Your copier had an issue when warming up. That code refers to Main heater lamp low temp detection. Sometimes you can reset that code via simulation 14 in service mode. If the code cannot be reset, you will need to have the lamp and maybe temp sensors in the fuser replaced.
*#66*# Set Factory Mode CONFIRMED *#8375# Show Software Version CONFIRMED *#1234# A2DP ACP Mode CONFIRMED *#1234# A2DP INT Mode CONFIRMED *#0000# + Send : Set Default Language CONFIRMED *#0007# + Send : Set Language to Russian CONFIRMED *#0033# + Send : Set Language to French CONFIRMED *#0034# + Send : Set Language to Spanish CONFIRMED *#0039# + Send : Set Language to Italian CONFIRMED *#0044# + Send : Set Language to English CONFIRMED *#0049# + Send : Set Language to German CONFIRMED *#0066# + Send : Set Language to Thai CONFIRMED *#0084# + Send : Set Language to Vietnamese CONFIRMED *#0966# + Send : Set Language to Arabic CONFIRMED
More some codes for reset mobile china *#77218114# *#881188# *#94267357# *#9426*357# *#19912006# *#118811# *#3646633#
CHINESE MODELS:
default user code: 1122, 3344, 1234, 5678
Engineer mode: *#110*01#
Factory mode: *#987#
Enable COM port: *#110*01# -> Device -> Set UART -> PS Config -> UART1/115200
Restore factory settings: *#987*99#
LCD contrast: *#369#
software version: *#800#
software version: *#900#
set default language: *#0000# Send
set English language: *#0044# Send
set English language (new firmware): *#001# Send
also ========== Service codes BenQ: software version: *#300# test mode: *#302*20040615#
Service codes Pantech: software version: *01763*79837# service menu: *01763*476# reset defaults (phone/user code reset to default): *01763*737381#
Service codes 3xx, 5xx: software version: *#79# software version: *#837# Service codes VK200, VK2000, VK2010, VK2020, VK4000: software version: *#79# service menu: *#9998*8336# (hold #) reset defaults (phone/user code reset to default): *#9998*7328# (hold #)
Service codes LG: software version: 2945#*#
Service codes Sony-Ericsson: J100 software version: #82#
Service codes Fly: 2040(i) reset defaults: *#987*99# Send MX200 reset defaults: *#987*99# Send MX200 software version: *#900# Send SL300m reset defaults: *#987*99# Send SL300m software version: *#900# Send SL500m reset defaults: *#987*99# Send SL500m software version: *#900# Send MP500 reset defaults: *#987*99# Send MP500 software version: *#900# Send Set language to English: *#0044# Set language to Russian: *#0007#
Service codes Konka: C926 software version: *320# Send C926 set default language: *#0000# Send C926 set English language: *#0044# Send
Service codes GStar: GM208 (Chinese Nokea 6230+) engineering menu: *#66*# Set language to English: *#0044# Set language to Russian: *#0007#
ZTE Mobile1- *938*737381# 2- PHONE WILL DIPLAYED DONE 3- POWER OFF YOUR PHONE AND POWER ON AGAIN alcatelE205 unlocking phone code,only press***847# without simcard
E900 software version: *#5002*8376263# E900 full reset: *2767*3855# Service codes Spice: S404 enable COM port: *#42253646633# -> Device -> Set UART -> PS -> UART1/115200 S410 engineer mode: *#3646633# S900 software version: *#8375# S900 serial no: *#33778# Service codes Philips: S200 enable COM port: *#3338913# -> Device -> Set UART -> PS -> UART1/115200
Service codes Pantech: software version: *01763*79837# service menu: *01763*476# reset defaults (phone/user code reset to default): *01763*737381# Service codes VK-Mobile 3xx, 5xx: software version: *#79# software version: *#837# service menu: *#85*364# (hold #) Service codes VK200, VK2000, VK2010, VK2020, VK4000: software version: *#79# service menu: *#9998*8336# (hold #) reset defaults (phone/user code reset to default): *#9998*7328# (hold #)
Service codes LG: software version: 2945#*# KG300 NVRAM format: 2945#*# -> menu 15
Service codes Fly: M100 software version: ####0000# 2040(i) reset defaults: *#987*99# Send MX200 reset defaults: *#987*99# Send MX200 software version: *#900# Send SL300m reset defaults: *#987*99# Send SL300m software version: *#900# Send SL500m reset defaults: *#987*99# Send SL500m software version: *#900# Send MP500 reset defaults: *#987*99# Send MP500 software version: *#900# Send Set language to English: *#0044# Set language to Russian: *#0007#
Service codes Motofone-F3: Motofone F3 software version: **9999* Send ***300* Set SIM Pin ***310* / ***311* SIM Pin ON | OFF ***000* Reset Factory settings ***644* Set Voicemail number ***260* / ***261* Auto keypad lock ON | OFF ***510* / ***511* Voice Prompts ON | OFF ***160* / ***161* Restricted Calling (Phonebook only) ON | OFF ***200608* Send: software version ***200606* Send: software version ***200806* Send: flex version ***250* / ***251* Keypad tones ON | OFF ***470* Select time format ***500* /***501* Prepaid Balance Display ON | OFF ***520* Change language
you should be able to get into service via trouble reset hold utility button while turning on copier when you get to trouble reset screen do the stop 0 stop 0 1 and that should get you in. You might need to put the stock firmware on to cure the fault. If you need anymore help i can look into it for you.
1. Service mode is switched by SERVICE key, CH UP + VOL DOWN when reset. 2. Service mode is cancelled by SERVICE key during Service mode. 3. Service mode can be switched to the following 5 modes via MENU key: Do it with care. Enter the site linked here to know more. Do a search by entering thebrand name to your deviceby its search box at top right of the
display window, because, posts are not arranged in alphabetical order, but by
brand name first.
I just had the same problem. I downloaded a service manual and give this a try
http://www.servicemanuals.net
. Turn on your TV and with the remote do the following
Key in the code “123654” via the standard RC transmitter. This get you into a customer service mode and you can check your error codes. After I got out this mode my TV worked. I think the TV was stuck in protection mode for some reason and by entering the service menu's it reset it. I then entered the SAM Mode How to Activate SAM Via a standard RC transmitter: key in the code “062596” directly followed by the “INFO” button. After activating SAM with this method a service warning will appear on the screen, you can continue by pressing the red button on the RC. It will give you more info. The TV worked fine after I exited these menu's. I also did a software update as per the user manual and the TV seems to be working fine again.
to reset it just enter service mode and cycle power. But first take out the fuser ( right side of copier 2 screws ) and check that the 2 rollers hot and pressure are touching each other no gap between them. The unit you have is a nice unit, for service to fix if replacement is required would be about 300.00 or so... -Carl
if the part is wrong try A190-4119 thermistor for ft3613 might work as well as for the reset go into the service mode via Clear 107 then stop(hold down till changes screen then you need mode 97 for fuser reset.. Good Luck A..
