Question about Frigidaire FWS833A Top Load Washer
My washer started making sort of a knocking kind of sound, and now it doesn't agitate or spin. What is the likely problem, is it an easy fix? I know absolutely nothing. Thanks so much in advance!
    President:
  • 1,653 Answers
First thing to do is tswitch oiff the AC power and wait for 30 minutes then switch it back on. Make sure you do a light load only and try again. If the error persists then then there may be:
  1. a defective load sensor
  2. problem with too much water in the drum (which will be aproblem with the pressure or water level sensor)
  3. the drum support mountings
  4. drum support tenstion springs
  5. drum or motor bearing.
Posted on Nov 13, 2009
Maytag washer doesn't agitate
Google the model number. I had the same problem, Googled it, and found the actual turial on YouTube to fix it.
Dec 11, 2011 | Maytag MAV6200 Top Load Washer
Will not agitate after water fill up. Motor makes whining sound.
It sounds like it could be the coupling that has worn or broke, to verify this put the washer in spin, let it drain the water out (if it will) then turn off the timer or open the lid, wait 10 seconds or so then start back up in spin. If the washer just whines then it is most likely the coupling. I have put together some instructions on this if you follow this link it will tell you more about it and how to replace it if you wish. Let me know if this helps.
http://www.fixya.com/support/r4670549-drive_coupling_replacment
May 06, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Old GE washer, agitater starts, tubs stats to move
The main seal on the tranny is leaking. This is a cheap and easy fix. This machine is worth the effort to repair it by the way. Here is what you do and it is fairly easy to do although it sounds complicated. Remove the agitator and the tub anti wobble. Then remove the inner tub. Get the tub eal off and then remove the tranny. Flip it over and remove the bottom. Knock out the seal and put a new one using a little oil to lubricate it. Add 2 quarts of motor oil to the tranny and put it back together. Re install the tranny and she will be good as new. Nothing is complicated about this repair and no special tools are needed.
Dec 20, 2009 | Heating & Cooling
Washer is not washing, only sounds in spinning cycle, but no washing, make sound and kind of moves the clothes around, but that's it. turns off by itself
If it is fact spinning,use this video to replace the agitator dogs.
If it is not spinning let us know for the next fix.
http://www.youtube.com/watch?v=V5wIN1J70-Y&feature=player_embedded#
Dec 10, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore Elite top loader makes loud knocking sound when spinning
sometimes the agitator gets loose, causing the drum to sway to far all over the place.make sure its tight , remove the softener dispenser (manual nut), then tighten the metal nut that holds the agitator down
Jul 14, 2009 | Washing Machines
Whirpool Duet washer knocking sounds
From what it sounds, it could be one of the suspension bars. when it's spinning, it is all in the same direction where as agitation is both directions... that would make noise from starting and stopping directions etc. it could be a few other things... please let me kno if you need more help.
Feb 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Agitation issues. Everything else appears/works normally.
I just encountered the same problem. I think the operation of the machine is such that the motor turns one direction for the spin cycle, and the other direction for the agitate cycle. I am replacing my motor, as I think i have a bad winding on the reverse. I will let you know.
Jul 03, 2008 | Maytag Performa PAV2200
Whirlpool noise
Ok can you take the front panel of the washer off easily?
If you can look for the motor pump assembly. Start the washer with no load, turn the water level down to the small and fill with water when it goes into agitation does it make the noise? if not turn timer to spin and see if motor makes the noise.
One other thought, maybe the smell is coming from the dryer?
Let me know. I wont be on line again until Friday Sorry
May 26, 2008 | Whirlpool LTE5243D Top Load Stacked...
Knocking sound in agitator
Your Agiator "Dogs" maybe stripped these hold the agiator in the wash cycle place you han on top of the agit. and try to turn it clockwise then go back counter colkwise is it feel like it is grabbing or just free spinning??
Jan 16, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Frigidaire FWS833A Top Load Washer Logo
152 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
