Question about Motorola Mobility RAZR V3c Cellular Phone
Http error: 502 bad gateway - Motorola Mobility RAZR V3c Cellular Phone
Internal error 502
However, it is possible that there's something wrong on your end and we'll work through those possibilities below.
  1. Try loading the URL again by pressing F5 on your keyboard, or by clicking the refresh/reload button.
    While the 502 Bad Gateway error is usually indicating a networking error outside of your control, it could be extremely temporary. Trying the page again will often be successful.
  2. Start a new browser session by closing all open browser windows and then opening a new one. Then try opening the webpage again.
    It's possible that the 502 error you received was due to an issue on your computer that occurred sometime during this use of your browser. A simple restart of the browser program itself could solve the problem.
  3. Clear your browser's cache. Outdated or corrupted files that are being stored by your browser could be causing 502 Bad Gateway issues.
    Removing those cached files and trying the page again will solve the problem if this is the cause.
  4. Delete your browser's cookies. For similar reasons as mentioned above with cached files, clearing stored cookies could fix a 502 error.
    Note: If you'd rather not clear all of your cookies, you could first try removing only those cookies related to the site you're getting the 502 error on. It's best to remove them all but it won't hurt to try the clearly applicable one(s) first.
  5. Start your browser in Safe Mode. Running a browser in Safe Mode means to run it with default settings and without add-ons or extensions, including toolbars.
    If the 502 error no longer appears when running your browser in Safe Mode, you know that some browser extension or setting is the cause of the problem. Return your browser settings to default and/or selectively disable browser extensions to find the root cause and permanently fix the problem.
    Note: A browser's Safe Mode is similar in idea to the Safe Mode in Windows but it is not the same thing. You do not need to start Windows in Safe Mode to run any browser in its particular "Safe Mode."
  6. Try another browser. Popular browsers include Firefox, Chrome, Internet Explorer, andSafari, among others.
    If an alternative browser doesn't produce a 502 Bad Gateway error, you now know that your original browser is the source of the problem. Assuming you've followed the above troubleshooting advice, now would be the time to reinstall your browser and see if that corrects the problem.
  7. Download Software Update 1 for Microsoft Forefront Threat Management Gateway (TMG) 2010 Service Pack 1 if you have MS Forefront TMG SP1 installed and receive a Error Code: 502 Proxy Error. The network logon failed. (1790) or similar message when accessing a web page.
    Important: This is not a common solution to 502 Proxy Error messages and only applies in this particular situation. Forefront TMG 2010 is a business software package and you would know if you have it installed.
  8. Restart your computer. Some temporary issues with your computer and how it's connecting to your network could be causing 502 errors, especially if you're seeing the error on more than one website. In these cases, a restart would help.
  9. Restart your networking equipment. Issues with your modem, router, switches, or other networking devices could be causing 502 Bad Gateway or other 502 errors. A simple restart of these devices could help.
    Tip: The order you turn off these devices isn't particularly important, but be sure to turn them back on from the outside in. In other words, turn on the outermost hardware on the network first (usually your modem), followed by the device it's connected to (usually your router). Next would be any switch or other device between the router and your computer.
  10. Change your DNS servers, either on your router or on your computer or device. Some Bad Gateway errors are caused by temporary issues with DNS servers.
    Note: Unless you've previously changed them, the DNS servers you have configured right now are probably the ones automatically assigned by your ISP. Fortunately, a number of other DNS servers are available for your use that you can choose from. See my Free & Public DNS Servers list for your options.
  11. Contacting the website directly might also be a good idea. Chances are, assuming they're at fault, the website administrators are already working on correcting the cause of the 502 Bad Gateway error but feel free to let them know about it.
    See my Website Contact Information page for a list of contacts for popular websites. Most websites have social networking accounts they use to help support their services. Some even have telephone and email contacts.
    Tip: If you suspect that a website is down for everyone, especially a popular one, checking Twitter for chatter about the outage is often very helpful. The best way to do this is to search for #websitedown on Twitter, as in #cnndown or #instagramdown.
  12. Contact your Internet Service Provider. If your browser, computer, and network is working, and the website reports that the page or site is working for them, the 502 Bad Gateway issue could be caused by a network issue that your ISP is responsible for.
    Tip: See How To Talk To Tech Support for tips on talking to your ISP about this problem.
  13. Come back later. At this point in your troubleshooting, the 502 Bad Gateway error message is almost certainly an issue with either your ISP or with the web site's network - one of the two parties may have even confirmed that for you if you contacted them directly.
    Either way, you're not the only one with seeing the 502 error and you'll need to wait until the problem is solved for you.
Errors Like 502 Bad Gateway
The following error messages are related to the 502 Bad Gateway error:
500 Internal Server Error ' 503 Service Unavailable ' 504 Gateway Timeout
A number of client-side HTTP status codes also exist, like the very common 404 Not Found error, among many others: List of HTTP Status Code Errors.
Aug 06, 2014 | Yahoo Computers & Internet
How do I remove 502 Bad Gateway from my computer
Generally, a 502 error is not something you can fix. It means that one or more of the servers that fulfill your request for a web page aren't sending back what's expected. (It's quite typical for a web site to grab data from other places to render the page you are looking at. The main text usually comes from the site you are looking at, but a lot of the times, the pictures, video, comments section, etc., might be hosted on another machine altogether. The ads placed on web pages typically come from outside servers.)
If this is the only web site on which you are getting a 502 error, it probably is the site. However, I was able to go to http://www.quotev.com/ (using FIrefox 19.0.2 and Chrome Version 25.0.1364.172 m) with no issues, which makes me wonder. If you are getting the error when visiting a lot of sites, it's probably time to do some more digging on your end. Have you tried power cycling the router that serves the Internet at your place? It's possible that the site has moved to a new server and the router has some of the old web site IPs in it's routing table. That is, it might not be your laptop, but in the router or further upstream toward the web site.
Jul 02, 2014 | Computers & Internet
502 bad gateway message on every site except for Facebook and Hotmail and google.
Please a 502....
Did you check if you are surfing on a proxy?
Did you visit any suspected websites recently?
Is there any unusual activity on your computer?
That are the things to check.
And last but not least are you the one controlling your browser, firewall, router etc or is that someone else?
May 03, 2014 | Computers & Internet
Error 502 secure error
This may be due to software installed on your computer which is preventing access to a particular webpage ( for example if Forefront TMG 2010 is installed), there could be many reasons why the problem exists and usually it is a bad gateway error which can be resolved by googling the error code (copy/paste) and you could also try the college IT dept. to see if they can resolve the issue, hope this helps.
Aug 06, 2017 | Computers & Internet
List of abbreviations
Here is the list of error codes for websites
100 Continue
101 Switching Protocols
200 OK
201 Created
202 Accepted
203 Non-Authoritative Information
204 No Content
205 Reset Content
206 Partial Content
300 Multiple Choices
301 Moved Permanently
302 Moved Temporarily
303 See Other
304 Not Modified
305 Use Proxy
400 Bad Request
401 Unauthorised
402 Payment Required
403 Forbidden
404 Not Found
405 Method Not Allowed
406 Not Acceptable
407 Proxy Authentication Required
408 Request Time-Out
409 Conflict
410 Gone
411 Length Required
412 Precondition Failed
413 Request Entity Too Large
414 Request-URL Too Large
415 Unsupported Media Type
500 Server Error
501 Not Implemented
502 Bad Gateway
503 Out of Resources
504 Gateway Time-Out
505 HTTP Version not supported
Oct 23, 2013 | Computers & Internet
Cannot contect to apache through wrt54g
Highly unlikely. That would block all HTTP sites that use Apache. Even then, how would they distinguish one web server from another type. Your error is based on a specific site, or all internet if Comcast does not show their splash page saying it can't reach a specific site.
Dec 04, 2012 | Linksys Wireless-G WRT54G Router
Nokia N8 I can not use internet. Error: 502 Bad Gateway T-mobile Bad Gateway. Can you help me?
You'd better reset your network.
Tools>Setting>Network setting>AP>Options>New access points>
After finished, restart your cell phone.
electronics wholesale
Nov 14, 2011 | Nokia N8 Cell Phone
My phone internet is not working? It keeps getting HHTP Error : 502 Bad Gateway !
The error you are getting, HTTP Error: 502 Bad Gateway, is not a problem that you are able to fix.
The error relates to one of two things:
1) The site you are trying to access has a problem with it's server and you will get the same error message from any device that trys to access the site.
2) Your network carrier is experiencing network difficulties/equipment failure and needs to repair the fault.
The error may already have been resolved. To check this, restart your phone to clear the cache and try to access the internet again.
Regards,
sjstore2
Dec 18, 2010 | Samsung Cell Phones
Error 205 when i try connecting 2 bing server
Are you sure it's not ERROR 502? If it is then this means "service temporarily overloaded" or "bad gateway" In either case it is the web sites problem and not yours.
Apr 28, 2010 | IBM ThinkPad R51 Notebook
Motorola Mobility RAZR V3c Cellular Phone Logo
208 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
