Question about Specialized Bicycle Components Specialized Bike Bicycle Mountain Road Sticker Decal
I have an o5 enduro expert that I took the shock out of, but the pieces aren't fitting so easily on the way back in. Can you describe the order (there are 3 pieces on each side and two frame pieces as well as the shock itsself)? thanks
    New Friend:
  • 77 Answers
You should have a bolt and washer that pushes through from the drive-side first. It goes through the frame tab, the right-side step washer, the o-ring and the eyelet. It comes out through the other side of the body, the o-ring, the step washer (small side facing the shock eyelet), the frame tab and out the other side where you thread the nut on.
NOTE: The step washers need to be inserted into the eyelet/DU bushing so the the smaller part is fully inserted into the eyelet BEFORE you start!
Posted on Jan 10, 2010
My van shimies left and right badly....and it pulls to the left....it does it more when going straight and not so much when going around curves
check the vans rear shock absorbers if they are faulty the car can exhibit this type of behaviour and braking will be less efficient. Also tyre wear will be affected to.
I am not a shock absorber expert but had recently my four shock absorbers replaced as the fluid had ruptured in the front shockers and the rear mounts for the rear shockers were corroded and unsafe. (shock absorber expert at repair place mentioned the symptoms you are describing as a rear shock problem or the rear leaf springs are faulty)
Mar 18, 2015 | Cars & Trucks
I have a replacement rear bumper/fender (the plastic shell) for my '93 190e 2.0, but its different to the original - the right dimensions, but its one piece that fits right around from one wheel arch to...
YOu can contact Mercedes for a copy of the service manual for your particular vehicle, It cost some money but it will tell you how to basically fix and replace anything . Other than that i cant be any more help , maybe another expert can have a better idea
Jul 14, 2008 | Mercedes-Benz 190-Class Cars & Trucks
I put the wand back inside of the tube and clicked the handle back onto the vacuum. Now the wand is poking down the bottom of the back of the vacuum. It's pushing down the black curved piece at the...
The black curved piece you mention is part of the changeover valve mechanism, which automatically diverts suction from the cleaner head to the hose when you remove the wand from the cleaner. The position you've described it in - open, with the base of the wand poking through - is normal when the wand is fitted on the machine, and is nothing to worry about.
If you have any further concerns, please get in touch with us directly so one of our experts can provide the assistance you need. You can call us free on 08002980298 (UK), or 1866MYDYSON (US).
Kind regards,
Jack
Dyson Customer Service
Aug 05, 2011 | Dyson Ball DC24 Bagless Upright Vacuum
My boyfriend took his back tires off and I messed with his barkes now they are locked how can I fix it ?
Put the wheel on properly.
Search Engine of your choice: "how to install back wheel on a bike" for video.
Ditto: "how to adjust brakes"
Experts aren't for routine Search Engine answers.
Jun 27, 2011 | Cycling
I have an TE-450 2010 model and i want to lower it 1 to 2 inches with out upsetting the suspension.What would be the best way too achieve this.Can i change the shock linkage arm to lower the bike. Thanks
No, best way to lower your bike is to send the forks and shock to a reputable suspension shop and ask them to install spacers inside the forks and shock which will reduce the length without changing the damping. This modification is easily reversable if you decide to put the bike back to full height.
Try Enduro Engineering or Factory Connection or .... there are many others out there.
Sep 01, 2010 | Husqvarna TE 450 Motorcycles
My xbox has an error code o5 says it requires service can you help
error Code 5 on The Standard XBox.
states That The Hard-Drive is Unlocked.
and will usually frag ( red/green )
this can be resolved, by fitting a temporary mod-chip.
and locking the drive back. or purchasing a software disk to do this.
This has been caused, by powering off the console, while a save-game or similar, has been occuring. the xbox hard-drive only unlocks at initial boot up. and to save games.
I could fix this, unfortunately Fixya does not Allow experts To advertise Services. If you look around. you Might Find my e-mail Address ;-)
Mike @ Compurepair.
Aug 19, 2009 | Microsoft Xbox Console
Something rolling inside the Drum
The rear half of the outer tub, with bearing is part # 131525500 and it looks like the back "spider" shaft is not available as a separate part from the inner drum. The "spider" shaft is most likely worn or damaged and in need of replacement also.
131618500
Then, there's that strut
134564200
Now, two pain in the back side hours of your labor and you've got your washer back, at more than what a new one would cost! Junk it and get a new larger capacity front loader.
Please don't rate this, as anything but the top rating will lower my score. I'm just giving you my honest opinion, that your machine is not economical to repair. I've owned a LG front loader for over 6 years and think they are the best, but there are other good front loaders out there also.
May 19, 2009 | Frigidaire GSTF1670A Front Load Washer
How to best insert new break fluid and bleed the line
Depending on which brand of brakes you have on your bike, you will need a brake bleeding kit specific to those brakes. Some of the fittings in the kit are such that you can't make them or obtain them elsewhere easily. There are various fluids used also. Some brakes use mineral oil and some brake fluid vary in density from DOT 3 to 5.1. This is something that is more easily done with a helper and the right tools. A good bicycle shop can do this at a nominal fee or they can sell or order you what you will need.
Apr 24, 2009 | Specialized Bicycle Components Specialized...
Saab 93 - noisy when going over bumps on the road.
Have you tried driving over a bump whilst also applying the brakes? (Right foot on gas, left gently on brake - with no one behind you!) If the noise goes away, then it could be the brake pads that are not fitted correctly. Only posting this, as this just happened to mine...the mechanic took it over bumps and noise was there. Applied brakes whilst going over bump, noise went away. Replaced badly fitted rear pads (had been bodged by another garage) and the problem was solved.
Apr 23, 2009 | 2004 Saab 9-3
Specialized Bicycle Components Specialized Bike Bicycle Mountain Road Sticker Decal Logo
104 people viewed this question
Top Specialized Bicycle Components Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Specialized Bicycle Components Cycling Expert? Answer questions, earn points and help others
