Question about ASUS DVD-ROM |DVD-E616A2 BG R DVD Drive
My asus dvd rom ejects when inserting a disc. I have to insert a disc atleast 20 times to play it.
  • 466 Answers
It's probably just dirty opticals. Try running a CD cleaning kit a couple of times.
Posted on Nov 13, 2009
DVD player wont eject dicks or play just say's disc error
You need to insert dicks into the DVD player, also, once it ejects the dicks, you should wait 20 minutes or so before attempting to eject more dicks.
Jun 26, 2012 | Televison & Video
Wat should i do when is displays no disc
Hello
If your DVD player shows no disc, even a disc is inserted, try to clean its laser head assembly, by inserting a cleaning disc in it and play atleast three times. Take it ejected each time before you play it. If it does not helps, open the top cover of your DVD player, insert a disc, and notice if the disc spins or not. If disc spins, and not reads, the laser picup unit of your DVD player is faulty, and should be replaced with same type and number. If its stripe wire connected between pickup unit and main board is detachable, try repalcing the strip wire first. In some occations, bad strip wire will show this type of problem.
If disc does not spins, the sled motor [the motor that used to spin the disc at high speed], is damaged and shoud replace it. OK.
Apr 07, 2011 | GE DGE100N DVD Player
A dvd is stuck in the drive. It resists all attempts at removal including the ''eject cd'' command in Open Firmware. Can I manually remove it?
The iMac (Slot loading) computer's disc eject mechanism is electrical instead of mechanical. To eject a CD-ROM disc at startup that contains system software, press the mouse button until the computer ejects the disc. If the disc does not contain system software, wait for the iMac to start up and drag the disc icon to the Trash.
If either of these steps fails to eject the disc, push the drive's manual eject button with a small, blunt object like a paper clip. This button is located to the right of the CD/DVD slot as shown in Figure 1. The computer must be turned on to eject a disc in this manner.
ht3007_1.gifFigure 1 Manual eject button
Once the disc is ejected, it extends just beyond its center hole so you can remove it from the drive. If the disc fails to eject, while holding in the paper clip, use another CD to gently push against the inserted CD. This gentle pressure may help to release the inserted CD.
Important: After ejecting the disc with the manual eject button, you must restart the iMac in order for the CD-ROM or DVD-ROM drive to work.
DONT FORGET TO VOTE
Oct 10, 2009 | Apple iMac G4 Desktop
Dvd wont eject when you try to open it. or dvd wont play
i think the cd or dcd disc inside stuck-up you have to insert the tiny hole located at the dvd rom and insert a needle or something that is similiar or smaller of the hole size of that locted in your dvd rom.usually its new the LED blinking when opening or inserting the disc. and now you can now eject your disc manually regarding your question about it won't play a dvd try first to clean your DVD disc with a micro fiber cloth, avoid you'll scratch it, if still the same i think you're dvd room is defective.
Oct 08, 2009 | Bose (321GS) System
I inserted a disc (dvd) it will not eject. any
If the disk will not eject but however you got full power to the dvd rom then the dvd rom will need to be removed from the laptop and then opened up to manaul eject the disk.
Jun 30, 2009 | Dell Studio 15 Laptop
I purchased a CD-Rom advertised on Amazon as compatible with Asuseeepc and I wanted it for use with the DVD support disc. It works fine with cds but does not recognize dvds when inserted. I have been
A CD-Rom will only recognize CD's. It must be a DVD-ROM to recognize DVD's. DVD-ROM will recognize CD's ,but not the other way around. No drivers needed for thes, they are plug and play.
Char S.
May 20, 2009 | Teac PortaCD 224PE External 24x CD-ROM...
ACER 4520 CD-RW/DVD-ROM its pops up insert disc
you can try two solutions
1) go to device manager and uninstall the primary and secondary ide controller under the IDE ATA/ATAPI controllers and than restart the system and than chk it if that works out
2 ) if the first option doesnt work try to update the firmware of the drive
Sep 09, 2008 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Magnavox DVD Video Player DVD609AT
DVD609AT:
The manual is available at Philips website, the number for more info in manual is out-of-date; the new number is 1-800-605-8610
This unit has a problem when playing dual-layer discs of some kinds - read the warnings on the Magnavox website - playing the wrong kind of disc will cause an error that will require svc/repalcement to fix
Playable Discs
This DVD Player will play Digital Video Discs (DVDs) and Audio CDs. In order to play a
DVD or Audio CD on this DVD Player, make sure the Disc meets the requirements for
Region Codes and Color Systems as described on this page. Also, the Discs should have
the following logos and should meet these standards.
• CD-ROM
• Compact Disc-Interactive
(CD-I)
• Compact Disc-Recordable
(CD-R)
• Digital Video Disc-Video
Recordable (DVD-VR)
• DVD-RAM
• DVD-ROM
• Super Audio CD (SACD)
• Photo CD
• Video CD
• Video Single Disc (VSD)
Digital
Video
Disc
12 cm
12 cm
Approx. 4 hours
(single-sided)
Approx. 8 hours
(double-sided)
Approx. 80 minutes
(single-sided)
Approx. 160 minutes
(double-sided)
20 minutes
8 cm
8 cm
(singles)
Logo
Maximum
Disc Type Contents Playback Time
Sound
and
Pictures
Audio
CD
Disc Size
Sound
74 minutes
Disc
Segments
DVDs are
divided into Titles,
which are divided
into Chapters.
Titles and Chapters
are numbered.
Audio CDs are divided
into numbered Tracks, i.e.,
a track may be one song.
Unacceptable Discs
If you insert an unacceptable type of disc, “Please insert a playable disc” will appear on
the TV screen. Also, “- - - - - “ will appear on the DVD Player display panel. Insert a
DVD or Audio CD. The following Discs will not play on this DVD Player.
• CD-ROM
(CD-I)
(CD-R)
Recordable (DVD-VR)
• DVD-RAM
• DVD-ROM
• Photo CD
• Video CD
May 28, 2008 | Philips Magnavox DVD/VCR Dual Player
Samsung sh-s182 not read cd's and dvd's
So you mean each time you insert the disc it ejects automatically?or you have a problem reading with the disc?
May 09, 2008 | Computers & Internet
Dvd disk won't eject???
this is device do not play dvd-video, onli dvd-rom with maps for gps-navigation.
Apr 28, 2008 | Eclipse AVN5495 Car DVD Player
Computers & Internet Logo
201 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
