Question about Hardware & Accessories
I have a intermatic/malibu ML300TW low voltage light transformer that will work manually by turning the on off knob but once the timer gets to the place it should turn on, it stops. Almost like it does not have enough power to trip the lights on. Once on (WITH A KNUDGE OR A MANUAL ON)it will shut itself off. Ideas?
  • Dan Todd May 11, 2010
    Have you tried dousing the inner works with WD-40? Mine does the same thing and it works for mine.
protek480
  • 1714 Answers
SOURCE: My intermatic timer won't trip back on
I don't think the timer runs on 240 volts does it? You can switch 240, but the timer uses 120 volts to run. You might check the connections and timer clock rating more closely. Also, the 'off' & 'on' trippers are different, make sure you use the right one.
Posted on Jun 26, 2009
SOURCE: Have Malibu low voltage transformer. Need red and
Routinely vailable on eBay...sometimes listed as "Intermatic" (Malibu's parent company.).
Posted on Mar 12, 2010
  • 5159 Answers
SOURCE: I have an intermatic/malibu low voltage outdoor
I think you can add any Malibu 12V lights rated for the 300 W power pack. Make sure that the total output stays below the 300W limit.
http://www.malibulights.com/ and click on Products and the different available lights will be detailed with the voltage and wattage.
You just have to click on the category, then the specific light and Product details.
This tier light would be acceptable http://www.malibulights.com/Products/Detail.aspx?category=Low+Voltage+Lighting&subcategory=Tier+Lights&sku=8301-9200-01&series=TIR-2009-1&seriesname=Cast%20Metal%20Tier%20Light&id=195
This flood light can also be put on the system
http://www.malibulights.com/Products/Detail.aspx?category=Low+Voltage+Lighting&subcategory=Flood+Lights&sku=8301-9602-01&series=FLD-2009-2&seriesname=20W%20Cast%20Metal%20Flood&id=206
I hope this helps.
Posted on May 10, 2010
SOURCE: My Intermatic Timer (model PB115M1) is not keeping
...may have solved this one... opened up an Intermatic Model HB31R and it seems to have the WG2030 timer motor... this model (complete timer box) cost $20 or so...
Posted on Sep 24, 2010
SOURCE: I just bought an older
I think you have the ET70215C SPDT
http://www.intermatic.com/products/timers/electronic%20time%20switches/next%20generation%20time%20switches.aspx
If this is not your timer, then add a comment.
Manual for ET70215C (same manual is for other models too)
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/et70215c%20-%20english.ashx
Just as you figured, timer has selectable voltage.
Page 28 shows wiring diagrams and jumper settings:
Timer comes with a jumper, and then you select with voltage by installing jumper
Sample wiring diagram below shows 120Volts:
ET70125 appears to have 8 terminals.
Some models have 5 terminals.
There are many ways to wire this timer. Off hand I can think of 10 different ways.
Add a comment if you need help with a specific project.
In any case, the clock terminals are 1 and 2.
To put voltage to the timer switches in the simplest wiring options, is to put a jumper wire from terminal 2 to 3
If you are using 240-277 voltage with two hot wires, you still need to jumper from clock terminals to switch terminals. For example one jumper wire from terminal 2 to terminal 3 & then second jumper wire from terminal 1 to terminal 6
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer.
Posted on Jan 09, 2011
We have an older Malibu 300w low voltage transformer that has a non-working timer and want to install a photo eye on it. The instructions for the photo eye as well as recent IFU from Malibu show 3...
How about this solution:
Don't use the photo eye from Intermatic, since unsure if older timers might not be made for that feature.
Instead, plug power pack into photo-eye timer.
Or plug power pack into ordinary wall timer:
Copy following links for resources:
http://waterheatertimer.org/Woods-timers-and-manuals.html#outdoor
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#TN
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Call Intermatic and they might have solution for photo eye.
Gene
hh
Oct 06, 2013 | Intermatic Malibu 300W Power Pack...
Manuals al900mtss transformer
Copy following link for Intermatic / Malibu low voltage transformers manuals:
Copy following link for Low voltage Intermatic pool transformers:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#pool-lights
Jun 05, 2012 | Intermatic Hardware & Accessories
Lost manual for ML300RTW transformer. Does this transformer have an override so I can plug into exterior timer? If so, where is it?
Yes power pack has override, depending on model.
There should be a small knob located above and to left of dial that rotates: Step 8 in Manual says: You can manually operate the lights by turning the Manual ON/OFF Switch counter clockwise.
http://www.intermatic.com/~/media/files/intermatic/products/instructions/professional%20lighting/ml300rtw%20ml300rtwsn%20trilingual.ashx
For information on Intermatic/Malibu power packs showing links to manuals, troubleshoot steps, replacement trippers, useful links, warranties and tips:
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Apr 02, 2011 | Intermatic Malibu 300W Power Pack...
Timer on my 200W transformer is working but lights will not turn on manually or by timer. when i turn on with manual switch they flash on for a second then turn off. i am just under 200W for total...
You posted under Intermatic-malibu power packs.
Wattage of bulbs must match wattage of power pack or bulbs and power pack will burn out.
Your power pack might be damaged beyond repair.
For information on Intermatic/Malibu power packs showing troubleshoot steps, replacement trippers, useful links, warranties and tips:
Aug 23, 2010 | Malibu ML200RT - Low Voltage Power Pack...
Nov 22, 2009 | Malibu ML600TW - Low Voltage Power Pack -...
I have a Malibu 600 watts low voltage transformer that works only for 30 minutes and then, will turn on again for another 1 hr. I only want to turn on one time but for 4hrs. I already removed one red and...
There are no repair parts for intermatic/malibu power packs.
If problem timer malfunction, then set power pack to override, buy cheap plug-in timer, and plug power pack into cheap timer.
If problem is internal wiring, then replacement is option.
For more information on Intermatic/Malibu power packs showing troubleshoot steps, replacement trippers, useful links, warranties and tips:
Sep 01, 2009 | Intermatic Malibu 300W Power Pack...
Hardware & Accessories Logo
635 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
