Question about Philips Senseo HD-7810 Coffee Maker
Turned machine on this am,power light came on for a few secs,then went off...cannot turn on use my senseo every day...please help
  • 24 Answers
Try another wall socket, and fumble a little with the wire - it may have been damaged. If you can notice a relation between moving the wire and the Senseo switching on and off, the wire should be replaced.
Posted on Oct 28, 2010
Senseo will not turn on or heat water
No need to see what is in the manual.
But what I type here, you also have to read.
The manual gives pictures. I'm not.
Remove the transparent back of the machine and fill it with water. a few centimetres under the top, you fine the line for max fill.
Then replace the transparent back on the machine. Then plug in the power cord and press the power on button. (once is enough) a light comes on and flashes, when the mains plug has power.
Then wait till the light stops flashing. In the mean time put a coffee pad in the top and close the top all as described in the manual.
Place one or two cups under the nozzles and press the button with the one or two cups. (two cups gives twice as much water, so place two cups.
That is all.
Jul 21, 2014 | Philips Senseo HD-7810 Coffee Maker
Philips Senseo HD7810 /40 stops midway brewing
This lookes like a problem I experienced with another model of the Senseo. The problem here was the 470nF X-capacitor in the capacitive power supply. (230VAC models) Try replacing.
Aug 15, 2013 | Philips Senseo HD-7810 Coffee Maker
Dear Madam, dear Sir, I tried four times to descale my coffee machine with Philips Senseo Descaler; nevertheless, the "calc" lamp is still on. What else can I make? With cordial...
Hi. Sounds like a sencor is faulting. Try unplugging it from the power for a few minutes, then start it back up. If you dont have water coming out the your boiler maybe blocked. Id need more information to suggest anything else. Dazza REPAIRER
Sep 24, 2011 | Philips Senseo HD-7810 Coffee Maker
I have cleaned my senseo , but the red light still is on. what do i do next?
Do not turn off the machine until all 4 cycles are complete (2 descaling & 2 rinsing ). The machine will then switch itself off. This is not properly explained in the instruction booklet.
Aug 25, 2011 | Philips Senseo HD-7810 Coffee Maker
How do I prime an old machine that's been sitting in my cupboard for awhile??
De-mothballing a Senseo check-list:
  • Get some citric acid & prepare it as prescribed,
  • Fill the Senseo's reservoir with the citric acid suspension,
  • Place a large bowl underneath the coffee outlet,
  • Press and hold both small buttons, and
  • Press the Power button.
The citric acid suspension will now be pumped through the machine, into the bowl. To stop the rinsing, press the Power button again. I suggest you repeat this a few times, don't forget to swap the pad holders somewhere in between so they both get some suspension as well.
After that, repeat the procedure a few times with fresh water only to get rid of any citric acid in the machine - it will make a poor cup of coffee if you forget that step!
Jun 19, 2010 | Philips Senseo HD-7810 Coffee Maker
Senseo won't turn on after running vinegar thru it to clean.
If it doesn't respond at all then make sure the plug is in the wall socket and the wire isn't damaged. If it's plugged in properly, the wire is intact and other electrical appliances work OK when plugged into that same wall socket, the macine will need some tender love and care from a mechanic.
May 14, 2010 | Philips Senseo HD-7810 Coffee Maker
Robinair 34788. I need help. I have had my machine for 1.5 years and has served me well. A few weeks ago, I realized the machine was able to use database cartridges. So, I bought them. I put one in, turned...
I did this once; did you insert the cartridges with the machine plugged in?
Don't worry! just replace the circuit protection fuse on the motherboard.
on mine it was located under the rear screen cover. hope this helps!
Jan 12, 2010 | Robinair Cool Tech 34700Z Recovery,...
Pump is not working
The reason could be the following.
You used your machine on a mains working with 50 cycles/sec. In U.S. frequency is 60 cycles /sec. this could alter the working of the oscillating piston in the pump. The impedance of the coil is somehow about 20% higher on this mains, reducing so current and power of the pump.
To be quite shure of this, try to fill the pump thoroughly with water.
(Disconnect machine from mains, use Low pressure hose , max 0,5 bar, tied to the inlet -where the water tank feeds-, and fill until water comes out of the open hood)
If now the same humming persists an no pumping effect is noticed, i even will be a bit wiser knowing that 60Hz is not good to 50 Hz pumps.
Jan 04, 2009 | Philips Senseo HD-7810 Coffee Maker
Mitsubishi WS-65313 - Will not turn on
The most common failure are the two convergence integrated circuits part # 267P173010. The two pico fuses may be open as well, which come from the power supply and provide +24 volts and -24 volts.
Feb 15, 2008 | Mitsubishi WS-65313 65" Rear Projection...
Philips Senseo HD-7810 Coffee Maker Logo
657 people viewed this question
Top Philips Coffee Makers & Espresso Machines Experts
Kolbrun...
Lisa
Lisa
just-ice
Are you a Philips Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
