Question about Whirlpool Duet GHW9150P Front Load Washer
I am getting a code f-02 on whirlpool duet washer. I run the diag routine and the pump motor runs but begins to make a chattering noise after a few seconds. I checked and have 120v at the motor connector with it disconnected. I was unable to check voltage with the motor running due to space constraints. I want to be sure it is the motor and not a low voltage condition like bad relay contacts. Is the motor a common failure? model GHW9100L
  • Whirlpool Master
  • 19,396 Answers
Hi.
The noise is probably debris or objects stuck in the pump filter.
Undo the pump hose and check out.
If the hose is clear, and noise is from the pump, then replace the pump.
Regards.
Posted on Nov 13, 2009
Why does my whirlpool frontloader stop in the middle of a cycle and read f 02
Repairing the F02 error code can usually be done without ordering parts. Tools needed to repair your whirlpool Duet F02 error code are towels and a quarter inch socket.
Tip the washer back at a 45 degree angle. On the bottom panel there are three or four screws, with the screws removed the panel will slide down and off. With the lower access panel now removed you will have access to the washers drain pump clean out.
With the water already bailed from the washer you can twist the filter head counter-clockwise to remove. Twisting the filter head counter-clockwise will loosen filter so it can be pulled out.
With the filter out clean and install it back into washer.
Run a quick cycle to ensure the washer is back up and running and the F02 error has disappeared. If the error comes back, it may require you to clean the drain pump filter again.
If you require a new drain pump motor, you can purchase the part from the link below.
- See more at: http://www.appliancerepairlesson.com/2011/03/12/how-to-fix-whirlpool-duet-error-code-f02-duet-sport-error-f02-fix/#sthash.PuGd0iuQ.dpuf
Sep 06, 2014 | Whirlpool Washing Machines
F- code 02
How to fix a Whirlpool Duet & Duet sport error code F02. Repairing your F02 error code can usually be done without ordering parts. Tools needed to repair your Duet F02 error code are towels and a quarter inch socket.
With the water already bailed from the washer you can twist the filter head counter-clockwise to remove. Twisting the filter head counter-clockwise will loosen filter so it can be pulled out. With the filter out, clean and install back into washer.
Run a quick cycle to ensure the washer is back up and running and the F02 error has disappeared. If the error comes back it may require you to clean the drain pump filter again.
Dec 03, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Code "F02" sometimes pumps out water sometimes
F-2 Long Drain
If the drain time exceeds eight minutes, the water valves are turned off
and "F/02" is flashed. Press PAUSE/CANCEL two times to clear the
display.
NOTE: After four minutes the "Sud" error will be displayed, then four
minutes later the "F/02" error code will be displayed.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and
make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Here's the handy Hippy with a nice video
Here is a Duet HE washer service manual
Thanks for using FixYa
Jan 24, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washergets a code 2 when it gets to spin cycle.wont rinse and spin
If the drain time exceeds eight minutes, the water valves are turned off and “F/02” is flashed. Press PAUSE/CANCEL two times to clear the display. NOTE: After four minutes the “Sud” error will be displayed, then four minutes later the “F/02” error code will be displayed.
1. Check the drain hose and make sure it is not plugged or kinked. 2. Unplug washer or disconnect power. 3. Check the electrical connections at the pump and make sure the pump is running. 4. Check the drain pump filter for foreign objects. 5. Plug in washer or reconnect power. 6. If the above does not correct the problem, go to step 7. 7. Unplug washer or disconnect power. 8. Replace the pump.
Apr 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F-02 error code on whirlpool front loader duet
F/02 Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump
Mar 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F 02 Error code, took apart and found 2 small
WHAT DID YOU TAKE APART AND FIND THE NAILS? WAS IT THE PUMP? SOME MORE NAILS MIGHT HAVE GOTTEN BACK IN THE PUMP OR THE PUMP IS DAMAGED.
Feb 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Hello- I have a front loading whirlpool duet washer. I am not sure of the model number BUT.... it fills and begins its cycle and after awhile it starts to make a low grinding/crunching type noise. It...
F/02 Long Drain
  • If the above does not correct the problem, replace the pump.
Jan 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet washer will rotate to balance
To solve this:
thanks.
Aug 31, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet. Strange noise and F 02 error code
Feb 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My Duet washer doesn't run through the entire spin cycle on heavy duty setting. Clothes come out of washer, naturally,WET!!!!!!!!!!!!!! Seems to spin out better on the normal cycle. spin cycle dosent...
displayed.
Possible Causes / Procedure
or kinked.
Jan 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
122 people viewed this question
Dan Webster
Dan Webster
Sal De
