Question about Western Digital Passport 320GB External USB 2.0 Hard Drive
When i hook it up onto the computer i can here the detection sound usb and also the the usb confirmation icon pop's up on the lower right screen near the time... i've tried switching the casing also and it doesnt work....tried different usb ports.....tried different computers n operating systems as well and so far no luck.....the data on my HD is very valuable to be, is there anyway i can save the data?
  • solano_pe Nov 13, 2009
    sir about the external hard drive problem the model is Western Digital My Passport 320GB\r\ni opened the hard drive already and found out that there is no sata socket... please help.. my files are very important thank you very much for your quick reply sir..
  • 748 Answers
If the USB drive is detected by system generally, as you write, first thing I would do is go to Disk Management (on Windows XP it's under Administrative Tools, the quickest way to get there is to right-click My Computer and choose Manage) and see if the system recognizes the disk volume. If it is listed under Disk Management, try Assign/Change drive letter, and assign it an unused drive letter. Don't try anything harsh, like formatting or removing partitions!
If this doesn't help, or the drive volume is not present under Disk Management, the next step would be to remove the actual drive from the USB case and hook it up to the motherboard. You don't specify your drive model, so the actual hookup will depend on the type of drive that's inside. If it's a 2.5" IDE/ATA drive, you will need an adapter to connect it to a standard ATA cable and standard power for example. If you are not computer hardware savvy, I would recommend asking for professional assistance.
Good luck.
Posted on Nov 13, 2009
  • Stan
    Stan Nov 13, 2009
    Well, it's rather impossible to assist you remotely. You need hands-on assistance from someone that knows what he/she is doing, otherwise it will only get worse.
How do I turn on usb storage when attaching to my computer
Connect your tablet to the PC via the USB connection
After a few seconds, during which the two computers are negotiating the connection, a small USB icon will appear in the toolbar at the lower right, near the clock
Touch the toolbar clock and in the pop-up menu that will then show, touch the "Turn on USB storage" entry.
In the window that then opens, touch the "Turn On USB Storage" button that appears near the bottom of the frame
You now have files access to and from the PC, and can up and download files to eiher the micro USB card (if fitted) and/or the internal storage memory. [:o)
Sep 14, 2014 | ZEEPAD New 7 Inch Android 2.2 Tablet Pc...
Magicjack and a usb handset device from tigerjet are suddenly in my computer's speaker mixers. now I get no sound through my computers speaker, however that sound is coming through my telephone speaker...
I am assuming you are on a windows machine.
Right click on the speaker icon (volume control icon) normally located near the time lower right hand corner of the task bar. When you right click a sub-menu should pop up.
Select "Playback devices" and then select the "Speakers" option you wish the sound to play back on.
Hope this helps.
Sep 07, 2013 | Computers & Internet
How to unlock partition on flash drive
USB flash drives are small, convenient storage drives. Place data such as pictures, photos and text on them quickly and efficiently and then carry it to another computer for copying to its hard drive.
A USB flash drive that has security enabled in it must be 'unlocked" before it can be used, which becomes difficult if the password has been lost. Because the security on the USB flash drive is rudimentary, a number of methods, from built-in software to optional programs, can remove the security so that the drive can be used.
Plug the USB connector of the USB flash drive into a USB port on the PC. Right-click on the icon of the USB flash drive when it appears on the desktop of a Windows-based computer. Select "Format" from the pop-up menu. Follow the command prompts in the window that appears to format the USB flash drive. Click "Done" in the confirmation window when it appears. The USB flash drive can now be used because the security has been removed from its storage space. Plug the USB connector of the USB flash drive into a USB port on the Mac. Double-click on the Mac's Disk Utility program, which comes free with the OS X operating system and is in the "Utilities" folder on the hard drive. Select the icon of the USB flash drive in the left column of the Disk Utility program's main screen. Select the "Erase" tab at the top of the Disk Utility program's main screen. Click on the "Format" check box on the right side of the Disk Utility program's main screen. Select "Fat (32)" from the drop down menu below the "Format" check box. Click "Format" at the bottom of the Disk Utility program's main screen. Click "Format", again, in the confirmation box that appears. Quit the Disk Utility program when the formatting is done. The USB flash drive can now be used because the security has been removed from its storage space. Download a password protection program to the computer's desktop; for example, the free TrueCrypt password protection program (see the link Below). http://www.truecrypt.org/downloads Double-click on the icon of the password protection program when it has fully downloaded. Follow the command prompts to install the program onto the computer's hard drive. Restart the PC after the installation has been completed. Double-click on the password protection program to launch it. Wait for the password protection program to recognize the USB flash drive and display disc letters for the drives attached to the computer in the left column of its main program screen. Plug the USB connector of the USB flash drive into a USB port on the computer. Wait for a letter to appear in the left column of the password protection program's main screen. Use the mouse to click once on this letter which represents the USB flash drive. Click on the "Volume" or "Volume Tools" button to open a new window. Click on the "Next" button in the new window. Erase the password in the "Password" column of the new window that appears. Erase the password in the "Confirm password" column. Click on the "Next" button to go to a new screen. Select "Traveler Disk Setup" from the drop down menu below "Tools" at the top of the password protection screen. Click on the "Open Explorer window for mounted volume" check box in the new window that appears. Click the "Create" button at the bottom of the window. Click the "OK" button on the confirmation window when it appears. Quit the password protection program. Drag the icon of the USB flash drive to the Trash or right-click on it and select "Eject" from the pop-up menu. Remove the USB flash drive from the computer's USB port. Plug the connector of the USB flash drive back into the computer's USB port. Double-click on the icon of the USB flash drive when it appears on the desktop to open its window now that the security password has been removed. Plug the USB connector of the USB flash drive into a USB port on the PC. Go to "Start" and select "Run" from the pop-up menu. Enter "regedit" into the text column that appears and press the "enter" key to run the registry editor. Press the "Browse" button on the registry editor's main screen and navigate to the following path on the computer's hard drive: "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies" Click "OK" to close the window. Double-click on the "WriteProtect" text that is in the right column of the registry editor's main screen. Enter "O" into the "Value Data box" in the window that appears. Click on the "OK" button to close the window. Quit the registry editor program. Restart the PC. Double-click on the icon of the USB flash drive that is on the desktop to open its window and access the files now that the security write protection has been removed.
Hope this helps.
Jan 17, 2013 | SanDisk Electronics - Others
Convert usb raw drive to fat drive
The Fat32 (FAT) format is used to format disk drives on Windows-based computers and can also be recognized by the Mac's OS X operating system. You can format a flash drive with the FAT format so that it can be used on both PCs and Macs. The procedure is straightforward, if different depending upon the operating system being used to do the formatting. You do not need to purchase any additional software to format the Flash drive in the FAT format.
http://www.supermediastore.com/article/u/how-to-format-usb-flash-memory b> http://download.cnet.com/hp-usb-disk-storage/3000-2094_4-10974082.html Format USB flash drives with FAT, FAT32, or NTFS partition types. Plug the Flash drive into a USB port on the Mac. Double-click the "Applications" folder inside of the Mac's hard drive. Scroll down to the "Utilities" folder. Double-click the "Utilities" folder. Scroll down to the Disk Utility program. Double-click on the Disk Utility program to launch it. Click once on the icon of the Flash drive that is in the left column of the Disk Utility program's main screen. Click on the "Erase" tab at the top of the window of the Disk Utility program's main screen. Name the Flash drive in the "Name" column at the center of the Disk Utility program's main screen. Select "MSDOS (FAT) from the "Format" menu beneath "Name." Click the "Erase" button at the lower right corner of the Disk Utility program's main screen. Click the "Erase" button in the pop-up confirmation window that appears. Wait as a progress bar at the bottom of the Disk Utility program's main screen fills in from left to right. Click the "Eject" button at the top of the Disk Utility program's main screen once the progress bar is completely filled in. Quit the Disk Utility program. Remove the Flash drive from the USB port of the Mac. b> Format Flash Drive in FAT on a PC b> Plug the Flash drive into a USB port on the PC. Go to "start," "My Computer." Right-click on the icon of the Flash drive in the center column of the window that appears below "Devices with Removable Storage." Select "Format" from the pop-up menu. Select "FAT32" from the "File System" drop-down menu in the window that appears. Click the "Start" button at the bottom of the window. Click the "OK" button in the confirmation pop-up window that appears. Wait as a progress bar fills in from left to right at the bottom of the window where you had selected "Fat32." Click the "OK" button on the "Format Complete" pop-up window when it appears. Right-click on the icon of the Flash drive that is on the desktop. Select "Erase" from the pop-up menu. Remove the Flash drive from the USB port of the PC. Hope this helps.
b>
Dec 07, 2012 | Corsair Memory Computers & Internet
I have a Sony DSC-W350/W360 and want to download onto my computer. How do I do that
Connect your camera in computer USB port with supplied USB cable, turn On camera in playback mode, Windows will recognize it and install required drivers automatically, once you got confirmation box at lower right corner of screen, click My Computer > Mass Storage (new disk icon) to get it open, you will see folders there that contain saved pictures, click to open folder and copy/ paste pictures in computer.
Hope this will help.
Thanks.
Jun 21, 2011 | Cameras
I want to use my wifi feature to connect my computer to the internet.
If you mean you will use your phone as a modem to connect your computer to the internet please follow these steps.
Setting up a USB Internet Sharing connection
  1. Note: BEFORE YOU BEGIN Make sure your phone is on and that one of the data services icons appears at the top of the screen. If you don't see either of these icons, you cannot use your smartphone as a modem.
  1. On your computer, open ActiveSync or Windows Mobile Device Center.
  2. Click File > Connection Settings, and make sure the Allow USB connections box is unchecked.
  3. Connect your smartphone to your computer using the sync cable.
  4. On your smartphone, press Start 800w_start.jpg and select Today. Select the Internet Sharing icon.
  5. Select the PC Connection list, and then select USB.
  6. Press Connect (left softkey). When your computer detects the connection, an icon appears in the taskbar in the lower-right corner of your computer screen.
  7. On your computer, open your web browser to confirm that you can connect to the Internet.
You can visit the site here for more details
Mar 31, 2011 | Palm Treo 800w Smartphone
How to get Photos From memory card to computer
  1. Hi
  2. Plug your Samsung mobile phone's USB flash cable into the phone and into the computer's 2.0 USB port outlet. When the computer detects a USB connection, a notification screen will appear in the lower right corner of the screen, above the task bar. The phone's software driver will be automatically installed to your computer's hard drive.
  1. Import your pictures to your computer. Click on "Import Pictures" when the "AutoPlay" dialog window pops up. Close the "AutoPlay" window to configure the import settings.
  2. Choose a gallery title for the pictures you are importing. When the blank data form appears in the bottom right corner of the screen, type a name for your gallery in the data form. Click on the "Import" button to begin the downloading process.
  3. Remove the Samsung USB flash cable from the computer and then from the mobile phone. Click on the "Start" menu icon, then select the "Pictures" tab folder. Your newly imported pictures should be stored in this folder. Please Rate this solution. Regards.
Nov 12, 2010 | Samsung Cell Phones
When my hd connected to my laptop.the removable disk icon is shown.but it is not processed.what is the reason for this and let me know the solution
when i hook it up onto the computer i can here the detection sound usb and also the the usb confirmation icon pop's up on the lower right screen near the time... i've tried switching the casing also and it doesnt work....tried different usb ports.....tried different computers n operating systems as well and so far no luck.....the data on my HD is very valuable to be, is there anyway i can save the data? - Fuzz
Oct 02, 2009 | Western Digital Passport 320GB External...
Samsung eternity cant get pics onto computer
There was software that came with the eternity. Use it, or buy it off amazon.
Apr 19, 2009 | Samsung SCH-u550 Cellular Phone
Transfer Problem
What did your PC screen say? It is the PC that does the file transfer not the camera. If you use a Window XP OS, a window on the PC screen should pop up and ask you what you want to do. If you don't see that (plug and unplug the USB cable again and/or use your window window explorer (right click on the start icon and choose explore) to look for your camera. I don't have a Finepix S304, may be the camera screen just telling you that it detected a PC hook up to the camera. Good luck, Hope this help.
Sep 12, 2005 | Fuji FinePix S304 Digital Camera
Western Digital Passport 320GB External USB 2.0 Hard Drive Logo
191 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
