Question about Sakar Kidz Cam Digital Camera
All I need is where can I find the screws that hold the cover down where the batteries and the memory card go. It is the crayola camera
  • 132 Answers
RADIO SHACK SHOULD HAVE SOME THING THAT YOU CAN USE
Posted on Nov 13, 2009
Insertion of sd card into crayola camera model 25070n
Use a screwdriver to remove the battery cover on the bottom of the camera. You'll see a slot running lengthwise, between the batteries. The card goes in contacts first, the notched corner toward the single battery.
Dec 28, 2011 | Crayola 2.1 MP Digital Camera Scrapbooking...
Every time we take a picture, a red F appears on the screen and we have to shut the camera off and turn it back on each time we want to take a picture. The camera is also not saving pictures
I think you can download a user manual from here:-
http://www.sakar.com/productdetail.aspx?id=2498&return=y&txt=Sakar+Crayola+EZ+Grip+&page=0
I had a quick look at the manual and on page 8 it states:-
If icon red F appears on the screen, this is an indication that the internal memory is full. No further
photos can be taken until the existing photos have been downloaded and cleared from the camera
memory.
You need to empty the camera's internal memory (Download the manual) or insert an SD card, this camera can take up to a 2Gb standard SD card. Needs to be formatted with FAT 16 file system.
(User manual)
Sep 25, 2011 | Sakar Crayola EZ Grip Digital Camera
Error 53 on crayola camera
This is usually a memory card error. This older camera can only take SD, not SDHC cards. ry another non-SDHC memory card.
Mar 18, 2011 | Cameras
I have put fresh batteries in my Canon Power Shot S1 camera and it still will not come on? Can you help me?
Contact failures may have occurred between the camera and the batteries.
Confirming that the [Memory Card / Battery Cover] is securely closed
If the [Memory Card / Battery Cover] is not securely closed, the power of the camera may not turn on.
Close the [Memory Card / Battery Cover] securely, and then turn the power on.
Clean the battery terminals with a dry cotton swab that has a fine and soft tip, and then re-insert the batteries.
If your camera uses four AA-size alkaline batteries supplied with the camera, follow the procedure below. In addition to Alkaline batteries you may use optional nickel metal hydride (NiMH) batteries.
1. Be sure that the camera power is off.
2. Slide the battery cover lock in the direction of the arrow, and push the battery cover slightly forward. Then open the cover.
batts_step1.gif 3. Insert the batteries as shown.
batts_step2.gif 4. Close the battery cover.
batts_step3.gif * For the PowerShot S2 IS, PowerShot S3 IS, and PowerShot S5 IS the batteries are inserted in a slightly different order, please refer to the decal inside the battery door for the correct order.
Installing batteries in cameras with 2 batteries. If your camera uses two AA-size alkaline batteries supplied with the camera, follow the procedure below. In addition to Alkaline batteries you may use optional nickel metal hydride (NiMH) batteries. Please see the various examples to find which type matches your camera.
Example 1:
  2. Slide the battery/memory card cover lock in the direction of the arrow (1.gif), and press down while opening the cover (2.gif).
  3. Insert the batteries as shown and close the battery / memory card cover.
Example 2:
  2. Slide the battery cover lock in the direction of the arrow, and open the cover.
* For the PowerShot A300 and PowerShot A310 the battery polarity is reversed.
Dec 05, 2010 | Canon Cameras
Battery door replacement how to? The battery door on my Nikon Coolpix L5 doesn't stay closed anymore because a little piece broke off when I dropped the camera. I can get a new battery door cover but...
OK IT IS EASIER THAN IT APPEARS TO BE(DONT GET SCARED)#1 REMOVE BATTERIES AND MEMORY CARD AND STRAP(if you have one)#2REMOVE ALL THE SCREWS AROUND THE CAMERA(you will see 3 screws around the tri-pod mounting hole DONT REMOVE THE LONE SCREW THAT IS CLOSER TO THE LENS(AS IT IS NOT HOLDING ANYTHING BUT THE TRIPOD INSERT AND LEAVING IT IN WILL MAKE IT EASIER TO SNAP EVERYTYHING BACK TOGETHER.#3CARFULLY AND EVENLY PRY ON THE BODY TO REMOVE THE SCREEN SIDE.#4 NOW YOU WILL BE ABLE TO SEE THE SMALL CLIPS THAT HOLD THE LENS SIDE OF THE BODY CARFULLY SEPERATE FRONT BODY (* this will enable you to see the large head on the battery pin.) #5 WITH A THIN NEEDLE NOSE PLIERS PULL THE PIN OUT #6 LAY THE NEW COVER DOWN AS IF IT WAS CLOSED AND INSERT THE PIN BACK IN.#7 BEFORE YOU SNAP THE FRONT BOBY BACK IN BE SURE TO PUT THAT TINY RUBBER BATTERY PULL TAB BACK IN THEN CAREFULLY SNAP THE FRONT COVER INTO THE CHROME AND THEN THE BACK COVER. PUT SCREWS BACK AND YOUR DONE.
Jun 21, 2010 | Nikon COOLPIX L5 Digital Camera
Screen is black when i attempt to take pic
Move all the pictures to the camera memory card from your internal memory. Since you have to open the camera, the pictures will be lost otherwise. Save your pictures. If you do not have a memory card, transfer all the pictures to your computer.
Remove batteries from the camera.
Purchase a replacement LCD screen, specific to your camera. These replacement screens can usually be purchased directly from Canon or from a camera resale shop. Auction websites should also carry LCD screens specific for these cameras. Use the mini screwdriver to remove the four screws from the back of the camera. Be careful with this step since the screws are tiny. Take the back cover of the camera off carefully. Inside the camera, there is a piece of foam that supports the LCD screen. Do not remove the foam. Set the bottom portion of the camera to the side.
Turn the top portion of the camera so it is facing upward. Notice how there are clips holding the LCD screen in place. Carefully lift these clips up and remove the broken LCD screen. The screen clips are extremely fragile and break easily if they are lifted too quickly. A gentle touch is key.Place the new screen down gently and replace the clips. Gently dust the screen so fingerprints are removed.Turn the top portion of the camera down so the screen is pointing down. Place this on top of the foam padding. Turn the screws carefully. The best way to screw the back of the camera in place is to first screw in one corner, move to the corner that is diagonally across and turn that screw. Repeat for the other two screws.Replace the batteries. Turn the camera on and see if it is function.
Thank you !!
Jun 01, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
Screen stays black
Purchase a replacement LCD screen, specific to a Samsung S860 camera. These replacement screens can usually be purchased directly from Samsung or from a camera resale shop. Auction websites should also carry LCD screens specific for these cameras.
Sep 02, 2009 | Samsung S860 Digital Camera
Battery and memory card compartment cover wont stay closed
ours does the same thing, i couldn't figur out a way to keep it ****, so i just taped it.
Jul 25, 2008 | Casio EXILIM Card EX-S770 Digital Camera
My fuji A700 shuts off when trying to take a picture!
I have the same camera with the same problem.I tried the new batteries.Didn't work.I tried holding down the battery back.Didn't work.Took out the memory card and pushed the on button and it said memory card was full,but the memory card wasnt in it.So try taking out the memory card and see if it tells you the problem.I erased some pictures and it worked.
Jun 21, 2008 | Fuji FinePix A700 Digital Camera
Cover card open when it's shut
This problem is caused by the little piece of plastic that you flip down to hold the XD card in place. It has a nipple sticking out of it that is prone to breaking off. Unfortunately, this nipple (about 1/16" x 1/8" x 1/8") holds down a little button which tells the camera that the the plastic piece has been flipped down. Once the nipple breaks off, you need to find some other way to hold the button down.
I simply took a small plastic peg from an old boardgame -- a cribbage-board peg might work -- and whittled it down to fit the opening. Remove the XD card and you'll see the small 1/16" x 1/8" rectangular opening. There's a tiny, squarish black button inside. Use a toothpick or tiny screwdriver to carefully press the button in while the camera is on, and you'll see the error message disappear.
Once you get the idea, use a tiny Phillips screwdriver to remove the plastic piece that you flip down. There are two screws to remove, two little metal retaining brackets and a tiny metal rod. Be careful not to lose any of these pieces! Then gradually whittle your piece of plastic so it fits the rectangular opening snugly, and consistently turns off the error message. Then cut it to about 1/8" in length, insert it into the opening, and reassemble the rod, brackets and screws to hold it in place.
Now the little button will always be pushed in and the camera will be functional once again. Since the XD card has its own spring-loaded "locking mechanism" (you push to insert and push to remove), the piece of plastic you flip down isn't really needed in the first place. You can save it, anyway, just for the memories....
Apr 05, 2008 | Olympus Stylus Verve S / ?-181 mini S...
Sakar Kidz Cam Digital Camera Logo
51 people viewed this question
Top Sakar Cameras Experts
Robert
Steven Wander
Steven Wander
Are you a Sakar Camera Expert? Answer questions, earn points and help others
