Question about Polaris Ranger RZR Ride on Toy
Vehicle only works in slow speed, no reverse or high speed.
    Genius:
  • Polaris Master
  • 1,508 Answers
Do both wheels spin in the rear, might be a bad motor
Posted on May 14, 2012
2000 toyota corolla carburetor the car shuts off every time i come to a stop or slow down
you have two circuits in a carby......a high speed and a low speed, the slow one is the one that takes engine revs up to about 1500 rpm, the high speed takes over after that. these carby's can be a nightmare to fix, only tackle if you feel confident or try a can of carb clean sprayed into the air intake.
Feb 23, 2014 | 2000 Toyota Corolla Inside Door Handle Set...
Not step on the accelerator of vehicle automatic speed
Automatic vehicle at the beginning will automatically forward, but the speed is not too fast, because the automatic mechanism principle, high running loose throttle speed decreased than manual slow some, is a normal phenomenon. use gna 600 to diagnostic If the initial automatic acceleration, speed has a problem, the problem generally appear in the idle adjustment problems, such as: solar term door fault, the intake system leakage phenomenon, cause idle setting, you can go to your car repair station for inspection repair, in order to accurately determine fault.
Dec 09, 2013 | Ford Explorer Cars & Trucks
Does not operate in reverse
If the vehicle will not go in reverse, but works in both low and high forward speeds you most likely have a bad shifter switch.
The shifter switch is only available in a shifter assembly found here: http://www.mendingshed.com/j4390-9209.html
Replacing the shifter should get your Power Wheels running correctly.
Thank you,
Colleen
Customer Service
MendingShed.com
800-339-9297
Mar 26, 2013 | Fisher Price Power Wheels Barbie Mustang...
Apart from the squeaking from my shoes on the foot pedals, listen to the car as it goes over the humps. Any quick diagnoses?
Instructions
    • 1 Remain calm. It's easier said than done, but a cool head is essential to safely control your vehicle.
    • 2 Keep your eyes on the road and continue to steer. Pay attention to what's in front of you, and maneuver to avoid heavy traffic, pedestrians, and dangerous obstacles. The one exception is if your brakes don't work because something is stuck under the pedal. If that's the case, you should try to remove the object with your foot, rather than bending down to get it.
    • 3 Warn other drivers and pedestrians. Turn your hazard lights on, and honk your horn to make others aware that there is a problem. While they may not be able to figure out what the problem it is, a warning should cause most people to proceed with caution and pay attention to what your vehicle is doing.
    • 4 Pump your brakes. Pumping your brakes several times may rebuild enough pressure in the braking system for you to stop. This may take a while, so keep trying. You should do this even if your car is equipped with ABS as the ABS is only activated when your car is braking too hard, which won't be the problem if your brakes have failed.
    • 5 Shift into low gear. If you have a manual transmission, downshift quickly. You may not be able to downshift directly into first or second gear at high speeds, but go into the lowest gear you can, and try to downshift again once the vehicle slows a bit. With a manual transmission you can possibly stop the car very quickly by slamming it into reverse; according to one report, it spins the drive wheels in reverse momentarily, then the entire transmission fell into the street as the car stopped! If you have an automatic transmission, shift into low range (generally labeled as "1" on the shifting mechanism). Again, if you can't go directly into the lowest range, try gradually shifting down.
    • 6 Use the emergency brake. The emergency brake, or "parking brake" can usually stop a vehicle, although it will take longer than usual to come to a stop. Apply the brake (depending on your vehicle this is done either by pulling up on the handle or pushing down on the pedal) slowly and steadily. If you pull up the brake quickly, your vehicle is liable to spin out of control.
    • 7 Slow the vehicle however you can. If the above measures fail to stop you, or if you must stop very quickly, do whatever you can. Ideally, you could use a runaway truck ramp, but as these are not particularly common, you'll probably have to improvise. Keep in mind, however, that these techniques can be very dangerous, especially at high speeds, and should only be used as a last resort.
      Use friction to slow your vehicle. Driving through gravel or dirt (such as you might find right off the side of the road) can slow your vehicle considerably.
      Use guardrails to slow your vehicle. Cement dividers are built pear-shaped so that contact is made with the wheels, not with the precious metal and paint of your automobile. Applying friction to the rubber on your wheels will slow the car considerably without harming other portions of your vehicle.
      Use terrain to your advantage. Try to seek out inclines that you can go up.
      Small trees and shrubbery will slow your vehicle when all else fails. Try to put your vehicle through the center of a line of shrubs or saplings, being careful not to pick a tree that is too heavy for your car to go through.
      Hit the back of another car. While obviously not a first choice, it can slow your vehicle. If you're going to do so, try to warn the driver in front of you by honking your horn. Try to strike a vehicle that is traveling at about the same speed as yours (hitting a slow-moving or parked car will stop you, but the deceleration will be quick and extreme) and attempt to make impact squarely on the back of the vehicle. Glancing blows will likely send both vehicles out of control.
    • 8 Look for a safe spot to pull over (or to crash). Scan the road ahead for a safe area to pull over once you're able to come to a stop. If you're not able to bring the vehicle to a complete stop, look for open spaces that you can coast across without hitting anything.
      If the safest spot to "crash land" your vehicle requires you to jump a curb, extra caution must be taken. Even with power steering, the cars' initial reaction will be to rip the steering wheel from your hands, bounce from the curb and back into traffic. It is imperative that you grip the steering wheel in a firm manner and angle your car deep enough into the curb so that it will go up and over, yet shallow enough so that you don't turn the car completely and lose control in a spin.
Jan 20, 2013 | Cars & Trucks
How do i change the speed
There're is a screw in the shifter, take that screw out and there will be reverse and slow forward and shifter will now go up high to high forward
Sep 21, 2011 | Fisher Price Fisher Power wheels Cadillac...
How do i know if its my tcc solenoid and not the torque converter its self and will it affect the reverse
If the solenoid is stuck so the torque converter remains locked, the transmission will not be able to shift down and the engine may stall when you slow down from highway speed. This seems to be the most common problem with this part, and it shows up primarily in prolonged high-temperature running.
If you can get the vehicle into reverse with a locked torque converter, you may have to maintain a minimum speed to keep from stalling the engine - not a safe situation.
My experience with hanging TCC solenoids is that they usually release the clutch if they are allowed to cool for a few minutes, if they don't release when the engine stalls.
If the TCC is not locking the torque converter, there will be no difference in high-speed performance when you disconnect the TCC solenoid. If the TCC is working to this extent, disconnecting it will cause a lag in acceleration and loss of gas mileage in high gear. Unfortunately, this is not a completely definitive test; it does not rule out a malfunction in the torque converter clutch mechanism.
Jan 28, 2011 | 1999 Chevrolet Camaro
Reverse speed too high
No, the controller must be reprogrammed and you will need an Invacare service tech to bring his hand-held programmer over to make the corrections to the chair.
Oct 11, 2009 | Health & Beauty
Polaris Ranger RZR Ride on Toy Logo
118 people viewed this question
Top Polaris Toys Experts
Adam Fjeld
Adam Fjeld
cwradio73
D. E. Hev
Are you a Polaris Toy Expert? Answer questions, earn points and help others
