Question about Linksys Wireless-G WRT54G Router
The router shows connected but will not connect to internet
  • 535 Answers
U have to configure the router first u have to put the IP address in a router by the given your internet provider if there is something like that 192.168.1.2 then u have change Your router IP address default IP address is 192.168.1.1 u have to change it first u have change it 192.168.0.1 then the give sub-net marks 255.255.255.0 then after gateway address is 192.168.1.1 then after DNS server is 192.168.1.1
1) disconnect router form the internet
2) plug in it in local pc
3) open internet browser
4)type in address bar 192.168.1.1 then press go
5) u got log in screen type there user name admin and pass is admin
6) then go in internet setting do change as i say
Posted on Nov 13, 2009
I have a LinkSys WRT54G2, Vers 1.0 router with the latest firmware installed and basically default configuration. I usually have 3-4 PCs connected to the router. I frequently loose connection to the...
Sometimes, you might face a situation where your wireless icon shows that you are connected to the Internet but you just can't access any websites. What do you do when you face this problem?
This article will show you how you can repair Internet connection when wireless icon shows connected, but unable to go online.
To connect to your wireless network with Wireless Zero Configuration, please click here.
In checking if you're computer is properly connected to the Linksys Router, you will need to perform four steps:
i. Checking the Physical Connection to the Router
ii. Checking the LEDs
iii. Checking the IP Address of the PC
iv. Pinging the Router
NOTE: To check the computer's connection to the router using Mac, click here. If you are using Windows Vista, click here. For Windows 7 users, learn more here. For Windows 7 users, learn more here.
Make sure that the computer is connected to one of the four Ethernet ports of the router and the modem should be connected to the Internet port. For more instructions, click here.
Checking the LEDs
The Linksys router's LED lights will indicate the status of the connection. After connecting the broadband modem and the computer to the router, make sure that the LED lights are lit up. For more instructions, click here.
The IP address of the computer is another indication that the computer is properly connected to the router. For instructions, click here.
Pinging the Router
Ping test helps trace the communication between the computer and the router. The computer sends packets to the router and in return the router sends out replies to validate the connection. In this example, our router IP address is "192.168.1.1."
Dec 06, 2010 | Linksys WRT54G2 Wireless Router
Cannot connect internet as it shows internet is offline
Always check your LAN cable between your modem and the router and try a new cable. Login the make certain your router is configured correctly to connect to your mode.
Jul 13, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
My web light on my belkin router does not show any connection to web. But my primary computer still connects to internet using router. Why? My other computer show connected, but still can not connect to...
Turn everything off, modem, router and computer.
Turn on the modem first and wait for a solid data/connect light.
Turn on the router, give it two minutes.
Still if problem presists you need to reset the router
May 25, 2010 | Belkin (F5D8231-4) Wireless Router...
Netgear power is connected, but internet is not
If the router has no power you cannot connect to the internet.
If you have an internet connection then you are connected to someone else's router.
May 19, 2010 | NetGear DG834 Router
Cant connect to internet, icon shows as internet
Just unplug the router for 10 full seconds from plug-in, then plug it back in, wait a couple minutes, and try connection again.
Feb 20, 2010 | Trendware TEW-652BRP Router
Can't accress the internet as there is no gateway showing
Check whether your pc has static ip's set,
Go to Start/settings/Network Connections/Wireless connections
Click on Properties
Under the General Tab scroll in window to Internet Protocol (TCP/IP)
Next click on Properties
Make sure that both buttons (IP / DNS) are set to obtain automatically
Nov 14, 2009 | NetGear DG834G Router
Internet connection
i don;t realy understand ...
so u have a wireless router and the computer that connects to it shows that is connected but it doesn't work on the internet ?
than the computer connecting to the router is connected, but the router it self is not connected to the internet ! Go at the router settings and configure the internet connection ...
if this is not the issue, please try to explain again with more details what the problem is....
Sep 04, 2008 | Belkin (F5D7230-4) Router (587009)
Internet connection not detected
Try desconecting the router for a few minutes. Then turn off your pc and power on again your router and pc.
Feb 26, 2008 | Linksys Wireless-G WRT54GS Router...
Wireless internet connection
I may be able to help with this...but I need a detailed description of how you have things connected between the XP desktop, the cable, modem, the Linksys router, and the laptop. Also, is the Linksys router new?
Typically, the wan port on the wireless router connects directly to the cable modem with a cat5 network cable....then the desktop pc connects to the router...on port 1 for example...with a similar cable. Once the wireless router is set up properly, the laptop should then be able to connect using wireless.
Feb 01, 2008 | Computers & Internet
Linksys Wireless-G WRT54G Router Logo
98 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
