Question about Dell 5650 Computer Speakers
Hey there I have Dell 5650 Computer Speakers i turn the volume all the way down but still get high sound from speakers someone please help
Here is your Fix!!!
Go to RadioShack and pickup these items. 2 packs of 3-conductor Stereo 1/8" (3.5mm) Phone Jack part no.# 274-0219 you will need all four of them, Two comes in each pack. 1 Project Enclosure Box 4x2x1" part no.# 270-1802. A 5 pcs soldering kit. 1 pack of 22 gauge * stranded hookup wire red, green and black comes in the pack of three rolls. Okay let's get started. You need to know how to use a soldering iron. Small pliers, wire strippers. Cut nine pcs. of wire the lenth of 5 inches 3 green, 3 red, and 3 black. stripper both ends of the wires, about 1/2 inched. tie only one end of each color sets together. You sure have 3 grn wires tied, 3reds tied and 3blks tied. Solder them together. each set by themselevs. Used the heat shield the thing that looks like a pair of sissiors with a spring at the end. clip it on the wire where the color and wire meets so you won't melt the plastic on the wire. do the same at the other end but don't tie them together. Open a pack of the stereo jacks or phone jack not telphone Stupid!. you will see it has three tails sticking out. Use the heat shield to shield the black plastis on each tail. Put some solder on each tail!!!!. Now to connect you work. Solder the top no.#1 pin to the green end that is tied together. look on the bag silly :-). Solder the pin on the same side no.#3 to the red end that is tied together and the black to no.#2 the end tied together. Now all the loose green end wires get solder to the other stereo jacks no.#1 one pins one on each of the others. Now do the blacks the same way on no.#2 the same way. now the box mounting. what you need is this a drill and a 1/4 inched drill bit. Drill three holes on one side and one on the opposite side. take the plier and srew off the ring of the stereo jack with the ties end into the one hole side and the same on the other side with the remaning jacks. Take the stereo audio cable and plug it in the one side jack and the other end into you laptop or whatever!!!! headphone jack or line out jack on your pc. Take the dell jacks and stick them in the other three. Hope you have all the speakers hooked up. WHALAA! sweet sounds. Hit me up on facebook Lyons Joseph and tell me how you love them now. The speakers Silly :-)
Posted on Apr 28, 2010
    Sergeant:
  • 267 Answers
How long has this been going on? you can also turn the volum down on your computer look to the lower right corner of you monitor. you will see a little horn. double click it to bring up your volum control lower as needed
Posted on Nov 13, 2009
Dell Home Theater Speaker System MMS 5650, subwoofer not turning on...fuse NOT blown. Has turned on for a second and then goes back out. What is the problem??
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
:((appropriate speakers)): also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
Jul 05, 2011 | Dell 5650 Computer Speakers
No sound comes out of two of the speakersgostmilk@hotmail.com
you might have to uninstall then reinstall both the driver and the sound devices
((appropriate speakers)) or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers or right click select properties to either troubleshoot,uninstall,rollback driver
hope this helps
Dec 30, 2010 | Dell 5650 Computer Speakers
I can not hear sounds on laptop sometimes i hear it at the starting
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
hope this helps
Oct 03, 2010 | Dell 5650 Computer Speakers
I have the Dell 5650 Computer Speakers..I had to reolad the audio driver.. now, the two fron speakers and the center speaker under the monitor work, but the two rear speakers are not producing sound..I...
If you are using Sound Blaster, go into "All Programs" and open the "Creative File" and then the "Audio Console", left click the "CMSS 3D" tab, under the "CMSS Modes" click on the selection box and select "CMSS". They should start working at once.
Sep 04, 2010 | Dell 5650 Computer Speakers
Can't control sound
what you need to do is the audio you must plugged it in thegreen spot in the back of the pc
Aug 05, 2009 | Dell 5650 Computer Speakers
Speaker volume too loud
Have you tryed to turn down the sound volume on the media player its self as well as the the main volume?
Jun 21, 2009 | Dell 5650 Computer Speakers
My Dell 5650 Woofer isn't working.
Please download the manual for Dell 5650 and check the placemat details if anything is missing.
http://support.dell.com/support/edocs/acc/p62507/
And update me if that helped.
Feb 07, 2009 | Dell 5650 Computer Speakers
No sound, cenral and rear speakers Dell 5650 speakers
the surround sound speakers connect to the computer by way of three connectors. the system should have come with an adapter that plugs all three connectors into one green connector. if you color match that green connector into the computer you should get sound out of the central and rear speakers. not sure if the surround sound will work correctly for movies, but you should get sound
Jan 20, 2009 | Dell 5650 Computer Speakers
Dell MMS 5650 speaker Volume control
Since it has been working perfectly, you need you change the control knob, there may be a pershal contact that is preventing it from controlling the volume.
Jowinson
Jun 18, 2008 | Dell 5650 Computer Speakers
Not working at all
If all your connections are sound, call dell. If they can't do anything for you insist on a refund. (You have to get testy with Dell)
Dec 29, 2007 | Dell 5650 Computer Speakers
Dell 5650 Computer Speakers Logo
304 people viewed this question
Top Dell Audio Players & Recorders Experts
jairo sanchez
Jax Planet
Jax Planet
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
