Question about HP Photosmart C6180 All-In-One InkJet Printer
0xc18A0101 HP printer error (model 7280) got the error from the units front panel,i think it's an ink cartridge rejection error.
  • 4,041 Answers
Hi just maybe it will clean the error off I found this I know your error not in here but it may work for It worth a try nothing to lose and it may work. I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm it Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
1. Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the product.
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7. Reinsert the cartridges, and then close any open doors on the product.
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 08, 2010
Error 0xc18a0101 persists. Have tried solution given earlier for 0xc18a0001 without success. Ink system failure not resetting; all cartridges are full.
Its tricky mechanism, once printer detects ink system failed it cannot be resetted. Do this take out cartridges from printer., open right cover., find out logic card., remove cmos battery., wait for 5 minutes., refix batyery., power on the printer., follow the screen messges ... I hope it will solve the issue..
Sep 15, 2014 | HP Office Equipment & Supplies
I receive hp catridge error when i refill the catridge and install in my printer.
check if cartridge is genuine
check if it is really a brand new one or fake
power cycle the printer
check if it has an alignment option,align the cartridge with new inks
check if it has a clean utility automatic cleaning
or you can manually clean the contacts on printheads which detects the inks the you inserted
reset the unit if you know how to
different printer has specific way of resetting
most probably you are just getting a rejection error try using theold one if that fixes the issue it means there must be an issue with brand new inks
hope it helps you
Your's Truly,
Christian from HP
Say "Thanks" by clicking the thumb icon in the post that helped you.
Please click "YES" in solution that solves your problem as "was this helpful?"
(Although I am employed by HP, I am speaking for myself and not for HP)
Apr 10, 2011 | Office Equipment & Supplies
Hp 7280 all in one. Magenta ink (all new) does not work. Test print shows good cartridges and plenty of ink.
Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached. To reattach the cartridge, turn on the lid of the printer and then remove the cartridge from the printer head. Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report. Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
Jan 18, 2011 | HP Photosmart C7280 Printer
I have ink error OXC18aOOO1. Any idea of what I should do or how to clean the printer head, it won't pull over so I can get at the printer head. Thanks David
THAT 0X ERROR IS AN INK SYTEM FAILURE IT MAY HAVE BEEN CAUSED FROM REFURBED CARTRIDGES... THE HP WILL WORK WITH THE REFURBS FOR A FEW TIMES BEFORE REJECTING THE CARTRIDGE OR CAUSING AN 0x ERROR. THE UNIT NEEDS TO GO THRU AN ELABORATE INK SYSTEM RESET OR THE PRINTER NEEDS TO BE SERVICED
Mar 29, 2010 | HP Photosmart C7180 All-In-One InkJet...
Error 0xc18a0101
I think this may be an ink problem try resetting the printer
Follow steps below to reset Hewlett-Packard (HP) All-in-one Printers (products with keypads only).
Resetting your printer will reset your printer to its original state.
For products with keypads on the control panel:
1. Without turning the unit off, unplug the power cord from the back of the product.
2. Press and hold “# and 6′ keys.
3. While holding those keys plug the power cord back in.
4. Wait until the screen goes blank before you release those keys.
5. Follow on printer screen instructions.
Mar 25, 2010 | HP Photosmart C6180 All-In-One InkJet...
My all-in-one C6280 is reporting Error 0xc18a0101 Ink system has failed. Unable to print. The machine is less than 1-year old and is rarely used.
Hi
It is a Ink System Failure" error 0xc18a0101.
You can try.
Reset the product:
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
Jan 31, 2010 | HP Office Equipment & Supplies
Error: 0xc18a0101 I just change a ink and this
It seems some one else has had your problem. http://www.fixya.com/support/t1132877-oxc18a0101_error_message_c6180_all_in .
Jan 15, 2010 | HP Photosmart 3310 Printer
HP 7280 All in one problem Ink System failure Error 0xc18a0501 I have tried shutting down even reset the system, but it still produces same error code.
1. Try to remove and reinstall the Ink Catridges. Be sure it is lock in place on the ink cartridge holder.
2. Turn off the Printer and unplug and replug the power adapter.
3. Uninstall and reinstall the printer driver.
Jun 16, 2009 | OKI C3400n Laser Printer
Ink system failure
HP Photosmart C7180 will not accept new '02' yellow ink cartridge and repeatedly states 'printer does not have enough ink to ensure printer health. The empty ink cartridge must be replaced to resume.' This is the 2nd HP '02'yellow I've bought and it continues to say the same.
Sep 06, 2008 | HP Photosmart C7180 All-In-One InkJet...
HP Photosmart C6180 All-In-One InkJet Printer Logo
355 people viewed this question
Seeker5211
Seeker5211
