Question about Refrigerators
LG LFC25760SB french door light off but hot
Sometimes when we open the top doors the light does not come on but the light housing is hot. Is this a fire hazard? What can we do to fix it?
    Problem Solver:
  • 6 Answers
Try to replace the bulb/ door switch
Posted on Nov 13, 2009
How to replace lights on refrigerator LFC25760SB
In the LG bottom freezer refrigerator (model LFC25760SB), the light bulb covers inside the refrigerator and freezer compartments are attached using friction-fit clips.
It will be safest to unplug the unit, or shut off the circuit breaker. You may also need to remove Items, including the top 1 or 2 shelves.
Push the front of the cover gently toward the back of the refrigerator; LG's instructions show a screwdriver, but I would use something more flexible like an expired credit card or emty gift card. Swing the cover down to unhook the clips at the back.
Be careful with the bulbs, as they can get very hot, particularly if it takes some time to clear the way to the cover and get it off. I would close the door and wait a few minutes to let the bulbs cool off before removing them.
LG has a downloadable manual on their website that shows the procedure and gives the bulb specs (60 watt appliance type).
https://www.lg.com/us/lgecs.downloadFile.ldwf?DOC_ID=KROWM000110253&what=MANUAL&fromSystem=LG.COM&fileId=KROWM000110253.pdf&ORIGINAL_NAME_b1_a1=3828JD8991B%28ENG%29.pdf LG LFC25760SB Support Manuals Warranty More LG
Feb 28, 2018 | Refrigerators
Lights go off and on
your sensor sw is deff call for a tech to replaced
Jan 12, 2014 | LG LFD22860 Bottom Freezer French Door...
French door makes high pitched squeal when I open it
Lube will not help. The door needs adjustment. Look on top of the door where hinges are and try minor adjustment. You will need help to guide you.
Dec 04, 2013 | LG Refrigerators
LG LFC25760SB
Sounds dangerous and a fire hazard. Unplug it until you find the fault with the unit or replace the fridge.
Oct 11, 2017 | LG Refrigerators
The LG refrigerator door lights do not come on when I open the door every thing else works. French doors #LFC25760SW Hepl!!!
Were the doors left open at anytime? If so it has a thermostat that will shut off the lights to keep from getting too hot, If they werent left open, could be bad bulb or stuck or bad light switch on the door, all very easy fixes.
Sean
Mar 26, 2011 | LG Refrigerators
LG french door refrigerator, model # FRFD22850TT, light stayed on and food was hot. Hoe do we get the light repaired? Also, frost builds up on Rt. side of freezer even with the door always closed, no...
the door switch control the light. check the switch
defrost thermostat and heat element control frost, check all of them
if u live near madison . wi , i charge u $100 fix the problem . part may be $100
Jan 13, 2011 | LG LRFD22850 Bottom Freezer Refrigerator...
Door left open it turned off - how do I turn it back on
?? you left it open??? and now the lights arent workin is that correct??
if this is the case, no worry, the lights should havea built in thermosat that turn them off iff too hot( door left open) give it 20-30 min the lights will cool down and come back on.. its meant to do that soit doesnt coo yor food if the light switch ever fails
Oct 09, 2010 | LG LRFD22850 Bottom Freezer Refrigerator...
LG french doors, bottom freezer. Water leak from
Make sure your ic maker is empty. On the bottom of the ice maker is a small button. Watch the plastic fill tube and hold the botton in. Let the ice maker cycle anmd see if the water over shhoots rne ice maker. If it does, trim 1/8 of an inch off of the tube with a raxor knife on an angle = / this should take care of your problem.
Jan 14, 2010 | LG LFC25760SB 25 Cu. Ft. Panorama French...
Light remains on when fridge door closed. door switch does not turn lights off? light was hot enough to melt plastic cover
You can take the door switch out and replace it with a new one. You may also need to get an appliance light bulb that's not so hot.
Oct 10, 2009 | LG LRFC25750 French Door Refrigerator
My fridge has decided that the light in the top portion is going to stay on all the time. It got so hot that the light cover melted. I've taken out the light bulbs and everything else works fine. The door...
heck you door alignment to be sure when the door closes it is hitting th lite switch and turning the lights off. sometimes it is necessary to put shims on the door hinges to raise the door to cause it to hit the switch properly.
Jul 04, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
Refrigerators Logo
204 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
