start button will not start circle
look at the place where the lock locked in the door the metal pinns could be broken or covered with erosion or something. De door lock makes no contact with the receptor.
Mar 04, 2015 | Bosch Washing Machines
Where is located sensor of. Fuzzy logic t7517tepto
dE
Washing machine door detected as being open Door open error code can also be displayed as "dOE"
Very simple error, the fault code indicates that either the door is indeed open or that the door lock or door interlock mechanism cannot inform the electronics that the door is properly closed. LG door locks are known to and do commonly fail, the common one used in most LG washing machines and washer dryers can be found here with a link to a lower cost alternative part. However the door handle (can be found here) is also a common source of trouble and, if the catch doesn't engage into the lock properly you will get this fault code being displayed.
On non-display panel models this fault code is denoted by the light for the door lock being lit or flashing.
  • Check door is closed correctly and latched
  • Check door handle for damage or wear
  • Check door safety lock if inoperative replace door lock
  • Check door lock wiring
  • If there is a clicking sound once or twice when the Start/Pause button is pressed the main control board may be faulty
Dec 10, 2014 | Washing Machines
Wont start machine error come up
Door open error code can also be displayed as "dOE" On non-display panel models this fault code is denoted by the light for the door lock being lit or flashing.
Apr 08, 2014 | LG WD-1280FHD Front Load Washer
Washing machine flashing de
We normally need to know the make and model to diagnose what the fault codes are- different makes, models (top or front loaders), different decodes but this time your luck is in!
'dE' stands for 'door Error' indicating that there is a problem either with the lid/door lock or the lid/door locked sensor requiring a service call, sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Sep 12, 2011 | Washing Machines
When starting the washer it flashes dE several times - then starts it;s wash cycle
As you do not mention the make and model I am guessing that 'dE' stands for Door Error. It thinks the door is not closed. It could be the lock itself or the door lock sensor is malfunctioning and requires checking/adjusting (if that is possible on your machine).
John C
Mar 03, 2011 | Washing Machines
Washer flashing dl on the screen
"dL" indicates Door Lock Failure: dL flashes if the following conditions occur:
Door lid is not closed completely due to interference.
Wash media buildup is preventing the lock bolt from extending.
Machine/motor control detects open door lid switch when attempting to lock.
Machine/motor control cannot determine if door lock is in a locked state.
Check for lock interference with lid or lock bezel
Dec 14, 2008 | Kenmore Elite 45986 Front Load Washer
Flashing
revisar el nivel puesto que las lav tienen un sistema de anti bibracion que el cual la detiene
Aug 05, 2008 | Washing Machines
Washing Machines Logo
94 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
