Question about Haier HP50B 50 in. Plasma Television
Cannot adjust TINT control using HD inputs!
This model seems to have a MAJOR design flaw. You can only adjust the TINT when using the SVHS or TV inputs! When using anything plugged into the HDMI or component video inputs, the TINT adjustment is FIXED!!! I watched a Simpsons DVD and they looked a bit green. I was UNABLE to adjust the tint to correct this issue! POOR design! Are ALL plasma TV's like this??
SOURCE: Progressive Scan Problem (works sometimes)
This is a service bulletin for the 42ep24s.
Posted on Dec 03, 2006
SOURCE: Haier TV model 42HP25BAT
I have the Haier plasma..Model # 42EP24S and as others it has went to a black screen with only audio...Is there something I can do to fix this....Thank you for all help. Alison
Posted on May 05, 2008
  • 85 Answers
SOURCE: how to connect hdmi
yes there is but pretty expensive you can search on Amazon but here is one http://www.amazon.com/HDmi-Ypbpr-VGA-Audio-Converter/dp/B001KUSYFW/ref=sr_1_26?ie=UTF8&s=electronics&qid=1235781002&sr=8-26
Posted on Feb 28, 2009
  • 8457 Answers
SOURCE: Sound fine with HDMI input and DVD input. No
Unplug the tv about an hour,replug it back in,now ur tv it resetting it back to factory setting.Go into the tv menu,go into the AUDIO setting.Go down to reset,press it,now ur Tuner board it resetting,the sound should come back an work now.Not then ur Tuner board it defective,must be replaced.
Posted on May 14, 2010
SOURCE: INPUT and MENU do not work
Your main pcb assy has shorted out. Replace it and it will fix your problem. part #tv-5210-173
Posted on Aug 18, 2010
Unable to adjust the tint
I think your TV may not have this option at all. However, I can also come up with other ideas:
Some adjustments might become unavailable depending on the input or content, have you tried adjusting this parameter in different inputs? e.g. TV channels, HDMI, composite, component? Or different content? e.g. HDMI input but with a signal from a bluray player playing a bluray disc vs. signal from a bluray player playing a DVD. If you don't see the tint "unlocked" in any of these different scenarios the option might as well be natively unavailable.
Nov 21, 2013 | Proscan PLDED3273A 32" LED 720p HDTV with...
ONLY HD picture does not fit on WS-55805
To be kind you are wasting your time, This is a 1st generation HD set not designed for the modern equipment you are using---You cannot turn a Model A Ford into a Roll Royce.
I has only one HD input designed for a set top HD box providing it a 1080 I signal.
Dec 04, 2012 | Mitsubishi WS-55805 55" Rear Projection...
Can't adjust tint in 50 HD Digital LCD TV Element
I called Element TV they said the Tint adjustment/controls on most Digital Element TVs are programmed for "Non adjustment"with digital signals:
On Large Element TVs , the "Tint" controls are used only for Analog Video and for NTSC viewing, but the controls are inoperative or blanked-out when watching PAL or SECAM digital signals (my is HDMI directly from Digital cable box).
Dec 02, 2012 | Element Televison & Video
WE BOUGHT A2006 MODEL SONY PROJECTION TV MODEL # KDS-50A2000 WE BOUGHT IT 2006. ABOUT 6 MONTHS AGO WE STARTED SEEING GREEN TINT WE TRIED TO ADJUST COLOR BUT NOTHING HELPED. I WOULD LIKE TO KNOW WHAT CAN BE...
The tv light projection engine block are starting to have a problems.This is the tv a major functions component part of the tv beside the tv front picture screen panel itself.This tv design have major flaw in it light projection engine block.This is the major problems and design flaw.Tries Sony Corporation themselves say u need to talk to a Manager or a person above customers services.Discussion with him or her might get some help for u with the some money help for replacing or trying to repair the tv light engine projection block.Because this thing 90% the cost of the tv almost the same prices as a new tv itself.
Aug 27, 2011 | Sony KDS-50A2000 50" HDTV
I have a TT1620 but with the new HD antenna, I can not get the TruTech to find any channels.
Out of the several hundred reviews I've found on this product, exactly two gave it a passing grade. The vast majority of complaints were the flaky/useless tuner, and the flaky/useless DVD writer. The writer issue seems to be mitigated somewhat by using Memorex blank media. The tuner issue seems to be a design flaw. The only work around I've found has been to use the other inputs and use a cable or satellite box for tuning.
Sorry, but it sounds like you got one of the many duds. Wish I could offer more encouragement.
Jul 06, 2011 | TruTech TT1620 DVD Recorder
Need lg 32lh30 calibration specs
I think I have a solution involving far less effort. Have you tuned your picture settings? Out of the box, the settings are ok and the presets will do the trick for most. But if you're like myself, you want the best picture possible. Here are my settings:
Picture menu:
Aspect ratio: Just Size
Energy Saving: Off
Picture Mode: Expert 2
Backlight: 35
Contrast: 90
Brightness: 54
H Sharpness: 40
V Sharpness: 42
Color: 50
Tint: 0
--Expert control menu
Dynamic contrast: Off
Noise reduction: Off
Gamma: Medium
Black level: Low
Real Cinema: On [grayed out]
Color Standard: HD [grayed out]
Color Gamut: Standard
Edge Enhancer: Off
xvYCC: Auto [grayed out]
OPC: Off
Expert Pattern: Off[grayed out]
Color Filter: Off
White balance: Warm
Method: 10 point IRE
Pattern: Outer
IRE: [see below]
Luminance: 137
-- 10 point IRE calibration
IRE: [Red, Green, Blue results, respectively, for each IRE point]
100 [-8, 1, -40]
90 [-13, -5, -40]
80 [-20, -12, -40]
70 [-17, -14, -33]
60 [-17, -12, -31]
50 [-17, -13, -26]
40 [-13, -12, -19]
30 [-6, -4, -8]
20 [-6, -4, -10]
10 [2, 3, -1]
Color management system
Red color: 2
Red tint: 0
Green color: -1
Green tint: -7
Blue color: 2
Blue tint: 7
Yellow color: 0
Yellow tint: 1
Cyan color: 0
Cyan tint: 0
Magenta color: 0
Magenta tint: -2
These are taken from CNET.com
Nov 08, 2009 | LG 32LH30 32 in. LCD HDTV
Green tinted people
The only time I have had issues like this was because of the Component Cables not being in the right position (the Red and Blue connections switched), or a bad Component Cable where the Blue Connection is not receiving a signal. Swap out the cable to be sure and double check that it is properly installed. Green to Green, Red to Red , Blue to Blue.
Hope this helps,
skyassoc
Jul 18, 2009 | Samsung HLN5065W 50" Rear Projection...
Philips LCD HDTV -- color problems
I am having the same issue. I believe the issue to be somewhere in the transition between HD channels and non HD channels. A work around is to switch the input to another input such as DVD and then switch back to your cable input (mine is the HDMI input). I'm probing the web looking for why this happens and if there IS a permanant fix.
Nov 19, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Vizio liquid crystal tv l32hdtv
Check the cable connections and/or replace the cables to the AV2 input.
If replacing the cable doesn't provide a solution, try running your DVD through the input. Since it works fine now, you would be checking the input AV2 by putting your working DVD. If the DVD plays with no problems, the input is fine.
Also try the VCR using coax into the TV instead of RCA into AV2. This will give you some idea about the condition of the VCR.
I suspect either the VCR or the cables.
Apr 22, 2008 | Vizio L32 32 in. LCD HDTV
Vertical Stripes on My Mitsubishi WS-65809 Projection TV
ADAM,
YOU NEED TO ADJUST THE SCREEN VOLTAGES TO BALANCE IT OUT. YOU CAN DO IT YOUSELF. HERE IS A WEBSITE. PLEASE READ THROUGH IT ALL. ITS FOR RED TINT OR LINES, BUT ITS USE IS FOR THE SAME PROBLEM AND COLORS. HOPFULLY, ON A LITTLE ADJUSTMENT IS ALL IT NEEDS.
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
PRIDAH
Nov 22, 2007 | Sony KP-57WS500 57" Rear Projection...
Haier HP50B 50 in. Plasma Television Logo
314 people viewed this question
Top Haier Televison & Video Experts
Jaime Hernandez
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
