Question about Campagnolo Record 10-Speed Barend Bicycle Shifters - Pair - SL00-BE10CG
Sloppy shifting on a 9 speed campag record groupset
Hi I have a 9 speed campag record groupset with carbon shifters. I like the ergonomics and the positive shifting. They have probably done more than 20k. They still work but are not as crisp as they once were. Is there an accurate way of diagnosing what is needed to refurbish? At what stage should you count your losses and buy new gear?
Thanks
K
  • keith_r_sali Nov 17, 2009
    Hi
    My shifters are the ergo type with the integrated brakes/shifters(not bar end shifters) The comment was made in this category because it was the closest fit.
    Thanks for the advice which would be appropriate if the cabling was old. However this is not the case.
    Thanks anyway.
  • 1,305 Answers
Try replacing the cables first. If the cables are getting too stretched, maybe you can get more life out of your shifters with fresh cabling..
Posted on Nov 15, 2009
2009 aveo how do get to the transmission linkage from the shifter inside the car? I heard something fall of like a bolt and now the shifter is sloppy 5 speed manual
Best way is to jack up the car, install jack stands and crawl under the vehicle and perform a visual inspection of all components where the shift handle assembly mounts to.
Jun 24, 2017 | Cars & Trucks
How to remove the gear shift of a cadillzc dts 2011
    Cadillac 03-07 CTS and 04-09 SRX Shifter Assembly ...
    ? 1:31
    https://www.youtube.com/watch?v=GgZA6PbxaVA
    Feb 9, 2013 - Uploaded by Dominick Chavez
    Hello, This is a quick sloppy video of how to replace, re-install, and fix a clunky shifter. This works for 2003 ... images for How to remove the gear shift of a cadillac ...
Feb 03, 2016 | Cars & Trucks
How do I fix jumping gears on rear derailleur?
I also would check if the chain is not worn out. When the lenght increases the chain links, these also can make the chain jump. Put the bike up and rotate the peddles, while shifting gears and watch if the d?railleur moves fast enoug. Perhaps even the jumping is over, because the links are not pulled out.
for chain wear, check out this wiki. Bicycle chain Wikipedia the free encyclopedia
Mar 22, 2015 | Cycling
5th gear synchronizer shifter
sound to me like a basic sloppy shifter, did you inspect the shifter and all parts associated?
usually the synco dont stop shifts, only causes grinding
unless, it is shattered. (rare that)
it only matches speeds, so if cracked in half , you can shift by
double shifting , like racers and truckers did for years, "crash boxes"
RTM
http://hondatech.info/downloads/Auto/Manuals/Civic/
Nov 13, 2013 | 1987 Honda Accord
I have a 2001 Saab 9 3 se automatic transmission it drives great but wont go into park and I have to start it in neutral.
sounds like a linkage problem. when in gear, does the shift indicator look like its in-between gears?
Sep 23, 2012 | 2001 Saab 9-3
I have been given a set of Mavic NKSIUM Race wheels currently fitted with a Campag Cassette. Are these hubs Shimano compatable, as I want to fit a 8 speed Shimano Cassette Ian...
Nope. Campi and Shimano casette bodies are TOTALLY INcompatible, BUT I have had good luck with finding Campi casettes online (eBay) and having no interchange problems between my wheels and Shimano or Campi 9-speed shifters and derailleurs on several bikes. I switch wheels without concern for the other hardware.
http://desc.shop.ebay.com/i.html?_nkw=campagnolo+8-speed+cassette&_sacat=0&_odkw=campi+8-speed+cassette&_osacat=0&_trksid=p3286.c0.m270.l1313&LH_TitleDesc=1&_rdc=1
Within Campi there may be incompatibilities, though. If your wheels have an 8-speed Campi cassette now I think you'll be ok.
Feb 09, 2011 | Mavic Cycling
Campagnolo Record 10-Speed Barend Bicycle Shifters - Pair - SL00-BE10CG Logo
203 people viewed this question
Top Campagnolo Cycling Experts
Michial Gueffroy
jimmarmor_ma
Are you a Campagnolo Cycling Expert? Answer questions, earn points and help others
