Question about Casio Watches
New Casio 3157 watch: compass works for 7 seconds then goes blank
New Casio 3157 watch: compass calibrates great and works fine except after 7 seconds goes to a blank screen. Go back to time mode and then back to compass--compass works for about 7 secnods.
Mine does the same!
Posted on Nov 23, 2009
  • nicejoegreen Aug 16, 2011
    I just got one of these, and it does the same! did anybody ever find the solution?
    nicejoegreen@gmail.com
  • nicejoegreen Aug 20, 2011
    Looks like it's a design flaw. consider yourselves "lucky" if you're getting a display for 7 seconds.
    I only get 4 seconds (or less).
    I spoke with Casio's Tech Support and was told that "that is just the way the watch is designed--for the compass to be displayed for 2 seconds."
    I don't believe that for a minute, but that's the claptrap I was fed, When I told her that I considered that a fatal flaw that makes the watch a virtually useless piece of junk, her only response was the verbal equivalent of a shrug.
Pro trek 3500 compass only going up 300 degrees. Doesn't reach 360 north???
THe PRO-TREK watch compass is very sensitive to nearby Iron (eg. cars, fridges, steamships, artillary canons, battering rams, guillotines, etc) and anything wearable or embedded in your body. I had to calibrate mine in the middle of a baseball field.
Aug 09, 2017 | Casio Digital Compass Twin Sensor Sport...
I just bought the Casio SGW500H-2B Mens Twin Sensor 100M Digital Sports Watch Compass Thermometer. My problem is the digital readout in compass mode reads fine but the needle/ second hand points to east...
To fix this, hold down the A button for 4 seconds. this allows you to recalibrate the home position of the second hand. My secondo hand was posting exactly 90 degrees west in compass mode, and this home position recalibration fixed it 100 percent.
Sep 11, 2013 | Casio Watches
I have a tcm 217362 watch with a digital compass how can i set it up to show me north it currently shows cal. and when i press the top right and left button it shows err.(probably error) it is a black and...
Hi john30x,
You have to calibrate the compass.
1. Press the upper right button (switching to compass mode)
2. Press and hold upper left button. The "CALL" will appear on the display. You are in compass calibrating mode.
3. Rotate the watch horizontally (around his vertical axis) slowly, so to be sure that he point the North at least 2 times.
4. Now press the upper left button again to input the
declination (this is the angle between the magnetic and real pole). It is different for the area around the world, that you want to explore.
5. Switch between the positions of the cipher by pressing bottom left.
6. Change the cipher by pressing bottom right.
7.
Switch between the active position by pressing bottom left. Now you have to enter East or West declination
8. If you are ready press the upper left. "END" of calibration will appear on the screen
Once you calibrate and set the declination you can use the the compass by pressing upper right button. As the compass is very sensitive It is good idea to calibrate it on a field, far away of metal objects and electromagnetic fields (cables, ect.). You need to calibrate the compass each time you want to use it by different surrounding.
Remember the compass function of your watch need much more energy than the watch itself. Don`t worry to change the battery when dead. The water resistance remains good even after. Very robust and accurate device. I hope that should help.
May 15, 2011 | Watches
Just got my husband a casio pro trek sgw100-1 - we calibrated the compass but east and west are switched - north and south are fine - any ideas? thx
As a pure shot in the dark, are you sure that you calibrated it so that it was pointing to the north when it should be and not to south?
If it was pointing south instead of north, then East and West would be reversed.
Sounds a bit daft but better than the directions of east and west changing?
Check your calibration perhaps?
Nov 29, 2010 | Casio Watches
I don"t know how to calibrate or set up the compass function. Please advise.Its for a casio pro trex sports watch.
Write down the four-digit module number from the watch back, and go to this link for full info in PDF format:
http://world.casio.com/wat/download/en/manual/
Good luck, Bill
Aug 08, 2010 | Watches
I lost my owner's manual for my Casio SGW-100B. When I try to use the compass it asks me to please calibrate
Above link no longer valid. Here's the current one:
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw3157.pdf
Also, the key was inputting the correct #, in this case 3157 - NOT the 100B - at the following page:
I had almost given up when I looked again at the back of my watch and found the other number.
Sep 16, 2009 | Casio SGW100B-3V Watch
Casio Pathfinder Digital Compass will not calibrate
http://pathfinder.casio.com/support/manual/
find your watch and use the manual. if there is no solution then take it in for repair. any Casio retailer should have repair center information.
Jan 25, 2009 | Casio PRG-40T-7 Pathfinder
Casio Protrek PRG-70-YT
wait until the battery is full reloaded
Jul 08, 2008 | Casio PRG-40T-7 Pathfinder
Watches Logo
2,481 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
