Canon pixma mx308 check printer Error 5100 - Computers & Internet
SOURCE: canon pixma mp530 problem error code 5100
i had the same problem. aall i did was open the printer up and moved the thing that holds the cartridges to the middle by hand. mine seems to be working fine. post again if its still not working.
Posted on Nov 16, 2007
SOURCE: Service error 5100 on my canon Pixma mp110
just replaced the ink cartridges and reset the counters, evrth ok now :-)
Posted on Nov 09, 2008
  • 412 Answers
SOURCE: Canon Pixma MP830 error 5100
As a technician, I have worked on tons of printers. This particular error had stumped me for a while, but I finally found the cause. As others had pointed out before, it can have alot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. You're on the right track - I found the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display) Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corrosponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on) Hope this helps some of you out.
Posted on Mar 09, 2009
yboyandrei
  • 828 Answers
SOURCE: Canon PIXMA MP180 All-I-One It shows check printer 5100 erros
error 5100, this error appears and the problem is your cartridge, please double check your cartridge is connect properly and if it still have the errors change another cartridge, a new one...
Posted on Jun 22, 2009
  • 33 Answers
SOURCE: error 5100
- Carriage unit
- Timing **** strip film
- Logic board ***'y
- Carriage motor problem
Posted on Sep 13, 2009
Error 5100 for canon mp 287
Error 5100 for canon mp 287 - Canon PIXMA
Dec 22, 2013 | Canon PIXMA MP287 ALL-IN-ONE INKJET...
I am unable to download the driver of MX308
Is this cannon pixma 308 if yes then you can download drivers from the following links:
http://downloadnew.org/software/driver-mx308/
http://downloadnew.org/software/driver-canon-mx308-download-for-windows-7/
http://support-sg.canon-asia.com/P/search?model=PIXMA%20MX308&filter=0&menu=Download
i think that'll be enough :)
Feb 16, 2011 | Office Equipment & Supplies
I just need a software to be able to us my PIXMA MX308' Thank you!
Log on to "http://ptf.com/canon/canon+pixma+mx308+driver+download+free/"
Nov 22, 2010 | Office Equipment & Supplies
My printer is pixma canon mx308.when printing,the paper always jammed.how to solve this problem?error code 5100
This particular error has a lot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip.You can find the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display). Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corresponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on).
Thank you !!
Jul 22, 2010 | Canon PIXMA MX300 All-in-One Printer
Jun 22, 2009 | Canon PIXMA MP180 All-In-One InkJet...
Canon MX 308
How to reset canon MX 308 ??
Error Code 5800
Any Software to reseter this printer?
Feb 24, 2009 | Canon PIXMA MX310 All-In-One Printer
I have a Canon pixma ip1600 and it won't print. It just says service error 5100.
5100 is a carriage error, check the timing strip for contamination(plastic strip about 1/4" in width)
The unit is not homing, check for obstructions.
Jan 22, 2009 | Canon PIXMA iP1600 Printer
Mp145 ink
Canon PG-40 Black
High Capacity Canon PG-40 Black Ink Cartridge
Pixma Series: iP1600/ iP1700/ iP1800/ iP1180/ iP1200/ iP1300/ iP1880/ iP2200/ iP2500/ iP2580/ iP2600/ MP150/ MP160/ MP170/ MP180/ MP450/ MP460/ MP470/ MP470SE/ MP140/ >>>>MP145<<<<
MP210/ MX300/ MX308/ MX310/ MX318/ iP6310D
Canon CL-41 Color
High Capacity Canon CL-41 COLOR Ink Cartridge
Pixma Series:
Jan 08, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Canon ip2000 service error 5100
I have been facing same error and this was the solution.
Canon Error 5100
Sep 08, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Computers & Internet Logo
1,641 people viewed this question
David Payne
David Payne
