Question about Kenmore 16602 / 16604 / 16609 Built-in Dishwasher
Clean light flashing on a kenmore 665 16012401
The cleanlight flashes 7 times then pauses. it will only drain and thats it. the outher lights will come on but no function. can u please help
  • Anonymous Mar 14, 2014
    Genius:
  • 1,003 Answers
CHECK WATER INLET SOLENOID
Posted on Jan 18, 2008
I have a kenmore Utrawash dishwasher and the clean button is flashing
Ah, the famous (or infamous) Clean-light blinking problem. Watch that blinking light.... Does it blink 7 times, pauses, and repeats? Or does it blink 3 times (or some other number). The most common problem is 7 blinks which means "water not heating error". This could be caused by a bad heating element, a bad thermal cutoff, a bad controller.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Jul 19, 2014 | Kenmore Dishwashers
Clean light flashes and dishwasher will not work
when the clean light flashes its displaying a fault code based on the number of times it flashes...if it flashes 7 times then pauses then flashes 7 times again its displaying error code#7 if 4 times then pause its code#4 ect.
This tip i wrote will tell ya how to reset the board since sometimes its just electrical anomilie..reset the board and if it again flashes let me know how many times in a row it flashes and i will determine which error code it is , heres that tip to reset the control board http://www1.fixya.com/support/r10357661-get_whirlpool_dishwasher_start_when
GENE
Sep 26, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
The "clean" light is green, flashing.Dishwasher won't restart.
This is due to the water not heating properly. I have put together some instructions on how to reset the control so you can use the dishwasher again and what to check for as to why it failed. Follow the link and let me know if it was helpful.
Flashing Clean Light
May 23, 2010 | Kenmore 24 in. 17034 Built-in Dishwasher
Kenmore 665 17033400 Elite dishwasher clean light flashes 7 times and it wont run. i used the reset combination, all lights lit and stayed lit until i pressed reset. Then it started a wash. now the wash...
That signals an issue with a faulty heater &/or heater drive circuit.
(that info comes from their troubleshooting guide)
I ran into it this weekend and discovered that the heater coil in the bottom of the washer was broken.
Jan 14, 2010 | Kenmore 24 in. 17032 Built-in Dishwasher
Cleanlight blinks and wont let you do anything turn off power and still the same
Hi
Thanks for using FixYa. If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring).
It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 02, 2009 | Kenmore Dishwashers
Dishwasher not responsive, just a blinking CLEAN light.
HI, this is a control fault that is located in the logic sector of the circuit board. You will need to replace the control in order to restore proper function.
May 30, 2009 | Kenmore Dishwashers
The dishwasher won't start, the clean light flashes green 7 times
I have the same problem with ours Stock #17039 Type #575-0 Model # 665.17039401
Apr 14, 2009 | Kenmore 24 in. 16029 Built-in Dishwasher
Clean light flashes
You will have to reset the console. To do this, close the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Feb 11, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Clean light flashes constanly. Won't clear out to start new cycle
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
-high temp wash
-heated dry
-high temp wash
-heated dry
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Jan 03, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Sears Kenmore model# 665-16022401 Serial# FS0304946 - Clean Light Blinking
THE HUMMING NOISE THAT YOU ARE HEARING IS THE ELECTRONIC DRAIN MTR ACTIVATING BUT YOU HAVE NO WATER IN THE SYS. SO IT SOUND LOUDER AND DIFFERENT THE HUMMING IS THE LESS OF YOUR WORRIES THAT IS NORMAL BUT WHAT IS NOT NORMAL IS THE CLEAN LIGHT FLASHING IF IT FLASHES 7 TIMES THEN PAUSES YOU HAVEA BAD PROCESSING BOARD AND ALSO A HEATER ON SOME OF THE KM MODELS THE CONTROL BOARD AND HEATER IS SOLD AS A KIT. TO VERIFY THAT THIS IS THE CASE GO TO WWW.SEARSPARTS.COM . BUT FIRST ALSO CHECK TO SEE IF YOU HAVE A BURNT WIRE AT THE HEATER ASSEMBLY WHICH WOULD REQUIRE PULLING THE DW OUT. GOOD LUCK
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
Mar 12, 2008 | Kenmore 24 in. 15252 / 15254 / 15259...
Kenmore 16602 / 16604 / 16609 Built-in Dishwasher Logo
299 people viewed this question
Top Kenmore Dishwashers Experts
vince
D. E. Hev
gbob59
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
