Question about Loewe Articos 55 55" Rear Projection Television
Reset hours before installing new bulb - Loewe Articos 55 55" Rear Projection Television
  • rvonhoff Nov 13, 2009
    Thanks,
    How do you know if it is reset automatically and if not what is the process.
    I was told if it is not reset it will supply more amps to the lamp which could the damage or blow it.
    This is the second lamp replacement,the first I just replaced it and had no problems,it was lat the tv technician advised it was supposed to be reset.
  • Loewe Master
  • 5,138 Answers
You have to replace Lamp before resetting Lamp Timer and most of all the ones I have replace TV does it Automatically.But if you do have a problem on Menu go to Lamp Timer and reset.
Posted on Nov 13, 2009
  • ladywinn
    ladywinn Nov 14, 2009
    I have been repairing TVs for 32yrs ,another thing if Lamp is not working then you have No Picture so how do you think you are going to reset Lamp Timer without being able to See the Menu?
    In other words you cannot reset Timer untill you replace Lamp! Lamps are designed to play only 5000 up to 8000hrs so when you go to Lamp Timer see how many hours on Lamp does it have if it is telling you that you have over 5000 hrs then reset it back to 0.And Like I said Most all DLPs reset themselfs after New Lamp is install, Ive never had the first one come back due to Timer needing to be reset Nor have they ever been blowed back out because of not resetting Timer Hours.I hope this answers your question and think about it sometimes depending on Who gives you advice does not mean it is always The Right Advice,so when your not sure about what you have been told it is always smarter to keep asking untill you get the correct advice.God Bless have a Wonderfull Day.
How can i reset my lamp?
Posted on Jun 30, 2010
I have two issues with the pb8220 1. How do you reset the bulb hrs when a new bulb is installed? 2. Projects for about 10 seconds then goes black. The red bulb light comes on when the screen goes...
Reset the lamp hours as follows.
Press the Exit button on the projector for 3 seconds to display the total used lamp time. Press the MENU button on the projector during the lamp hour message. An adjustment message will appear. Press left or right arrow to reset lamp hours or press EXIT to leave.
sonsunny
Jul 09, 2011 | BenQ PE5120 Multimedia Projector
I Put a new bulb into projector and it still says to replace bulb. How do you reset the projector to clear this
hi,
You have to reset the lamp hour timer. just search for the procedure for lamp hour reset in its operation manual.
ok
Apr 28, 2011 | ASK Proxima C180 Multimedia Projector
I have a Sanyo PLC-EX20 projector which shuts down after five minutes, what could cause this?
There are 2 possible causes.
The first may be due to overheating. Most projectors have a "air filter" that can be removed and cleaned. If it gets clogged with dust over time, the projector can't breathe and shuts down.
The second cause may be your lamps life hour clock. Most projectors keep track of the amount of time that their bulbs have been active. Once a preset # of hours has passed the projector will limit functionality until a new bulb has been installed AND the lamp life clock reset. Most projectors do not automatically reset the lamp life clock after a new bulb is inserted.
There should be instructions on how to reset the lamp clock in your users manual, and info on cleaning the air filter. Unfortunately I went to the Sanyo website and was unsuccessful in locating a PDF of the user manual for you.
Mar 04, 2011 | Sanyo PLC-XE20 (Chassis XE2000)...
I have a VPL-CX70 that has a new lamp (less than 50 hours) and the hours were reset to 0 when the new one was installed. However, today, the lamp cover LED started blinking and the projector shut itself...
The bulb is not lighting correctly.
Take out the bulb and check the connectors are not dirty and reinsert.
See if you can see the bulb looks ok, you may be unlucky that the bulb has prematurely failed (hope not)
Try again to start it.
Please dont forget to vote this answer was helpful
Many thanks
Feb 17, 2011 | Sony VPL-CX70 Multimedia Projector
Replaced bulb last nite, green light blinks for a min. then it worked! watched a few min.turned on this morning blinking.... wont stop green blink. last nite when i changed bulb tv said change bulb reset...
Many projectors use a lamp hour timer for predicting bulb life so they can give you fair warning of impending failure. Since a bulb may be removed and reinstalled because it is still working or another used lamp installed, the timer is not automatically reset to zero when the lamp is replaced. I surmise your set is complaining because the timer was not reset or the time verified when you changed the bulb.
To fix the problem, buy or borrow a remote control; a universal remote control with a menu button may work. (If you borrow a universal remote from a friend, be sure to record the code for your friend's TV first so you can set it back before returning it.)
You could probably get back into the timer reset menu by removing the new lamp and reinstalling it. Caution: follow the directions on page 68 of the user's manual or the sheet that came with the bulb - let the set cool for an hour first, unplug, and wear gloves when handling the bulb since skin oil can cause discoloration and possibly an explosion when the bulb gets hot. You can download the user's manual from Panasonic's support page for this set.
If you can edit the timer hours instead of just resetting, you may want to set it for the number of hours the new bulb has been used.
It is likely that you can get into the lamp timer menu if the set is in service mode, but the user's manual doesn't tell how to get there (I don't have that info either - it's in the service manual, which may be available online from a third party for a price). Usually it is something like holding a volume or channel button on the front of the TV while turning it on with the remote control. After that you need the code to switch to the timer menu. If you have problems getting into the timer menu, ask your dealer's service department or try calling the Panasonic help line listed on the bottom of page 68: 1-888-VIEW PTV(843-9788).
Oct 16, 2010 | Panasonic PT-40LC12 40" Rear Projection...
Mitsubishi HC 900 DLP Projection Lamp Shutdown.
Honestly I would try entering the 'Lamp timer reset' code again. Or the button sequence given to reset the lamp timer.
An issue that may be happening is that something may have happened to the lamp ballast power supply also.
Just a thought.
Blessings always,
A/V Media Tech Guy
Nov 30, 2009 | Televison & Video
How to replace NEW ZENITH LG 31419SN984A DLP LAMP BULB LIGHT. I want to reset also my lamp hrs.
Please see link and find a thread click here. Here you can find the instruction that how to install the lamp.
For amp hour reset click here.
and for new part order click here.
thanks for using fixya.
Nov 08, 2009 | Zenith Z62DC1D Television
Lamp and temp lights come on after power up and stay on. Lamp only has 330 hours on it.
OK, that explains it. The bulb you have installed in the projector might be the original bulb that came with the projecoter when it was new. Just becuase it states 334 hours does not mean it is new. In fact, you could have a original bulb with 3000 hrs and reset the hour timer on the projector, which means your 3000 hour bulb might have 3334 hours on it because the person who owned it before you, reset the hour timer.. Best bet, buy a new bulb and reset the hour meter and see what happens. If you have the same problem, then your ballest might needs to be replace which is rare...
May 30, 2009 | ViewSonic PJ400 Multimedia Projector
New bulb installed and it takes 10 plus minutes to start
Exchange the lamp under warranty...
You've tried almost everything else.
It's not that uncommon to experience "infancy failure" with a brand new lamp.
If the problem persists with the replacements replacement then I would suspect the Lamp power supply (Ballast) is failing.
Dec 14, 2008 | InFocus ScreenPlay 4805 Multimedia...
Reset lamp hours for new bulb
Is it a Sony VPL CS4? Try [Reset], [<-], [->], [Enter] keys
Aug 18, 2007 | Philips UGO X-Lite Impact Multimedia...
Loewe Articos 55 55" Rear Projection Television Logo
376 people viewed this question
Top Loewe Televison & Video Experts
Jerry Umali
Grantec 2000
Level 1 Expert
Are you a Loewe Televison and Video Expert? Answer questions, earn points and help others
