My tv will not come on. The power light blinks one time slowly then nine times quickly.
  • vernon johnson
    vernon johnson May 11, 2010
    yes could i have your brand and model no#
  • 145 Answers
Vertical output ic shorted. suggest local service center
Posted on Nov 13, 2009
Why won't my tv turn on. The red light blinks nine times one at a time after nine times it stops & tv still won't turn on.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Jul 26, 2014 | Sony FD Trinitron WEGA KV-32FS120 32" TV
TV shuts down, power light blinks nine times
1) test the power supply: a) line cord, b) fuse c) c.breaker d) rectifier e) filter,f) switch,
2) measure the horizontal output +125Vdc
3) all other circuit +12Vdc-
4) vertical output +80Vdc
Oct 16, 2012 | RCA Scenium D34W20 34" TV
Panasonic TCP58S1 has no pic. or sound. Red light blinks 9 times.
It's dead. 9 Blinks means the display adaptor is dead. If it's still under warranty, you're covered.
Jan 22, 2010 | Panasonic Viera TC-P58S1 58 in. Plasma...
SONY KV35S40 Light blinks continuously when power is pressed
hello there,
Many of the later model Sony TV’s have a built in self-diagnosis function. If the timer/standby indicator is blinking, this could be an indication of a problem with the unit. The diagnostic blinking will occur automatically with no action required by you to engage it.
The timing of the blinking you see would be as follows: two to nine blinks, (depending on the fault), about a third of a second apart, then a pause for 3 seconds, then the two to nine blinks about a third of a second apart again.
May 29, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
TV will not come on. TV standby light blinks nine times continuously. TV is Sony KP-51WS520
Nine Blinks- Replace D6116 and D6301 on the "G" board, do not solder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negative).
Mike
Apr 16, 2009 | Sony KP-51WS500 51" Rear Projection...
You need to call a Sony service center for this problem. It will cost you less in the long run.
WON'T TURN ON
nine blinks means that there is a short inside the set you will have to find a tech to troubleshoot the set most probably is the G pcb
Aug 23, 2008 | Sony KP-46WT520 46" Rear Projection...
Blinking red ight.. HELP!
re solder first your tv most specially the horizontal section and jungle ic.
Aug 15, 2008 | Sony KV-35S42 35" TV
Standby light flashes nine times and tv will not turn on
I had the same problem with Sony KV-32fs120 with 9 blinks. Replaced D645 and D647 on main board with 1.5A1KV diodes from Radio Shack which did the trick.
Jul 01, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Televison & Video Logo
51 people viewed this question
Top Televison & Video Experts
Electro Med Services...
