Question about D-Link DWL-G550 802.11g/b (DWLG550) Wireless Adapter
D-Link DWL-G550 Hi..I am network administrator in a company and I am converting my network to wireless and installing D-Link DWL-G550 wireless card on client systems on windows XP...some users often see a blue screen with a message of physical memory dump and then they have to restart the system to get rid of that message..how can i remove that problem of physical memory dump message and what is that message all about?
    Novelist:
  • 101 Answers
Hi Atta,
The memory dump is not actually a error. It is the system making a log of the what is in the memory, at the time of a crash. The actual error was caused by something else. That DLink series of wireless adapter card, and thier drivers, seem to be very problematic. I found a lot of complaints, like this one, about them.
http://www.amazon.com/review/product/B00007LTBI?filterBy=addTwoStar
Any driver or device consistantly using 90% of your CPU is a bad investment. I am not a Dlink hater, since I use two Dlink routers.
You can go here, and get the most recent drivers for that adaper, and see if they help.
http://support.dlink.com/products/view.asp?productid=DWL%2DG550#
If the situation continues, and Dlink doesn't put out a fix, you might want to switch to a different brand. One other "fix" I have seen work on several problematic devices like this, is to disable the Dlink Wireless software, just keep the drivers, and use the Windows Wifi interface to control the wireless.
Good luck.
Posted on Jan 08, 2008
I am trying to connect my old lap top which has the DWL-650 card.....i am trying to connect to my wireless system which is verizon in my house....what must I do?
1. after pluged the DWL-650 card in your laptop need to install his driver.
2. After dirver installation you can connect your wi - wi - fi router.
Mar 25, 2010 | D-Link Air DWL 650 802.11b Wireless...
Dwl-520 PPPoE problem
Besides the DHCP/PPoE issue that cnavarro already said, I recommend you to check the interface metric, click on start, then on run, type cmd and click on ok
then in the black window type "netstat -r" that will tell you the metric of each interface according to each network destination, depending on what you see in there (like windows looking for a network trough another device) then just change the metric to 1 in your dwl520.
here is how to do it http://www.windowsreference.com/windows-2000/change-the-interface-metric-on-a-network-adapter/
Apr 18, 2009 | D-Link DI-514 / DWL-520 Kit...
How to make my DWL-2000AP works like a wireles card and is there any driver for it?
It sounds as if you want to use your access point to connect into a wireless network. A typical, simple wireless network includes (1) access points and (2) clients such as a wireless card in your laptop. Access points can only communicate with clients and clients only communicate with APs. However, many access points can be configured to be clients. Usually you would find that in the basic wireless setup page. I don't know if the DWL-2000AP can be set up that way, but you can check in the manual. If it can, then you would select that mode, then specify the SSID of the network you want to join.
Apr 15, 2009 | D-Link AirPlus Xtreme G DWL-2000AP...
I am not able to install driver for D-link wifi card
The card could be bad. I've found over the years that most of these desktop wireless cards work best when the software is installed before the card is installed. Meaning uninstall all the software. Turn off the machine. Remove the wireless card. Turn back on the machine. Install the software. Once installed, shut down the machine. Install the card. Turn back on the machine and lets Windows find the card and the software.
Mar 22, 2009 | D-Link AirPlus Xtreme G DWL G520 802.11g/b...
Driver for d-link dwl 520 wireless PCI card for LINUX OS
please go to the following web site and download the Driver and Instructions--
http://www.cyberciti.biz/tips/linux-install-and-configure-dlink-dwl-g-520-wireless-lan-pci-card.html
Nov 14, 2008 | D-Link Air DWL 520 802.11b (DWL-520)...
D-Link Airplus G DWL-G510 dose not start up
0) You must log as Administrator to enable your device
1) Check if the adapter has been installed
(My computer-->>Right click --Properties--->>Hardware--->>Device Manager---->>Network
2) You have to set the wireless connection
To set one do this:
Connecting XP
Click your Start Button
Select and click Control Panel
Select Network Connections
Select Wireless Network Connections
Right click
Select View Available Wireless Networks
5. Highlight the network you want to connect to
Click Advanced
6. Select the wireless network tab
7. Highlight the network in the available networks window
9. Click configure
9. IN the Properties Window
Double check the SSID (network name)
Enter the WEP KEY provided to you by the office
Click OK
Nov 12, 2008 | D-Link AirPlus G DWL-G510 802.11g/b...
Network card
i have D-link airplus G DWL-G630 wireless G notebook adapter i need driver wear i can get
Apr 07, 2008 | D-Link AirPlus DWL-G630 802.11g/b Wireless...
Can not get the IP
Make sure that your security1.gif password is correct.
Then:
start>control panel>administrative tools>services
Make sure your DHCP client and wireless1.gif zero client are started and set to startup type automatic.
Jan 15, 2008 | D-Link AirPlus G DWL-G122 802.11g/b...
D-Link DWL-G550 802.11g/b (DWLG550) Wireless Adapter Logo
148 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
