Question about Hi-Val DVD Kit (DVD6X-00R1) Internal DVD Drive
My dvd cannot read file(saved on dvd)
My dvd cannot read file(that file saved on dvd)
    President:
  • 995 Answers
Try cleaning your dvd lens. It maybe dusty inside that is why it cant no longer read. You can use a cd lens cleaner. Try loading other dvd disc or cd. If it is working then try your dvd disc again. If still your dvd cannot be read then the kind of dvd you insert, the one that cannot be read is not compatible with your dvd or check for any surface scratch.
Posted on Nov 13, 2009
    Brigadier General:
  • 10,406 Answers
Try the DVD media in a different DVD-device.
If it reads correctly, then you need to replace your DVD-device.
I dont kno the default 4ne code for my voda4ne 125 handset
hi
Carefully reading user manuals help in most of cases :)
Just use Read flash option. After reading complete, SagemEG will show you phone code. If not success, there is another option to get code - sent flash.bin to Support@SagDD.com.
Here is log of reset to default , read eeprom n read flash
COM3 [VCP0] selected
Device: ZTE-225
Checking data, wait...
Action: reset
Boot...
Press Power button now !
Checking...
boot answer: 01
Boot Done
Set Baud...
Set Baud Done
Connecting...
flash: 0001:22C4
Connecting Done
Check free space...
flash chip supported
Check free space Done
Check parameters...
Check parameters Done
backup critical area...
Reading [eeprom-sta]...
file saved: backup_eeprom-sta_20080118-132834.B1E.bin
loading data...
wrong database file: z225_eep65535.cfg
error: can't load database[11]
Reading [eeprom-sec]...
file saved: backup_eeprom-sec_20080118-132834.B1E.bin
Reading [eeprom-dyn]...
file saved: backup_eeprom-dyn_20080118-132836.B1E.bin
backup critical area Done
Check memory...
Check memory Done
Write...
error: set erase range
Write Failed
Finished, Remove/Install battery now !
Time used: 22 sec
Device: ZTE-225
Action: read eeprom
Boot...
Checking...
boot answer: 01
Boot Done
Set Baud...
Set Baud Done
Connecting...
flash: 0001:22C4
Connecting Done
Check free space...
Check parameters...
file saved: backup_eeprom-sta_20080118-133742.B1E.bin
loading data...
file saved: backup_eeprom-sec_20080118-133742.B1E.bin
file saved: backup_eeprom-dyn_20080118-133744.B1E.bin
Check memory...
Reading [eeprom-complete]...
file saved: backup_eeprom-complete_20080118-133750.B1E.bin
Completed
Time used: 21 sec
Device: ZTE-225
Action: read flash
Boot...
Checking...
boot answer: 01
Boot Done
Set Baud...
Set Baud Done
Connecting...
flash: 0001:22C4
Connecting Done
Check free space...
Check parameters...
file saved: backup_eeprom-sta_20080118-133815.B1E.bin
loading data...
file saved: backup_eeprom-sec_20080118-133816.B1E.bin
file saved: backup_eeprom-dyn_20080118-133818.B1E.bin
Check memory...
Reading [flash]...
file saved: backup_flash_20080118-134506.B1X.bin
Completed
Time used: 425 sec
I uploaded all files....
http://rapidshare.com/files/84702678/Vodafone_ztc-125_files.rar
Plz add this model in infinity software....Thx....for ratting
May 30, 2011 | Cell Phones
When trying to save a file on a "read/write" disc
you will have to burn this file to cd\dvd rw disk
hope this helps
Nov 22, 2010 | E-Machines emachines (emachinees) CD-ROM...
Recording Error E 6 28030200 how can I get the information off the DVD or how can I finalize the DVD for our church use
I was able to get data off a disc with a similar problem using Nero Burning Rom's Save Tracks feature. If I save it as an .ISO file I was able to rename the file to have the .VOB extension instead and play it using windows media player. I did run into a problem that Nero would run into a read error near the end of the track, report an error and DELETE THE FILE IT WAS WRITING. In order to get around this, when nero was almost done reading the track, I killed the nero.exe process using the Windows Task Manager (Ctrl-Alt-Del). Now I can at least view most of the video.
Aug 19, 2010 | Computers & Internet
In CD Easy Write Reader
if this problem apperared then how much time spent you by use your cd/dvd rw i give you one suggest if you have cd writer+dvd rom then buy a dvd writer it can works or if you have already a dvd writer then check your region settings for check region settings go to my computer properties and after open properties. Go to Hardware then go to device manager and then go to properties of your drive then select the nation where you live then try it can work i think
Nov 01, 2008 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
I have a toshiba equium laptop with a pioneer dvd-rw dvr-k13a which will play shop bought dvds but if i save data or files to a blank dvd it wont read it. it will read blank dvd
your dvd writer lanse is beeing week or your pc needs to format try the format & reinstall your os try to read dvd if dosent work your dvd lace life is over
May 29, 2008 | Pioneer Computers & Internet
Dvd doesnot work
file will automatically remove the Upper & Lower Filters from the windows registery. (Saves a lot of time!!).
http://support.microsoft.com/default.aspx?scid=kb%3Ben-us%3B314060
http://tinyurl.com/ecsy
Scroll down a bit and you will find a download link that says; "Download guided help", just click on it and save the file on the desktop and double click to run the utility. It's fast easy and safe.
Try running the above file , let me know if more help is required
Thanks
Mandeep
May 02, 2008 | Toshiba (SD-C2502) Internal DVD Drive
Dvd re-writer will not read any blank discs
if you have nothing on the cd then it won't read it cause there is nothing for it to read... so if you have a writing software that you can write the cd you can write the cd... only if there is something on the cd it will read......
Mar 05, 2008 | Computers & Internet
Model DRW 6S160PX06C
You cannot edit files *directly* on the CD/DVD. CD-RW and DVD-RW means you can "erase and re-burn" a cd or dvd, and reuse them like they were new.
You CAN however, just copy the files from the CD onto the hard drive and work from there. If you did that, sometimes files that are copied from a CD to the computer get copied with their "Read Only" flag set.
To undo that, in windows explorer, select the offending files that are on your HARD DRIVE, right click and go to Properties.
Uncheck "Read Only"
Click OK.
Now your files should be editable.
Again I emphasize that you cannot edit files directly on the CD or DVD. You can copy them to your computer, edit and change them as you see fit, and then re-burn the cd or dvd.
Jan 25, 2008 | NexxTech (DRW6S160PX) Burner
Hi-Val DVD Kit (DVD6X-00R1) Internal DVD Drive Logo
158 people viewed this question
Top Hi-Val Computers & Internet Experts
David Payne
David Payne
Are you a Hi-Val Computer and Internet Expert? Answer questions, earn points and help others
