Question about Hoover AAA160 Front Load Washer
Program over running
A wash cycle that normaly takes 40 mins or so takes much longer now.
I have to stop the machine and go to another setting.
  • Hoover Master
  • 3,463 Answers
Could be that the heater element is not working, therby prolonging the wash programme, if it works o/k on a 30 or 40 degree wash, then it is more than likely to be the j heater.
There could be other factors that could cause your prob.
Please leave feedback.
Thanks.
Posted on Nov 13, 2009
Testimonial: "Thank you for that. It gives me a place to start."
My moms washer is taking 3 hours to complete a 40 degree wash, what could be causing this
it sounds like the program/timer is on its way out ( it should click down the minuets then stop ) try another setting that you know will only take 30 mins or so and see if it takes longer. if it dose then program/timer is the problem ( the board behind the settings dile )
Apr 23, 2015 | Washing Machines
F1247td is taking much longer than suggested wash time, over double in some cases
Sounds like a heater issue, holding up the timer due to not getting to temperature. Could also be timer, or even pressure switch. Difficult to diagnose without testing individual wash cycles.
May 17, 2012 | LG Washing Machines
The washing machine is taking longer time
You can check that pump filter which is behind the base plinth, also check that the water entering the machine is at a reasonable pressure. If the machine is taking a longer time to wash and both inlet and the outlet of water is ok, it is more than likely a wash side heater fault. Basically, you set, for example. a 40 degree cycle, the heater does not operate and the water never reaches the required temp, the machine ventually times out on the heat phase and then moves on to the rinses or aborts to the end of the cycle.
Nov 26, 2011 | Bosch Washing Machines
Washing machine 11 years old is jumping on the wash cycles. EG instead of taking 25 mins its taking 10 mins to complete -clothes coming out wet unless manually turn to spin again
It is possible that the program is not running to the designed settings and so the program seems to skip the cycle.
The clothes come out wet because the spin cycle is not activated in the set program. Hence the program controller needs a check.
Jan 17, 2011 | Hoover Washing Machines
Stops mid cycle. Light flashes, cant get it to move on so have to start all over again
Hi there.
I have the same problem with my machine. Whatever program I select, the machine runs fine until it reaches 54 mins of the cycle remaining. To overcome the problem just to select a cycle that will not stop mid cycle, select a program which is less than 54 mins. I think the 40 degrees and quick wash select is the one to run with. The cycle is 45 mins, obviously less that 54 mins. The LED timer will display the cycle time. No problems with this cycle whatsoever. Not the total solution, but at least you're able to complete a cycle. After it's completed, I also run the spin program at 1200rpm. I hope this helps.
Regards, Ian.
Nov 22, 2010 | AEG Lavamat 72640 Front Load Washer
My Maytag Neptune FAV6800AW top load washer only runs for the first few minutes of the cycle, it will not spin..it just stops..we've tried two cycles, the quick wash...it starts at 33 mins and then stops...
I'm and owner and will try to help. Are you handy and do you want to try a DIY fix?
From the wash times is sounds like the washer is agitating the wash load (tumblers are rotating the wash basket load) is that correct?
If so see if the machine will complete a Spin Only cycle with no clothes in the wash basket. Set the Spin setting to Spin/Hang dry seting and start the cycle. It should take about 10 min complete. Does the Spin Only cycle complete with no clothes in the wash basket?
Some handy links if you are going to DIY.........Service Manual for reference.
Sep 17, 2010 | Maytag Neptune FAV6800AW Top Load Washer
My Candy GrandO washing machine is boil washing
sounds like overheating, don't use until you have had it checked, may be dangerous
Sep 29, 2009 | Candy CNW136 Front Load Washer/Dryer
Washing cycle on a 40degree op. takes more than
Don't forget that the reason you bought a front loading washer is for the efficiency of the washing. In other words, front loaders use less water and get clothes cleaner without all the harsh beating that the older agitator units do.
If you're using any of the pre-programmed wash cycles, you might want to tgry another cycle to see how it does for getting your clothes clean with a shorter cycle.
If you check your owners manual, it should provide the cycle times for the various wash and water temp settings. The colder the water you use, the longer the wash cycle typically is, since it takes more agitation and time to get clothes clean, especially with front loading machines. Hope this helps.
Jul 28, 2009 | Whirlpool WFW9200S Front Load Washer
Time remaining stays at 1 min for 20 min
This may happen if using the Super-eco program.
It is designed to extend the washing time / cycle, but is less intesive in rotations. It's more a long gentle soak than a quick scrubbing action.
Thank you for using Fixya! If this provided a solution, please rate as such. Thanks.
Jan 03, 2008 | Maytag EPIC MFW9700S Front Load Washer
Hoover AAA160 Front Load Washer Logo
143 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Johnny Ramirez
Johnny Ramirez
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
