Question about Microsoft Xbox 360 Console
Console will not connect to my wireless network
    Scholar:
  • 203 Answers
First off, make sure you have a wireless connector on your console. The new Elites come with one. If you don't you'll need to buy one (100 US dollars or so)
If you have one and it's still not connecting, make sure that your security settings on your network router are set to allow your xbox TO connect. I've found that if you have security settings set up that the 360 tends to have troubles connecting to a wireless network. Either open up your settings, or use a direct connect Ethernet cord, which bypasses the wireless security, to connect directly to the router
Posted on Jul 29, 2010
Cant connect to xbox live
What you need:A high-speed Internet connection such as cable A router, gateway, or wireless access point (WAP) that is compatible with Xbox LIVE. An Xbox 360 Wireless Networking Adapter (original Xbox 360 console only) Instructions: On your console, go to My Xbox, and then select System Settings. Select Network Settings. Select the name of your wireless network. Enter your wireless network password. Select Yes if you are prompted to update your console software. When you successfully connect to Xbox LIVE, your screen will look like this:
Jul 25, 2011 | Microsoft Wireless Network Adapter Xbox...
Tip
How to connect your Xbox 360 to the internet
In this guide I will go over how to connect your Xbox 360 to the internet either via wired or wireless connection.
Wireless Connection
*For a wireless connection you need a wireless access point(router) and either a Xbox with built in wifi adapter or purchase a xbox wireless adapter*
-Turn on your xbox and go to "My Xbox" then go to "System Settings"
-Select "Network Settings"
-Select the name of your wireless network.
If you do not see your network, select "Advanced options" then select "Specify unlisted Network" then enter your network name.
Enter your wireless network security key. It may prompt you to update your console, select yes.
Wired Connection
*For a wired connection you need to use an Ethernet cable and plug one end into the back of your xbox and the other end into your router or cable modem.*
-Select "Test Xbox Live Connection", afterwards it may prompt you to update your console, select yes.
Now, you are connected to the internet and can enjoy xbox live.
Regards,
G33k
on May 12, 2011 | Microsoft Xbox 360 Console
Tip
Setup your Xbox to a Wireless Network
Xbox game consoles can be connected <span style="text-decoration: underline;"></span> to a router<a href="http://compnetworking.about.com/cs/routers/g/bldef_router.htm"></a> for wireless access to the Internet and Xbox Live. Follow these instructions to set up the Xbox or Xbox 360 connections to a wireless home network.<br /><br /> <ol> <li>Connect the appropriate wireless network adapter<a href="http://compnetworking.about.com/od/hardwarenetworkgear/g/bldef_adapter.htm"></a> to the console. On the Xbox, a Wi-Fi adapter that connects to the Ethernet sometimes also called a wireless network bridge must be used. Alternatively, the Xbox 360 is also designed to work with certain Wi-Fi <i>game adapters</i> that connect to a USB port.<br /><br /></li> <li>Turn on the console and navigate to the wireless settings screen. On the Xbox, the menu path is "Settings -&gt; Network Settings -&gt; Advanced -&gt; Wireless -&gt; Settings" On the Xbox 360, the menu path is "System -&gt; Network Settings -&gt; Edit Settings."<br /><br /></li> <li>Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there.<br /><br /></li> <li>Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.)<br /><br /></li> <li>Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead. Note that the standard MS Xbox Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP.<br /></li> <li>Save your settings and verify the network is functional.<br /><br /> On the Xbox, the Wireless Status screen displays whether a connection has successfully been made with the wireless router, and the Connect Status screen displays whether a connection has successfully been made through the Internet to Xbox Live.<br /><br /> On the Xbox 360, use the "Test Xbox Live Connection" option instead.</li></ol> Tips: <ol> <li>Even when your wireless connection between the Xbox and the router is working perfectly, you may still experience difficulty connecting to Xbox Live. These issues can be caused by the quality of your Internet connection or the firewall and Network Address Translation (NAT) settings of your wireless router. Additional troubleshooting may be required in these areas to achieve reliable Xbox Live connections.</li></ol><span style="font-weight: bold;">Troubleshooting</span><br /><br /> The built-in diagnostic of the Xbox can help with any falure.Navigate to the <i>System</i> area of the Xbox Dashboard, select the <i>Network Settings</i> menu option, then select <i>Test Xbox Live Connection</i> to run the test at any time. If the Xbox 360 built-in network diagnostic fails with the following message: <br /> <ul><i>Technical configuration error. Please contact Xbox Customer Support.</i></ul> This indicates a network issue requiring further investigation. The Xbox 360 network diagnostic contains the following tests run in the order listed below. Steps for troubleshooting Xbox 360 connectivity issues depend on which test reports the failure. <br />If you have an original Xbox 360 console, you need to attach an Xbox 360 Wireless Networking Adapter before you can connect your console to a wireless network.<br /> <b>Note</b> You can use an Xbox 360 Wireless Networking Adapter with the Xbox 360 S console. If your wireless router is not near your console, you may get a better wireless signal by using a wireless networking adapter. When you connect an Xbox 360 Wireless Networking Adapter to an Xbox 360 S console, the console will automatically use the wireless adapter instead of the built-in Wi-Fi.<br /> If you have an original Xbox 360 console, you need to attach an Xbox 360 Wireless Networking Adapter before you can connect your console to a wireless network.<br /><br /> Step 1: Attach an Xbox 360 Wireless Networking Adapter to the back of your Xbox 360 console.<br /> Step 2: If a network cable is plugged into the back of your console, unplug it. Step 3: Check the light on the Xbox 360 Wireless Networking Adapter.<br /> If you're using the black adapter with two antennas:<br /> <ul> <li><b>No light:</b> The adapter is not receiving power. Unplug the USB connector, and plug it in again. Still no light? Try plugging the adapter into a USB port on the front of the console.</li> <li><b>Green:</b> The adapter is connected to a wireless router, gateway, or access point.</li> <li><b>Flashing green:</b> The adapter is attempting to connect to a wireless network.</li> <li><b>Red:</b> The adapter is not recognized. Try plugging the adapter into a USB port on the front of your console. </li> <li><b>Flashing red:</b> There is a problem. The adapter might be experiencing a hardware failure.</li></ul><br /> Configure your wireless settings Go to <b>My Xbox,</b> and then select <b>System Settings</b>. <br />Select <b>Network Settings.<br /></b>Select <b>Configure Network</b>.<br /> <ol> <li>On the <b>Basic Settings</b> tab, select <b>Wireless Mode</b>. <br /> <b>Note</b> If Wireless Mode is still not available, there might be a problem with your hardware. <br /></li> <li>Select <b>Scan for Networks</b>. </li> <li>Select your wireless network name. <br /><br />If your wireless network is not listed, try either of the following:<br /> <ol> <li>Try improve the router signal by moving the router position.If you are not broadcasting your wireless network name, select <b>Specify Unlisted Network</b>, and enter your wireless network name and security type. </li></ol></li><br /> <li>Enter your wireless network password, and then select <b>Done</b>.</li> <li>Press the <b>B</b> button on your controller, and then select <b>Test Xbox LIVE Connection</b>. If you successfully connect to Xbox LIVE, you'll see this screen:Choose <b>Yes</b> when you are prompted to update the console software. <br /></li></ol>
on Jan 18, 2011 | Video Game Consoles & Games
How do you get connected to xbox live
What you need
  • A high-speed Internet connection such as cable or DSL
  • A router, gateway, or wireless access point (WAP) that is compatible for xbox live
  • An Xbox 360 Wireless Networking Adapter (original Xbox 360 console only)
Configure and test
Next you need to configure your wireless settings and test your Xbox LIVE connection. The steps vary slightly, depending on your console's software.
  1. On your console, go to My Xbox, and then select System Settings.
  2. Select Network Settings.
  3. Select the name of your wireless network.
  4. Enter your wireless network password.
  5. Select Yes if you are prompted to update your console software.
Jul 04, 2011 | Video Game Consoles & Games
How do i hook my mi-fi internet to the xbox 360? i have purchased an adapter and can not figure out how to get the internet working
Here's how to configure your wireless settings:
  1. On the console, go to My Xbox, and then select System Settings.
  3. If you are prompted to select a wireless network, complete these steps, otherwise skip to step 4.
    1. Select the name of your wireless network.
    2. Enter your wireless network password and select Done.
    3. The console will automatically try connecting to Xbox LIVE. If you get an error message, go to the following webpage for help: support.xbox.com/pages/xbox-live/troubleshoot/connection-issues/connect-xbox-live.aspx (http://support.xbox.com/pages/xbox-live/troubleshoot/connection-issues/connect-xbox-live.aspx)
    Note If you do not see the name of your wireless network, select Advanced Options. Then select Specify Unlisted Network and enter your wireless network name. Select your wireless security type (WEP, WPA, WPA, or No Security). This security type needs to match the security of your wireless network.
  4. Select Configure Network.
  5. On the Basic Settings tab, select Wireless Mode.
    Note If wireless mode is not available and you are using the black Wireless N Networking Adapter, try using the software installation disc included with the adapter. For more information about how to do this, please see the following article: 977641 (http://support.microsoft.com/kb/977641/ ) How to set up the Xbox 360 Wireless N Networking Adapter
  6. Select Scan for Networks.
  7. Select your wireless network name.
    If your network is not listed, try the following:
    1. Select Specify Unlisted Network, and enter your wireless network name (also referred to as your Service Set Identifier [SSID]).
    2. Select your wireless security: WEP, WPA, WPA2, or No Security (if your network doesn't have a password).
      If you can't connect to your wireless network, try improving your wireless signal using the tips in the following article: 909336 (http://support.microsoft.com/kb/909336/ ) Your Xbox 360 console receives a weak wireless signal
  8. Enter your wireless network password, and then select Done.
    Note Make sure that you have entered the correct password. An incorrect password might allow your console to connect to your wireless network, but you might receive an IP address error when you test your Xbox LIVE connection.
  9. Press B on your controller, and then select Test Xbox LIVE Connection.
Mar 07, 2011 | Microsoft Xbox 360 Console
I got a charter internet router thet hooks to the cable service it does not have a phone connection and I have a 2 wire 2701hg wireless router is there a way to connect the two for my playstation 3 in the...
Wireless Connection
  1. Write down your wireless network name (SSID -example 2WIRExxx) and the security key (WEP key)
    • If you are using an 3rd party(PlayStation) wireless networking adapter (sold separately from your system), connect the USB connector to the USB port on the back of the console. Do not use the front USB ports.
  2. Turn on your console and wireless device.
    • If you have a wireless-to-Ethernet bridge, turn on the device.
    • If you have an 3rd party (PlayStation) wireless networking adapter, the device turns on automatically with the console.
  3. Turn on your 3rd party(PlayStation) console.
    • If this is the first time you are turning on your console, complete the initial setup and create a profile before continuing.
  4. In the System area of the 3rd party(PlayStation) dashboard, select "Network Settings."
  5. Select "Edit Settings."
  6. From the Basic Settings tab, select "Wireless Mode."
    • You are asked to set your locale if you have not set it on the console. Your locale is the country or region from where you are connecting to3rd party(PlayStation) Live.
  7. Is your wireless network name (SSID - 2WIRExxx) displayed on the screen?
    • If it is displayed, select it.
    • If it is not displayed because you are connecting to a wireless network where the network name is not being broadcast, choose "Specify Unlisted Network". Select the security type for the network, and enter the wireless security settings for the network.
  8. Enter the WEP Key.
    • If encryption is disabled on your HomePortal, you will not have the option to enter wireless security settings.
  9. When prompted, select Test Xbox Live.
If the Xbox Live test reports Connected, congratulations! You are now successfully connected your Xbox 360 console to Xbox Live. Select "Edit Settings" to review your settings or Xbox dashboard (Y button) to begin gaming.
Nov 04, 2010 | 2wire (1000-000057-000) Modem
Cant connect to the wireless
in order for the xbox works wireless
you need to have a wireless network adapter from xbox
if you do have the wireless network adapter if it black it has a installation disc that comes with the packet
install the disc make sure that the wirless network adapter is unplugged before you inserted the disc you will prompted an update select yes for the update once it is done installing remove the disc and turn off the console and plugged in the wireless network adapter then press the guide button the silver button in the middle of the controller and go to settings blade and choose system settings,select network settings,then configure network it must have the option for "wireless mode" select this option and select scan for network,choose your network if it ask for WEP,WPA /WPA2 this is the passcode that you set for the wireless network.after you enter the WEP,WPA/WPA2 you are connected
if it is the white adapter all you need to do is pluggin the wireless network adapter while the console is turn off once you switch on the console test the connection and you will be prompted to update select yes for the update then press the guide button the silver button in the middle of the controller and go to settings blade and choose system settings,select network settings,then configure network it must have the option for "wireless mode" select this option and select scan for network,choose your network if it ask for WEP,WPA /WPA2 this is the passcode that you set for the wireless network.after you enter the WEP,WPA/WPA2 you are connected enjoy the game =D
May 27, 2010 | Microsoft Xbox 360 Console
It will not connect to the internet at all now it tells me that there is no access point in range and to check my SSid setting what is that
so that means your game console is using wireless connection. it's not detecting the wireless equipment(usually a wireless router) that it's connecting to. SSID is the name of the wireless network of the wireless router or access point. SSID is like an identification, so that your game console or wireless computer if they are connecting to the right equipment and not to your neighbor..
if you have other computers that are wireless and those are working right, it means the problem is on the game console.. try to power cycle the devices, turn off the modem, router or access point, computers and game console.. wait 1 minute, then turn on the modem first, router or access point next, then computers and game console..
May 08, 2009 | Video Game Consoles & Games
Link Your Console to Another Console
Console-to-Console Connection: Wireless Some Xbox games offer console-to-console, or system-link, play, in which two or more players (depending on the game) can wirelessly network their consoles for multiplayer use. Console-to-console wireless networks are also known as ad-hoc networks. In ad-hoc networks, a wireless adapter on one device connects directly to a wireless adapter on another device. An Internet connection isn't shared with this type of network, and the console-to-console connection is typically temporary. For console-to-console play, you need: Two Xbox 360 consoles. Two Xbox 360 Wireless Networking Adapters. An Xbox 360 game that supports system link play. To wirelessly connect your console to another console: Attach an Xbox 360 Wireless Networking Adapter to the back of each console as described in Use Your Xbox 360 Wireless Networking Adapter. On each console, go to the System area to enter your network settings. (They will be the same for each console.) If all settings are correct, exit the System area. The consoles should now be wirelessly connected to each other.
Nov 20, 2005 | Microsoft Xbox Console
Nov 20, 2005 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
49 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
