Question about Viking DFSB483D
Viking DSB483D: freezer at +10F for 4 hours or more
I have a Viking DFSB483D which is roughly 2.5 years old. Suddenly it did not defrost anymore. Service has replaced the electronics, the thermocouples and the defrost thermostat. However, after all these fixes one problem remains (and it wasn't like this before): the freezer will stay at +10F for 4 hours or more, ice cream is very soft.
Any pointers highly welcome!
    Problem Solver:
  • 6 Answers
Check the evaporator coil for leakage.
Posted on Nov 13, 2009
Where is the drain hole located in the Freezer side of Viking DFSB483D? How can it be cleared?
you need to remove all freezer shelves and remove rear panel in freezer. under the coils is drain pan and drain hole.
May 25, 2017 | Viking Refrigerators
I have a Viking refrigerator/freezer model DFSB483D. The door to the fridge will not close by itself and must be pushed shut each time (seal is tight when it is closed). Is there a spring or other p
A simple test for the problem is : Remove everything from the shelves on the DOOR and test the closure. more than likely you have something colliding with inside shelf
Dec 02, 2014 | Viking Designer DFSB483D
Viking pro refrigerator DFSB483D can i change the wood panel to stainless?
yes you can, carefully pull off the wood and replace.
Jan 17, 2013 | Viking DFSB483D
Fridge is no longer cool, it's warm even on the coldest setting and everything in the freezer has thawed out with same setting. fridge is 11 years old. repair or replace?
Hi and welcome to FixYa, I am Kelly.
I note this question is not over 3 hours old so this is probably a 2nd opinion.
Actually it depends on the condition of the compressor. From the symptom that I am reading the compressor is not running at all. This can be caused by a defective defrost control or defrost thermostat. It can also be caused by something as simple as a PTC relay / KliXon thermal overload on the compressor or the run capacitor for the compressor. I would at least have it evaluated by a technician before making the decision to replace it. However... if the internal material condition of the compartments and shelving is severly degraded you may want to think twice about investing roughly $150.00 in a service call and parts to get it going again if it has mechanical defrost circuit controls. The real key is for you to find out if the compressor rotor is LOCKED or not. If the compressor is not locked or GROUNDED it is probably worth the repair cost. If they tell you that you need a new compressor the parts alone will run $235.00 + freon + labor + service call. It adds up fast.
Since you did not include the model number I do not know if you have the mechanical or electronic defrost control The mechanical one is around $35.00 and the electronic one is around $85.00. If you have a unit that has all the bells and whistles the control board can run $185.00 That is why I needed a model number. Given the unit is 11 years old I am assuming it has a mechanical defrost control.
Thanks for choosing FixYa,
Kelly
Apr 19, 2011 | Kenmore 54739 Side by Side Refrigerator
Pilot wont stay on furnance in the garage. About 20 years old
clean pilot and change thermocouple see if this works
Jan 07, 2011 | Dayton Gas Furnace Heater
Our Viking oven is not heating up? what can we try before calling for service? It is only 2 years old.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems
Replacing the Igniter
heatman101
Dec 11, 2010 | Viking Ovens
Anyone know what causes condensation on the bottom of the freezer door? seems to beed up on the gasket, but the gasket seems to seal fine. A service guy actually came out and said the gasket is not the...
There often is a heating strip that runs inside there that keeps a bit of warmth there so that condensation does not form....
The heat strip is bad ans as far as I know it is not replaceable...
heatman101
Aug 31, 2010 | Viking Designer DFSB483D
Viking refrigerator with bottom freezer always running
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Jul 05, 2009 | Viking VCBB363L Bottom Freezer...
My viking refrigerator freezer won t freeze
A lot of problems have been reported with this model,with the defrost timer not moving,Like a clock stopping,the defrost timer has stopped,and won`t allow the compressor to freeze the freezer unit.Most likely not to cool in the refrigerator either is it?If I can help anymore,let me know,but have the defrost timer checked or replaced.
Jun 12, 2009 | Viking 42 in Built In Professional...
Viking DFSB483D Logo
109 people viewed this question
Top Viking Refrigerators Experts
Dan Webster
Dan Webster
Jay Finke
Jay Finke
Joseph Hoffmann
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
